Motor Spacer, Who Has That? >
Old 09-20-2010, 09:32 PM
Barry White's Avatar
Default Motor Spacer, Who Has That?
Can anyone help me with this. I'd like to be able to move my motor a few mm to play with weight distribution.
Tamiya has this but it's too thick to my likings:
Square have this but I don't want the radiator:
Barry White is offline
Old 09-20-2010, 10:22 PM
locked's Avatar
why not just use 2 washers with a >3 mm hole?
Maybe some suspension mount spacers like these?
http://www.amainhobbies.com/product_...-Spacer-Set-12
locked is offline
Old 09-21-2010, 05:12 AM
I suspect the motor mount bolts would bend in a hard crash if doing that since the whole mounting surface of the motor is not supported. You could play around with washers to get the right balance you want and then get a local machine shop to make you a plate of the right thickness out of aluminium. Just leave a motor can with them for them to get the right spacing of all the holes needed and any small machine shop should be able to bang one out in no time.
spongerX is offline
Old 09-21-2010, 05:47 AM
Thank you for making my point clear
Old 09-21-2010, 09:13 AM
Take a look at the fiber motor spacer that comes with the Tamyia M-03, M-05cars.
You could stack a couple of them to get your different widths.
Bob Oaks
bob o is offline
Old 09-21-2010, 09:19 AM
heretic's Avatar
The tamiya one you show seems light... you could sand it carefully on 1000 sand paper to remove the extra thickness.
I bought a RW spacer a few years ago, but it was maybe 3mm thick which seems to much for you. A bit on the heavy side, too, which is a bit annoying when you are trying to remove weight from that very location of the car by moving the motor away.
heretic is offline
Old 09-21-2010, 10:30 AM
http://www3.towerhobbies.com/cgi-bin...?&I=LXWHZ3&P=7
Serzoni is offline
Old 09-21-2010, 10:52 AM
Regional Moderator
CarbonJoe's Avatar
You could just go to a hardware store like Home Depot in the US (if those exist in Belgium), and get something called a fender washer. They come in various diameters, and then you could drill your own motor screw holes.
Something like this:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
CarbonJoe is offline
Old 09-21-2010, 10:55 AM
FREAKAH's Avatar
You could get a 1 1/2" hole saw and cut out discs from aluminum sheets of different thicknesses. I think Home Depot has different thicknesses of anodized aluminum sheet.
FREAKAH is offline
Old 09-21-2010, 10:58 AM
corallyman's Avatar
Trader Rating: 101 (100%+)
Associated used to sell a motor spacer. My guess is that it was about 2mm or 3mm thick and the full size diameter needed to support the motor. Maybe check some place like tower or stormer hobbies. I think this is what you would want.
Steve
corallyman is offline
Old 09-22-2010, 11:06 PM
rough512's Avatar
Yeah lap it down to your desired thickness. Use lower grit to start, then finish with 1000 then 2000 for mirror finish. Those ribbings will look good; silver on blue background
rough512 is offline
