Old 11-03-2010, 07:00 PM   #361
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 11-03-2010, 07:12 PM   #362
jammincrtjames's Avatar
Originally Posted by Drew Ellis View Post
Yes that is how I am running them. And Martin says its wrong. The H stands for higher link but in the spot I have it. The link is lower. Hard to explain on here. You can run the links Land H's were ever you want. I know its tricky as for me I am still try to figure it all out, but thats were I put them and it seemed to work really well on carpet.
Thanks Drew
I ran the H's tonight and it did work well down and in on the front end.
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 11-03-2010, 07:16 PM   #363
Here it is guys. Took the pic with my phone, think it will be clear enough. The gridding on my bulkhead was from testing the hill billy link.
Thanks Drew
I did not see that before. That is how I ran them. How many shims did you run on the outside link? The car had a lot of steering. How can I smooth that out? Would running a wider front track width smooth it out?
Old 11-03-2010, 07:27 PM   #364
Drew Ellis's Avatar
2mm is what I ran. Check out my set up from the Halloween Race on www.teamxray.com under Andrew Ellis. I think playing with the ackerman is what you need to do. That will help with making the car smooth out.
Thanks Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 11-03-2010, 07:33 PM   #365
Thanks Drew
One more question. Im running 1mm shim on the ackerman. Where would you start? 2mm?
Old 11-03-2010, 08:52 PM   #366
Drew Ellis's Avatar
For your ackerman your front wheelbase plays into that. So I am long front wheelbase with 4mm shims for ackerman.
My setup was really good at the Halloween Race I would try the whole setup and see what you think, maybe just some fine tuning from there to suit your driving.
Thanks Drew
Old 11-03-2010, 10:05 PM   #367
TimmyMontoya's Avatar
Default Shock shims
What effect does shiming the front or rear shocks outward away from the shock tower have? Thanks
TimmyMontoya is offline   Reply With Quote
Old 11-03-2010, 10:48 PM   #368
Still Bill's Avatar
When moving the arms forward or rearward on the chassis for a setup, I make them vertical again (from the side view) by shimming the shocks at either the tower (top) or arms (bottom). Whichever end requires it. This eliminates the added angles created by moving the arms.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 11-04-2010, 04:04 PM   #369
Thanks Drew
Does this work with the L's also ?
slashman4x4 is offline   Reply With Quote
Old 11-04-2010, 04:39 PM   #370
yumlailai's Avatar
Just wondering what is the difference between a 409 and 407 Ko receiver. I have a EX-10 Eurus which comes with a 409 receiver. Just wondering if i can go for 407 since they are cheaper. Is there any performance gain on 409 receivers?
yumlailai is offline   Reply With Quote
Old 11-04-2010, 07:05 PM   #371
Drew Ellis's Avatar
Yes you can run them in all 4 spots. The L's to what I understand will be at a higher point then the H's in that same spot.
I think the 407's will work, but the 409's are faster with the radio system. I will try to get Robert from KoPropo to better supply us with some info. From what I understand the radio system has different speeds that you can choose how fast the radio responds to the rx. With the 409 you can have it as fast as it will allow. With the 407 it will limit the speed.
Hope that helps.
Thanks Drew
Old 11-04-2010, 10:26 PM   #372
ByteStream's Avatar
Default Setup Sheet Question
On the setup sheet for the T3, there is a measurement that I can't quite figure out .. on top of the sheet where it specifies caster, ride height, etc.
On either side of the word 'wheelbase/mm' there are some checkboxes,
0 - 1 - 1 for the front and 2 - 1 - 0 for the rear, which are checked for certail setups, what do these stand for?
If this is for wheelbase, and the checkboxes are for shims, I would have thought you had 5mm to play with, 2 + 2 + 1 shims in any combination.
ByteStream is offline   Reply With Quote
Old 11-04-2010, 11:29 PM   #373
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
The easiest way to under stand those boxes is like this. The set up sheet is asking "How many shims are you using in front of the arm?"
Old 11-05-2010, 09:36 AM   #374
yumlailai's Avatar
Hope that helps.
Thanks Drew[/QUOTE]
If this is the case, i will go with 409
Thank you
Old 11-05-2010, 08:05 PM   #375
Can someone please make a tutorial on how to bleed the shocks! Everytime I release the bottom cap and do what the instructions say I get air in the shock.
Futaba 7PX---Xray T4 '18 ---R1 Wurks---EAMotorsports---Hobbywing
kobiwan is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46185 Today 11:05 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Ask Mike Blackstock Trinity ,Rcamerica, Team Xray Edition.. Mike Blackstock Electric On-Road 225 12-30-2006 06:57 AM
RCAmerica/ Xray / Hudy Mark G Electric On-Road 10 03-15-2006 09:17 PM
RCAMERICA Live Race Coverage @ The Dirt Nitro Challange David Joor Electric Off-Road 40 03-03-2005 12:33 AM
