Old 11-22-2010, 08:43 PM   #466
Originally Posted by Drew Ellis View Post
I heard people having problems with this, but I have been running the 52mm ECS's with 2.25 shims for width and have had no problems. I run the 50mm CVD's in the rear.
Thanks Drew
What about with the standard 1.5 shims at the front, can we still use the 52mm cvd? Thanks!
air jordan is offline   Reply With Quote
Old 11-22-2010, 09:10 PM   #467
Drew Ellis's Avatar
Not sure on that. I have been running the 2.25mm shims with the gear diff. I used to 1.5mm with the spool and that worked fine but have not ran that narrow with the gear diff.
Let us know what you find out.
Thanks Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 11-22-2010, 09:14 PM   #468
Drew Ellis's Avatar
Originally Posted by Mini-Mod View Post
Here's my custom made gear diff my dad made from the NT1 that I use in my T3.
Bro tell your Dad nice job one of the best I have seen. Would he make me one? Let me know and I will send the parts. Or atleast have him share how he did it.
Thanks Drew
Old 11-22-2010, 09:47 PM   #469
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
For realz. I really like the gear diffs but I refuse to run a leaking gear diff. I'd expect the NT1 modified gear diff doesn't leak? A post with pics and a parts run down (especially if it doesn't look hack like some i have seen) might tip the scales and get me walking the bins at RCA this week. Drew if you get the PN and assembly info and such pm me and I will get two of everything for you and me and send you one NICELY done.
AWD
Old 11-22-2010, 09:50 PM   #470
arn671's Avatar
Trader Rating: 15 (100%+)
Thanks Drew
I'm with Drew on this one-If your dad wants to sell these I'll gladly pay for one!
arn671 is offline   Reply With Quote
Old 11-23-2010, 01:54 AM   #471
mugler's Avatar
Thanks Drew
I see, thanks for the 411 and the tip. Just my opinion, but to skimp on such top priority item is not a good business decision as a lot of people will look elsewhere such the ta05 v2 R and such. Buying turnbuckles will eat into a lot of the saving right off the bat & defeat the budget purpose. The notching trick is a good "tie-over" option for those who buy the kit and then realize whats missing.
mugler is offline   Reply With Quote
Old 11-23-2010, 08:19 AM   #472
Drew Ellis's Avatar
No problem, I understand. But they had to save some money somewhere in the kit. The price is alot cheaper then the T3 or T3'11. If you search around turnbuckles are not to much meaning they don't have to be Xray's. I think you can find a set for the car for under $20. I know alot of people that have this car and are really happy they got.
Thanks Drew
Old 11-23-2010, 08:48 AM   #473
Send a message via AIM to jeff whiting
Looking at picture of T3R I do not see any squared sections on the turn buckle where a wrench can be used....is this realy the case and if so how are you supposed to make camber and toe adjustments on the set up board??
Thanks Drew
Good point Drew. We have 4 T3R’s and we really like them. They are very forgiving and have held up very well. We have added turnbuckles as we went and the price is still way under most kits that have less out of the box performance than the T3R. Plus, there is so much good information for the T3 line that as a person gets quicker you can add bits and pieces to the T3R to pick up its performance in certain conditions. In the end it's nice to have choices.
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 11-23-2010, 08:59 AM   #474
M-Technic's Avatar
Giddy like a school girl waiting for my T3 '11 to arrive this week.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 11-23-2010, 10:19 AM   #475
Johnny Wishbone's Avatar
Whats the big ring for beside the belt pulley? Just curious.
Gary Lanzer
Old 11-23-2010, 04:52 PM   #476
Mini-Mod's Avatar
Not sure. The diff is completely stock besides the mod of getting th pulley on the diff.
E.Albano
Yokomo / Hobbywing / JConcepts / A Main Performance Hobbies / Solaris Racing Products / ProTek RC / Schelle / Boom RC / TNP (TopNotchPaints)
Mini-Mod is offline   Reply With Quote
Old 11-23-2010, 10:00 PM   #477
I'm thinking the big ring to the right is what is left of the NT1 teeth after machining them?
Mini, would you show us what the gear side looks like with the cover off showing how/where the electric pulley was machined?
Old 11-24-2010, 10:42 AM   #478
JayL's Avatar
Here is the first link showing an nt1 diff in a t3
http://www.rctech.net/forum/7121865-post1660.html
we have all been doing this for awhile, with all the xray hop-ups it is one gram less than a spec-r
the t3 diff pulley gets the center cut out just leaving holes for the screws.
mini-mods dad has a sick way of using one of the pulleys for alittle more accuracy
JayL is offline   Reply With Quote
Old 11-24-2010, 08:02 PM   #479
PDX-Spike's Avatar
Default ALU Shock Pistons
Drew,
I got a couple of sets of 30 8306 ALU shock absorber set, short.
The documentation says the piston hole sizes are 1.1, 1.2 and 1.3 mm. In reality, the numbers on the pistons are 1 and 0, 1 and 1, 1 and 2.
I am assuming that 1 and 0 is 1.1, 1 and 1 is 1.2 and 1 and 2 is 1.3. Please verify is this is correct.
Roger Christal - Team Timezone (Hooligans), Rose City Scale Racing, ROAR Member until 9/16/2012
Support the locals: Timezone Raceway, Timezone II, R/C Plus, Portland RC Raceway
McKune Design, Slapmaster Tools, Houston's Engine Service
PDX-Spike is offline   Reply With Quote
Old 11-24-2010, 09:03 PM   #480
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Drew
Whats the latest on CVD length? Still 50's all round or just in the rear on the 2011 t3?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46184 Today 09:37 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Ask Mike Blackstock Trinity ,Rcamerica, Team Xray Edition.. Mike Blackstock Electric On-Road 225 12-30-2006 06:57 AM
RCAmerica/ Xray / Hudy Mark G Electric On-Road 10 03-15-2006 09:17 PM
RCAMERICA Live Race Coverage @ The Dirt Nitro Challange David Joor Electric Off-Road 40 03-03-2005 12:33 AM
