Old 10-11-2010, 08:42 PM   #196
Regional Moderator
CarbonJoe's Avatar
Someone in this thread would probably expect Xray to fly Drew around the country, building T3 shocks for every customer (all included in the price of the kit, or course). Anything else and the new kits are a ripoff.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-11-2010, 08:51 PM   #197
Chaz955i's Avatar
Too bad for you Carbon Joe. You clearly don't understand marketing or value. Spend the next 20 years living in your parent's basement playing World of Warcraft and spamming threads with nonsense and you might start to get it. Think I might dump the Corally and pony up for a T3 just because I feel bad for what these poor X-Ray folks have to endure....and the cars look cool so they must be faster.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 10-11-2010, 09:11 PM   #198
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Bonadona View Post
Drew, thanks for the help with my shocks this weekend. You were right about how easy it is using your method. I think if you do post a video on how to build and bleed shocks it will really help people having trouble getting them correct.
Thanks again,
Brian Bonadona
+1
It was a great race and in large part due to Xray's awesome support and Drew's and EA's help. I'll be attending as many Xray challenges as I can from here on out.
Old 10-11-2010, 10:18 PM   #199
Send a message via AIM to jeff whiting
Originally Posted by LThompson37 View Post
Thanks to Drew and EA for the help this past weekend with my car and ESC. I could have used some more luck in the main, but after qualifying 3rd in 17.5 I would have to say it was a good weekend. Also thanks to RC America for supporting local racing and coming to Memphis, look forward to doing it again soon.
Lee
I totally agree with you Lee. Drew and EA were a hugh help at the Xray Challenge in Memphis. Thanks guys.
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 10-12-2010, 08:42 AM   #200
Drew Ellis's Avatar
Thanks guys. The race was a really big hit. I feel like we helped alot of folks down there.
Brian, we will get working on the shock building video soon, but I am glad you got to see how easy they are.
I will be getting the race report and pics up soon on www.teamxray.com
Thanks Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 10-12-2010, 11:52 AM   #201
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by mackin View Post
Does anybody know how CRC side springs relate to the side springs on the x10. Also what is the center spring rated at?
thanks
chuck
Hey Chuck,
I think the red springs are a little stiffer than the ones that come on the kit. I usually use AE golds or Blues on my car. The center spring is rated WAY Too soft. We have tested new springs that seem to be working very well and I think are going into production any day now if not already.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-12-2010, 12:14 PM   #202
Drew Ellis's Avatar
Originally Posted by JayL View Post
What is the difference between the roll center mounts in the t3r vs the t3 L ones? and does rotating the t3r ones do anything?
Sorry about taken so long to answer this.
The difference is the L1 nd L2 that come in the T3 kit, they are longer.
Yes you can rotate the ones that come with the T3R. Its like having 4 camber link holes on the shock tower. You can have a long upper link, long lower link, short upper link, and a short lower link. Which all help you with roll center and camber gain.
Hope that helps.
Thanks Drew
Old 10-13-2010, 06:13 AM   #203
EA, I ended up with white CRC springs on the sides and heavy oil in the side shock. I also have a CRC center shock and #50 front springs to try, kind of what Monte ran in Vegas. Entry into high speed corners is good, but still pushes in low speed turns, Small tires are the way to go and Jack is much better than Sticky Fingers. Any chance of any shock springs showing up at The Gate next weekend?
thanks
chuck
mackin is offline   Reply With Quote
Old 10-13-2010, 11:24 AM   #204
Fred Hubbard's Avatar
Thanks again,
Brian Bonadona
Below is the method that I have used for months now to set near 0 rebound when using the Aluminum shocks.
1) Use a #56 or #57 drill bit and drill a hole in the shock cap.
2) I use an air removal tool to ensure there are no air bubbles in the shock.
3) Assemble the shock with the shaft fully extended and the shaft should be facing downward.
4) Invert the shock so that the shaft is on top and unscrew the cap 3 or 4 times, be careful not to unscrew it too much.
5) Push the shaft in and hold it then screw the cap back on. Excess oil should leak from the oil in the cap.
6) Push the shaft in and pull it out a few times and there should now be little rebound.
Initially when I developed this procedure I used to repeat these steps 2 times to be safe and then I soon noticed that 1 time was enough. It's near impossible to get 0 rebound so I always account for there being 10%.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 10-13-2010, 12:05 PM   #205
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
I always used a method similar to that on Tamiya shocks. I just used a body reamer to make a tiny hole in the cap, works great for similar rebound.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 10-13-2010, 01:06 PM   #206
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Just wanted to say thanks to Drew, EA, and RCAmerica for putting on the XRay Challenge races and for giving back to the racers the way you guys do...had an awesome time in Memphis and can't wait to try out Drew's shock building tips on my 2011 spec when it arrives! Thanks again guys!
-rocky b
flatspunout is offline   Reply With Quote
Old 10-13-2010, 01:13 PM   #207
Team EAM
thanks
chuck
Hey Chuck,
Go lighter on the side shock oil as that will make the car transfer weight more. Running more camber will def give you more steering. I think on the gauges monti had around 3 degrees. Also I would try long AE front .18 springs. That will make the car turn more off power as well. The long .18 are in between short .18 and short .20 plus they dont give up any.
EA
Contact Us
Old 10-13-2010, 08:09 PM   #208
Originally Posted by Drew Ellis View Post
Xray Challange's
Guys were are looking at doing alot more Xray Challange's in 2011. If you have a track and want us to come race there with you. Please give me some info. We are trying to get this all setup for next year.
We are looking for 2 tracks in the Midwest, 2 tracks on Westcoast and 2 tracks on Eastcoast.
Any info would be great.
You can run any car in the race. This is not only for Xray's but anybody. The whole idea is to promote racing as a whole.
Let me know.
Thanks Drew
Hey Drew, How about Jackson RC, here in N.J.
You can ask Paul.L. he's been here racing.
Track is run and maintained by racers that just want to have fun.
We've held multi 100+ entries races, and would love to hold a Xray Challenge.By the way it would be a good tuneup for the paved nats that we just got awarded.
Here's a picture of the track
If your looking for a indoor track also how about Horsham Raceway?.
Track is 48x100 smooth.Track is located in Horsham,PA which is just north of Philly.
Let me know how we can help
Jackson RC Raceway, Home of the 2011 Paved On Road Nats!
Horsham RC Raceway,Home of the 2013 and 2015 Carpet On Road Nats!
Awesomatix USA/ Side Piece Racing / TQ Wire / CR Graphics / R1 Wurks / LRP /Jackson RC Raceway / Horsham RC Raceway/Brownies Hobbies
Al Sodano is offline   Reply With Quote
Old 10-13-2010, 08:24 PM   #209
Factory Seal's Avatar
Trader Rating: 29 (100%+)
Drew,nice to finally get to meet you..........thank you very much for what you do for the SPORT we all love.............to expensive to be called a hobby...LOL!!
Anyway,everyone here in Mempho sure did appreciate you guys help.....
Props to R.C. America for everything they did to make the Race a success......especially sending you!...And "YOUR" TOOLS!..LOL!..what a Great company......Please tell all the people there thanks.......
Thanks E.A. and anyone else that helped anyone out ......i was a little buzy to see everything going on.........
That was some great Racing from the guys in 17.5 and VTA.........What about Loran smokin all the nitro guys.....Even Daddy.....Sorry,Jeff!!.......LOL!!
Looking forward to next years Xray Challenge Racing series........
holla at you later when my tools come in to build the nitro car........
Later Bro,
Donnie.
My club.....msra-racing.com
Factory Seal is offline   Reply With Quote
Old 10-14-2010, 12:39 AM   #210
RCknight's Avatar
Wow! Nice track...that looks like high speed fun.
RCknight is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46169 Today 04:54 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Ask Mike Blackstock Trinity ,Rcamerica, Team Xray Edition.. Mike Blackstock Electric On-Road 225 12-30-2006 06:57 AM
RCAmerica/ Xray / Hudy Mark G Electric On-Road 10 03-15-2006 09:17 PM
RCAMERICA Live Race Coverage @ The Dirt Nitro Challange David Joor Electric Off-Road 40 03-03-2005 12:33 AM
