Old 04-05-2011, 09:57 PM   #736
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Korey Harbke View Post
That's exactly what we do. You just can't see it.
-Korey
ahh. better pictures then! lol
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 04-05-2011, 09:59 PM   #737
pakk's Avatar
Trader Rating: 79 (100%+)
I was told today that Hudy bags 199120 and 199140 were discontinued. Is this true? Are new bags coming out?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 04-05-2011, 10:14 PM   #738
Canyon's Avatar
Trader Rating: 8 (91%+)
Originally Posted by Magnet Top View Post
Hey Canyon,
What changes to your setup would you make for "Mod" TC at Hangar 30? Next club race I plan to spin some !!! 17.5 1/12 put me in some kind of hibernation mode , I figure MOD TC should pull me out !
Jake
Well from my 17.5 nats setup, I'd definitely go with more rear toe. Bump it up to
1.15mm of shims for the rear arms. Probably move the sway bar link to the outer position on the rear arm. Thinking about dropping down to 1k oil in the rear gear diff not only for mod but for 17.5 too. And lastly throw in the 3 hole pistons up front with 500 and 3 hole pistons in the rear with 400.
Canyon is offline   Reply With Quote
Old 04-05-2011, 11:44 PM   #739
Magnet Top's Avatar
Thanks ! I'll give those suggests a try.
I kinda wish I had gone back to the gear diff for the final day, I was washing out a little and suspected it was the ball diff going bad but I just checked it and it feels fine. hmmm.... Also I had gone back to lighter shock oil for the last day too ( 500 2 hole / 400 3 hole ) from 600 2 hole / 500 3 hole for the quals ). I had good corner speed but it was not as predictable / consistent. Always too many things to consider.
Magnet Top is offline   Reply With Quote
Old 04-06-2011, 12:10 AM   #740
Canyon's Avatar
When I went to thicker oil in practice it made the car much more consistent. It seemed to also carry more corner speed and made it much more predictable. But that was SUPER high traction too. I feel like it tamed down the roll of the car and prevented it from dumping over due to such high bite. Now with the Hangar, there are bumps to work around. Granted my stock car was DIALED last time we ran, I think that in mod with the higher speeds the car will benefit from soaking up the bumps with lighter dampening. Gear diffs are tricky. It's a different driving style and much harder to be as consistent with them as a ball diff. Don't be discouraged if it's harder to drive. Work with it and learn how to drive it. I personally think the gear diff is faster, BUT only if you can drive it and be smooth and consistent. I spent a whole day at Timezone the weekend before nats learning the gear diffs, and I'll have to say I think it paid off.
Old 04-06-2011, 06:33 AM   #741
Drew Ellis's Avatar
Hey guys, getting ready to get on a plane to go to the 1/8 worlds. I will try and update you guys here on how the team is doing. Hold the fort down..
Thanks Drew
Oh the bags are not discontinued, we are just having to work some things out with customs.
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 04-06-2011, 07:10 AM   #742
Canyon's Avatar
Thanks Drew
And I'm sitting in the airport on my way to Silver State in Vegas. Have fun in Florida Drew. Talked to Brandon yesterday and LiveRC.com will be broadcasting the 1/8th onroad worlds.
Old 04-06-2011, 07:23 AM   #743
Drew Ellis's Avatar
Thanks Canyon, good luck there.
Yes thats right you can follow the team www.liverc.com and www.rcinsider.com
If you guys need something email me @ [email protected]
Thanks Drew
Old 04-06-2011, 04:29 PM   #744
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Keep an eye on Paul for us Drew. Heard he took a spill...
Old 04-10-2011, 03:33 PM   #745
Fred Hubbard's Avatar
Friday I received the new OG Spec premounts fresh from the factory in Korea to test out at West Coast Raceway for the 1st XRAY Challenge to be held there on April 29th - May 1st 2011. They are mounted on the EXP rim (EXP-WAWH) with the Aqua Medium insert (EXP-M). I waited toward the end of the day when most of the TC drivers had left to start testing to ensure that the grip had built up on the track (indoor asphalt) and also so I could have as close to uninterrupted sessions as possible while testing. I put a total of (7) 6 minute sessions on the tires and they look that same on run 7 as they did on run 2 with NO loss in performance!!! It is a "thing of beauty" at how good they look, the wear pattern is excellent!!! During each run the lap times remained consistent from start to finish and never fell off! This tire is simply amazing and is as fast as the other tires some of the guys have been running at the track. To say that these tires are impressive is truly an understatement!!!
RCAmerica/Xray,Hudy-og-spec.jpg
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 04-10-2011, 07:29 PM   #746
Johnny Wishbone's Avatar
Fred, what are these tire rated at 28/30/32 ? Any carpet run info on them ? Thanks
Gary Lanzer
Old 04-11-2011, 04:52 PM   #747
They are 40. I'm sure a carpet shore is coming at some point.
Old 04-19-2011, 06:43 PM   #748
Drew Ellis's Avatar
Default Xray Challenge
Paul Lemieux and myself will be attending the first Xray Challenge hosted by Westcoast. Hope to see you there.
Thanks Drew
RCAmerica/Xray,Hudy-2011-xray-challenge-flyer-1-.jpg
Old 04-19-2011, 06:57 PM   #749
casino57's Avatar
Thanks Drew
Hi Drew...Isn't one of the X-Ray Challenge races here at Leisure Hours in Chicago this year?
Mike Garcia - RCAmerica - XRay T3
Trinity - JDR - Hudy - KoPropo America
Laser Products - Tekin
Leisure Hours Raceway & Hobby Shop
casino57 is offline   Reply With Quote
Old 04-19-2011, 08:38 PM   #750
I'm no Drew, but I think this is accurate.
http://www.rcamerica.com/media/showa...?articleID=107
1/12 forum ovalnator Electric On-Road 46189 Today 08:13 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Ask Mike Blackstock Trinity ,Rcamerica, Team Xray Edition.. Mike Blackstock Electric On-Road 225 12-30-2006 06:57 AM
RCAmerica/ Xray / Hudy Mark G Electric On-Road 10 03-15-2006 09:17 PM
RCAMERICA Live Race Coverage @ The Dirt Nitro Challange David Joor Electric Off-Road 40 03-03-2005 12:33 AM
