Old 11-29-2010, 04:48 PM   #511
StevenOlsen's Avatar
Originally Posted by jammincrtjames View Post
Has anybody tried getting up and down the gearing range needed for 17.5 stock and 17.5 open without changing the spur? Is it possible to go from 4.0 to 6.4 without a spur change. I thought I would ask before I start changing spurs/pinions around.
try with a 100-104 tooth spur
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 11-29-2010, 06:44 PM   #512
RevMaxx's Avatar
Send a message via MSN to RevMaxx
Originally Posted by Mini-Mod View Post
Here's my custom made gear diff my dad made from the NT1 that I use in my T3.
did my own diff gear DIY with an NT1, similar config as this. mine sucks on "looks factor" coz the screws i use to fix the pulley to the diff case protrodes, but it has run about 500 laps and is holding quite well. still looks like when i first mounted it.
but i've seen a much nicer config with the NT1 diff. they place the T3 pulley on the other side of the diff, really looks real clean, like molded parts.
RevMaxx is offline   Reply With Quote
Old 11-29-2010, 08:28 PM   #513
KevinHawk's Avatar
Originally Posted by andrewdoherty View Post
I can't help it if my parents are clarevoyant.
AWD
haha Chris yours would be "please don't hit me in the first corner" and Andrew's would be ....... um.. ... Carpet fuzz. I like the sound of that.
KevinHawk is offline   Reply With Quote
Old 11-29-2010, 10:10 PM   #514
Jim Frahm's Avatar
Trader Rating: 68 (100%+)
Send a message via Yahoo to Jim Frahm
Default Hudy setup station question
I recently purchased the following setup stations: 1/8 scale on-road, 1/8 scale off-road, and 1/12 - 1/10 pan car. The pan car setup station came with thumb screws for screwing the uprights together. Can I buy the thumb screws separatly for the other setup stations? Also, do you make thumb screws for the 1/8 scale off-road wheel nuts?
Thanks,
Jim
Serpent S411 ERYX, Reedy 25.5, FLOW
AE 12R5.2, Trinity 17.5, ORCA
Jim Frahm is offline   Reply With Quote
Old 11-30-2010, 12:56 AM   #515
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Could be worse, like "Batesy-Watesy"
Old 11-30-2010, 12:59 AM   #516
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
here is my DIY nt1 diff to me it looks a good job.I done slight mods so i could fit lighter out drive in as is very heavy with stock out drive the weight came in at 30gr with metal gears so i think that's as best you can get it without Capricorn gears.
RCAmerica/Xray,Hudy-img_0199.jpg
RCAmerica/Xray,Hudy-img_0200.jpg
RCAmerica/Xray,Hudy-img_0201.jpg
RCAmerica/Xray,Hudy-img_0202.jpg
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 11-30-2010, 01:04 AM   #517
Do you have any pics of where you attached the pulley to the NT1 case?
Old 11-30-2010, 03:32 AM   #518
RCknight's Avatar
All and all my kit went together perfect. I'm concerned about the rear cvds. They are too long and have no room for compression in the rear. Fronts seem fine. I'm running the spacers per the instructions.
RCknight is offline   Reply With Quote
Old 11-30-2010, 01:40 PM   #519
R Dodge's Avatar
Are you using the SpecR gear diff? I noticed the same thing with mine with the stock 52mm shafts. I switched to 50mm (which I preferred anyway) and had no issue.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 11-30-2010, 03:47 PM   #520
Johnny Wishbone's Avatar
Looks pretty good, the only difference in mine was that I used the big hole side covers, and sanded the center section so the cover could be removed with out unscrewing the gear from the center section. Good job though, told you it wasn't that tough.
Gary Lanzer
Old 11-30-2010, 04:41 PM   #521
KevinHawk's Avatar
haha exactly
Old 11-30-2010, 04:41 PM   #522
[QUOTE=P.I.M.P;8277241]here is my DIY nt1 diff to me it looks a good job.I done slight mods so i could fit lighter out drive in as is very heavy with stock out drive the weight came in at 30gr with metal gears so i think that's as best you can get it without Capricorn gears.
QUOTE]
Nice, are those the 3racing outdrives?
Looks like you machined inside the outdrive to fit the bigger Xray balls, how did you do it?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 11-30-2010, 05:22 PM   #523
RCknight's Avatar
No I'm using the ball diff. Seems the kit should be using 50mm shafts as the 52mm seem to bind using the suggested shims.
Old 11-30-2010, 05:53 PM   #524
R Dodge's Avatar
Interesting. Sorry I can't help, I've never run the 52mm shafts on the rear of my T3 so I have no experience with this issue. I'd assume the issue comes from the design change on the front mount of the rear arm causing the arms to be pulled in towards the diff. This is honestly the first I've heard of this issue but I don't know if that might just be because I don't keep up on the threads much, or if everyone else has quietly accepted it and switched to 50mm shafts. I'd figure the 52's should work though, since they are what comes with the kit...
Old 11-30-2010, 05:55 PM   #525
KHoff7's Avatar
How narrow is your rear track width? If you run the car really narrow or if you use too much camber the driveshafts will bind.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46189 Yesterday 08:13 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Ask Mike Blackstock Trinity ,Rcamerica, Team Xray Edition.. Mike Blackstock Electric On-Road 225 12-30-2006 06:57 AM
RCAmerica/ Xray / Hudy Mark G Electric On-Road 10 03-15-2006 09:17 PM
RCAMERICA Live Race Coverage @ The Dirt Nitro Challange David Joor Electric Off-Road 40 03-03-2005 12:33 AM
