Old 11-05-2010, 09:24 PM   #376
Xpress's Avatar
Originally Posted by kobiwan View Post
Can someone please make a tutorial on how to bleed the shocks! Everytime I release the bottom cap and do what the instructions say I get air in the shock.
Are you pulling the shaft back down after you compress it? If you are that may how you're sucking air back into the shock body.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 11-05-2010, 11:19 PM   #377
Yes I am, becuase that's what it says to do in the manual. It says to very slowly push it in and then pull it back out. It even says to do it like 10 times to get 75% rebound, 15 times to get 50% rebound, etc. I give up.
Futaba 7PX---Xray T4 '18 ---R1 Wurks---EAMotorsports---Hobbywing
kobiwan is offline   Reply With Quote
Old 11-05-2010, 11:37 PM   #378
fullout's Avatar
Send a message via MSN to fullout
what i found to work very well is, hold the shock upside down with the bottom cap loose for a good five minutes. tighten it and check rebound if you want less rebound loosen the bottom cap again and hold shock uopside down till desired rebound is acheived. takes a bit of time but works well
fullout is offline   Reply With Quote
Old 11-05-2010, 11:47 PM   #379
Dave Bowser's Avatar
Trader Rating: 51 (100%+)
ok i hope this helps the way i have always done it is
step 1-fill shock with oil
step 2-move shock shaft up and down to move the air around
step 3-use shock pump to remove any air
step 4-put the shock membrane on top of the shock
step 5-put the shock eyelet on top of the membrane
step 6-put the orange shock nut over the eyelet and tighten it all the way down
step 7-loosen the bottom nut and pull it down so you can see the o-ring
step 8-push the shaft in about 80% and tighten the bottom nut at the same time
the further you push the shaft in the less rebound you will have so if you dont push the shaft in you will have 100% rebound and if you push it in all the way you will have 0% rebound
always tighten the bottom nut when the shaft is pushed in never pull it out and then tighten it
give that a try and lmk how it works out
RCAmerica, X-Ray, Hudy, Ko Propo, Protoform, PRS, Jaco, JConcepts, SXT, RC3 Grafix, Kool-Aid, P-Nut, NEXT, www.SuperiorHobbies.com
We're going to skate to one song and one song only!
Dave Bowser is offline   Reply With Quote
Old 11-06-2010, 05:18 AM   #380
DS Motorsport's Avatar
This is the way me and most other Xray team drivers build their shocks:
The method is showed with a different brand of shocks (Capricorn, perfect shocks might want to try them) but the principle still applies on the Xray shocks.
First, never touch the bottom cap again! It will only cause air to enter the shock and makes building the shocks a pain.
Step 1, Shockabsorbers.
The quality of the shocks is amazing, standard they come with TiNi coated shafts and a mono O-ring design. The pistons and shaft guide are machined nylon which makes for the smoothest shock I ever build.
All shocks were perfectly matched in bound and rebound on the first try.
Bleeding the shocks with a vacuum pump, this makes for a perfect air-free shock.
Meanwhile I engraved the shockcaps, this makes it easy to have the same shock on the same corner of the car every time.
Now the important bit:
I used the following method while building the shocks:
1. Put a 4mm spacer between the damperhousing and the balljoint, this sets the amount of rebound. A small spacer will mean less rebound, a big spacer more rebound.
2. While pushing the shockshaft into the housing( with the spacer in place) place the membrane on top of the shockhousing. All excess oil will come out of the shock.
Make sure the membrane sits flush with the shock housing, if you have the old style membranes (ditch them and get the new style asap) and they have been sitting in the shock this can be hard. The Xray membranes expand a lot, I uses to replace them about every month or for every big event. It gives the car more overall traction.
3. Screw the cap on top of the housing.
4. Check if both front and both rear dampers are equal, this is very important in terms of car balance.
I've build the dampers with 550cst in the front and 450cst in the rear, used 3 holed pistons all around.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 11-06-2010, 08:04 AM   #381
Where can I get one of those shock pumps? Speedtech RC and Ampdraw is the only places I saw them and they are out of stock.
Old 11-06-2010, 08:39 AM   #382
Trader Rating: 47 (100%+)
Send a message via AIM to smitty2802
http://www.nexusracing.com/product_i...oducts_id=3546
Heres a Tamiya pump from nexus... $$$
but you can look and see if you want to spend your money on that or not.
-DC-
~Jconcepts~EA Motorsports~
smitty2802 is offline   Reply With Quote
Old 11-06-2010, 09:09 AM   #383
Regional Moderator
CarbonJoe's Avatar
Something a little cheaper. I made an insert for the jar out of plexiglass to hold the shocks. Works great.
http://www.goodmans.net/item.asp?n=V...883450&sc=FRGL
You could always try the local Bed, Bath, and Beyond, which is where I got mine. The pump part is about $10. I got a jar that is round off the web somewhere. Search for Vacu Vin Coffee Saver.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-06-2010, 06:37 PM   #384
Drew Ellis's Avatar
Sorry DS but I dont know what Factory guys you have been around, but Ralph Burch, Paul Lemiuex and myself do not build are shocks like that. Are way is much easier and it seems to work pretty well.
Guys I will have a video of Paul Lemiuex building shock on www.prolevelrc.com within the next 2 weeks.
Thanks Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 11-06-2010, 07:20 PM   #385
Thanks Drew
Well ok, methods can differ.
The method I described is pretty much the same method Jilles Groskamp (Former Xray driver ) showed in the Redrc video. It allows me to build a perfect set of shocks within 15 minutes, something which is impossible with the way Xray does it in the manual.
But I'm interested to see a method which is much easier, drivers have been promised a video for quite some time now.
P1-RC.com
Old 11-06-2010, 08:30 PM   #386
Drew Ellis's Avatar
Yes I know it has been taken awhile, but we are wanting to make sure the video is done really well. I will have it up soon in about 2 weeks it will probley be about 20 mins long and Paul will go over everything in the build.
Thanks Drew
Old 11-07-2010, 06:58 AM   #387
RCknight's Avatar
Drew any word on the next shipment and some up coming option goodies for the T3'11?
RCknight is offline   Reply With Quote
Old 11-07-2010, 07:05 AM   #388
Drew Ellis's Avatar
The shipment should be showing up in the middle to end of November, they are getting it ready now should be shipping soon. We have been testing some new option's should no more soon.
Thanks Drew
Old 11-07-2010, 04:40 PM   #389
RCknight's Avatar
Sweet, glad to read this. Can you tell us what options Xray has in mind? I hope with all the people opting for other shocks Xray will have some new designed ones soon. I only buy Xray options since I know Xray thoroughly tests them and the materials are top notch.
Thanks Drew
Old 11-07-2010, 04:54 PM   #390
HarryLeach's Avatar
Send a message via AIM to HarryLeach
I really hope it's closer to the middle, as in 7-10 days from now. I have to go overseas for work again soon, and would love to bring a new car along to build during the boring times.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46181 Yesterday 02:42 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Ask Mike Blackstock Trinity ,Rcamerica, Team Xray Edition.. Mike Blackstock Electric On-Road 225 12-30-2006 06:57 AM
RCAmerica/ Xray / Hudy Mark G Electric On-Road 10 03-15-2006 09:17 PM
RCAMERICA Live Race Coverage @ The Dirt Nitro Challange David Joor Electric Off-Road 40 03-03-2005 12:33 AM
