Old 12-02-2010, 11:53 AM   #556
Drew Ellis's Avatar
Originally Posted by Catch-Air View Post
I recently purchased the following setup stations: 1/8 scale on-road, 1/8 scale off-road, and 1/12 - 1/10 pan car. The pan car setup station came with thumb screws for screwing the uprights together. Can I buy the thumb screws separatly for the other setup stations? Also, do you make thumb screws for the 1/8 scale off-road wheel nuts?
Thanks,
Jim
Yes, the part number is 108060 for the thumb screws. For the 1/8 wheel nuts its 108860.
Thanks Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 12-02-2010, 12:30 PM   #557
Drew Ellis's Avatar
Originally Posted by PDX-Spike View Post
Drew,
I got a couple of sets of 30 8306 ALU shock absorber set, short.
The documentation says the piston hole sizes are 1.1, 1.2 and 1.3 mm. In reality, the numbers on the pistons are 1 and 0, 1 and 1, 1 and 2.
I am assuming that 1 and 0 is 1.1, 1 and 1 is 1.2 and 1 and 2 is 1.3. Please verify is this is correct.
I think it is supposed to read that the pistons are 1.0mm, 1.1mm, 1.2mm. Not sure as I have never ran these pistons but thats what I remember them being.
Originally Posted by BlackedOutREVO View Post
Drew
Whats the latest on CVD length? Still 50's all round or just in the rear on the 2011 t3?
Right now I am running the 52's in the front and the 50's in the rear.
Thanks Drew
Old 12-02-2010, 01:24 PM   #558
StevenOlsen's Avatar
Originally Posted by M-Technic View Post
What would happen to the camber links if you swapped which side the L1 and L2 roll center holders were on?
you would get a little higher position a little like the H links
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 12-02-2010, 01:31 PM   #559
M-Technic's Avatar
Trader Rating: 15 (100%+)
What about if they were in the low position... a little bit lower or a little bit higher than if they were on the normal side and in the low position?
Thanks!
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-02-2010, 01:55 PM   #560
Thanks!
higher, but lower the the std. L in the high pistion
Steven Olsen
Old 12-02-2010, 02:01 PM   #561
Johnny Wishbone's Avatar
Quite a bit, it really changes the angle of the link. Like I said, with the H and L going from upper to lower inner setting and then swapping sides you get 4 different settings, just enough to keep you busy. Low inner links reversed seem to make the car a nicer drive for my setup right now.
Gary Lanzer
Old 12-02-2010, 02:07 PM   #562
drsfly's Avatar
Well I will take a shot at this and at least start some thinking.
If the L1&2 eccentrics are in the lower holes then they are actually lower and shorter. Because you have to turn them almost 90 degrees to get them into the bottom hole it turns the eccentric vertical almost. The centerline would be below the original position.
So the H's on the correct side but in lower holes would make the links longer by the amount of the eccentric offset and lower thgan the standard position.
On the opposite sides in the lower holes then that would be reversed.
So two sets of each and you would have 16 different possible positions.
Later,
Darrald
drsfly is offline   Reply With Quote
Old 12-02-2010, 02:10 PM   #563
M-Technic's Avatar
Wow, this is getting intense!
L1 and L2 reversed on the car and put in the long/low hole = somewhere between the regular long/high and long/low positions as far as link angle goes?
Old 12-02-2010, 02:52 PM   #564
Steven Olsen
Old 12-02-2010, 08:03 PM   #565
RCknight's Avatar
Drew why are you using 50mm in the rear? Is that with a ball diff or gear diff? With a ball diff my 52mm won't work?
Thanks Drew
RCknight is offline   Reply With Quote
Old 12-02-2010, 09:25 PM   #566
Drew Ellis's Avatar
I have been running a gear diff and the 50's allow for more travel with the gear diff. I had the 52's in with the ball diff and had no problem with them. The best thing is to post a pic so I (we) can see whats going on. Are you sure your bones are not binding up there self meaning are they free when you have just the whole cv out in your hand. I have seen some barrels bind up in the cvd when it is all together.
Thanks Drew
Old 12-02-2010, 09:28 PM   #567
RCknight's Avatar
I sent pics to EAMotorsports. Maybe he can post them here, but I've checked everything. Still bind against the diff.
Old 12-03-2010, 06:51 PM   #568
Chris Adams's Avatar
Originally Posted by JACK HAMMER View Post
Hey drew can I purchase parts for my xray t1fk04 from rc america ? I love this car
Mikeshobbyshop.com
They have a ton of older fk parts that has been sitting there for years. Feel free to give them a call. Im sure they would ship it out to you.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 12-03-2010, 09:26 PM   #569
Phil Trotta's Avatar
Yes I think we still have some of the main parts in stock. Just give RCAmerica a call @214-744-2400 or email me with the parts you are looking for [email protected].
Thanks Drew
thanks drew...................appreciated
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 12-03-2010, 10:11 PM   #570
Still Bill's Avatar
How about a lot like the H links.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46189 Today 08:13 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Ask Mike Blackstock Trinity ,Rcamerica, Team Xray Edition.. Mike Blackstock Electric On-Road 225 12-30-2006 06:57 AM
RCAmerica/ Xray / Hudy Mark G Electric On-Road 10 03-15-2006 09:17 PM
RCAMERICA Live Race Coverage @ The Dirt Nitro Challange David Joor Electric Off-Road 40 03-03-2005 12:33 AM
