Old 12-05-2010, 09:42 PM   #586
RCknight's Avatar
Originally Posted by Chris Adams View Post
Your curiosity has discovered the reason why he is binding :P
Ps. not sure if this is the truth but running high in the back is not recommended by any of the team guys.
Yeah Chris you could be right. After the above post, I remembered I did run an extra shim in each corner of my 008 when I ran the higher roll center. Can't remember if the 008 setup used more shims than the T3'11 per instructions or not. I think with the combination of the shorter rear/front once peice the and higher roll centers it may be causing it to bind. Thanks guys. I'll check it out closer.
RCknight is offline   Reply With Quote
Old 12-06-2010, 02:42 AM   #587
I don't have a T3'11, but a T2'009, and I have no problems with running the same roll-center as you. No binding at all.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 12-06-2010, 03:20 AM   #588
RCknight's Avatar
humm...well mine bind with the shocks and tires. I run 5mm ride height and they bind around 3-4 mm of compression. Some other guy here said he had the same issue with his T3R and went to the 50mm bones. Not sure what to do now other than add shims. Part of it has to be the rear one peice mount, since it's not equal in length to the rear bulk heads. Why I'm not sure. What do you do? I'm not buying 50mm bones. I hate to change track width, but it's the cheaper way to go.
Old 12-06-2010, 04:06 AM   #589
RevMaxx's Avatar
Send a message via MSN to RevMaxx
Originally Posted by P.I.M.P View Post
As said by by the other lad lining it up in the center would be my concern.and the epoxy would have to be a strong bond as it has nothing to key in to on the other side.if you can post a pic it would be better to know what you mean:-).
got the pics of the gear diff, the owner said went to more than 500 laps with no issues:
RCAmerica/Xray,Hudy-imag0014.jpg   RCAmerica/Xray,Hudy-imag0017.jpg   RCAmerica/Xray,Hudy-imag0019.jpg
RevMaxx is offline   Reply With Quote
Old 12-06-2010, 04:09 AM   #590
RevMaxx's Avatar
and here is a take on it.. "my build" :
twas tedious, but not that difficult...
RCAmerica/Xray,Hudy-imag0122.jpg   RCAmerica/Xray,Hudy-imag0134.jpg   RCAmerica/Xray,Hudy-imag0125.jpg   RCAmerica/Xray,Hudy-imag0137.jpg
Old 12-06-2010, 06:07 AM   #591
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Thats exactly how I did mine except I added CF pins to key the pulley to the case. What keeps your pulley from spinning on the case under power?
Old 12-06-2010, 06:56 AM   #592
Xpress's Avatar
The T3/T3'11 front rear arm mounts are not "inline" with the bulkheads. The T3 has more built in toe than the older platforms.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 12-06-2010, 08:25 AM   #593
RevMaxx's Avatar
i drilled some notches all around the case where the thick plastic material is on, as well as quite a number small hole cut-outs on the plastic wall and added epoxy material in those voids to get a good grip on the diff case, the epoxy also engulfed the pulley plastic so i hope it'll hold...
still not sure how this though... only tests will tell..
Old 12-06-2010, 12:48 PM   #594
Drew Ellis's Avatar
Hey guys, I am needing to know all team drivers that are planning on attending the Snowbirds. Team RCA/Xray will have limited pit spots. Just trying to put down whos coming an would like to pit with us. Will do my best to get everyone pitted. But right now I need to know who is coming and how many pit spots we get.
Post here or email me [email protected]
Thanks Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 12-06-2010, 01:08 PM   #595
Johnny Wishbone's Avatar
Like Express said the "11 has more built in rear toe. Just add the spacers you need to free up your bind issue and then run the -.75 hexes, that should get you close on the width.
Gary Lanzer
Old 12-06-2010, 03:06 PM   #596
M-Technic's Avatar
Trader Rating: 15 (100%+)
Thanks Drew
I will be there.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-06-2010, 03:53 PM   #597
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
hi bud thanks for putting pic up looks very clean any chance on taking the cover off the pulley to see how it stays in one place without moving underpower.cheers
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 12-14-2010, 08:32 AM   #598
Drew Ellis's Avatar
How's everything been going?
Thanks Drew
Old 12-14-2010, 08:51 AM   #599
ByteStream's Avatar
How is that Xray Shock Building Video coming along? Any update when it might be available?
ByteStream is offline   Reply With Quote
Old 12-14-2010, 09:21 AM   #600
Drew Ellis's Avatar
Well the first one I shot myself with Paul and it was kinda shot like the Blair Witch movie. So we are going to have someone thats better then I am with a camera. We have had a crazy schulde going on so we are hoping to have it at the first of the year with a few other types of video's also.
Sorry just want to make sure its really good and has as much info in there as we can.
Thanks Drew
1/12 forum ovalnator Electric On-Road 46188 Today 08:58 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Ask Mike Blackstock Trinity ,Rcamerica, Team Xray Edition.. Mike Blackstock Electric On-Road 225 12-30-2006 06:57 AM
RCAmerica/ Xray / Hudy Mark G Electric On-Road 10 03-15-2006 09:17 PM
RCAMERICA Live Race Coverage @ The Dirt Nitro Challange David Joor Electric Off-Road 40 03-03-2005 12:33 AM
