Loose Rear need tuning tips >
Old 06-26-2004, 01:36 PM
  #16
you could lessen dual rates or stiffen front,soften rear.
if its on power oversteer increase front droop.
if its going into a corner off power try thicker shock oil in front.
trf racer is offline
Old 06-27-2004, 03:58 AM
  #17
Lonestar's Avatar
Trader Rating: 14 (100%+)
Originally posted by fatdoggy
Loose is fast sometimes. Maybe the setup is too agressive for you.
Same here... top drivers' setups might not always be the right place to start from!
Good luck
Paul
Hey Mark, 'sup? Giving setup tips now, eh? Take care, Paul
Lonestar is offline
Old 06-27-2004, 08:26 AM
  #18
TimPotter's Avatar
Good Point, but htat base setup Adrian has is pretty easy to drive, Roush, you may have something binding or loose, Compare your car to Adrians at the track.
TimPotter is offline
