Old 06-24-2004, 10:05 PM   #1
Switch Blade's Avatar
Send a message via AIM to Switch Blade
Default What high end stick radio's are on the market?
THe only one I know of is the KO Vantage II(i think thats the name). I believe there is an Airtronics one, but am not sure. I am looking into getting one, and would like to know the choices there are out there for stick radios.
College
Switch Blade is offline   Reply With Quote
Old 06-24-2004, 10:08 PM   #2
CRASH's Avatar
Trader Rating: 26 (100%+)
Default KO PROPO
KO PROPO
Airtronics
Later,
CRASH is offline   Reply With Quote
Old 06-24-2004, 10:11 PM   #3
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
I'm running the KO Propo Vantage 2, very good, very programmable does take some tweaking and the instructions are iffy. I think they have a new model now and you will be lucky to find someone who will seel you one AND it will be damned expensive. Was a good upgrade from my old exerd though, a few things I would like though, tension adjustability and to be able to rotate the sticks a little (slightly different angle).
crimson eagle is offline   Reply With Quote
Old 06-24-2004, 10:13 PM   #4
that airtronics looks very nice, im thinking it is quite expensive though
College
Old 06-24-2004, 10:15 PM   #5
Thanks for the links Crash......the Ko looks very nice also....
College
Old 06-24-2004, 10:26 PM   #6
Sorry of all of the multiple posts, but for the KO PROPO - Vantage ESPRIT II Type R it is only 299.99, right around the price of the Futaba 3pk and other radios.....and all of those fetures, it sounds like the radio to last a life time...how easy is it to reach menu to menu on Ko radios, becasue I have heard that they arent the easiest..and only in 27mhz...idk, that can be good and bad.
Ill shut up now
College
Old 06-24-2004, 11:01 PM   #7
JimmyMac's Avatar
The Airtronics/Sanwa version is about the same price as the M8 radios. They even sold them stateside at one time. So you might beable to find one around. It's basically an M8 radio with stick controls instead of wheel and trigger. You get the same big screen and all.
Definately can't go wrong with the KO though...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-25-2004, 01:18 AM   #8
sosidge's Avatar
Futaba 3VC is a great stick radio. New HRS version should be available soon. Availability in the States is not a question I can answer...
Old 06-25-2004, 03:22 AM   #9
The 3VC is very good, has slightly more features than the old Futaba 3PJS. If there is new HRS version on the way my old one is for sale.
andsetinn is offline   Reply With Quote
Old 06-25-2004, 03:24 AM   #10
Cole Trickle's Avatar
I'm using a KO Presto, I find it's very easy to use. After reading the manual once, I dont need it anymore.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 06-25-2004, 04:28 AM   #11
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
[QUOTE]Originally posted by KilRuf
[B]The Airtronics/Sanwa version is about the same price as the M8 radios. They even sold them stateside at one time. So you might beable to find one around. It's basically an M8 radio with stick controls instead of wheel and trigger. You get the same big screen and all.
the sanwa version is called the Super Exzes, functions are the same as the m8, menu is easy to access. with this stick radio, you can rotate the 2 stick's travel axis to suit your finger's movements so its more comfortable.
the latest from KO is the Vantage Type R, while Futaba will have the 3VC Super out pretty soon....
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 06-25-2004, 09:30 AM   #12
The 3VC can be used with the synthesized transmitting modules from Hitec and Futaba.
Old 06-25-2004, 10:38 AM   #13
Hmmm...all of those seem like excelent radios, I guess the deciding factor would be which one is easiest to get. Does anyone have any idea where I can these radios?...even if they are from an over sea's shop.
College
Old 06-25-2004, 12:27 PM   #14
Dont forget the grip test !
As an example, I felt in love with the KO Mars, when I first saw it. But when I got in my hand, it was counted out in a second - way too small for my hand.
Old 06-25-2004, 03:45 PM   #15
Sanwa (Airtronics) Super Exzes is a great stick radio, very comfortable, easy to program thanks to the big screen.
The radio quality is also excellent,
You won't be deceived.
http://www.airtronics.net/super_exzes.htm
Ralf is offline   Reply With Quote
wttf high end stick radio party_wagon R/C Items: Wanted to Buy 0 07-24-2008 11:57 PM
wtb high end stick radio Ophidian R/C Items: Wanted to Buy 0 06-06-2008 03:43 PM
wtb high end stick radio party_wagon R/C Items: Wanted to Buy 1 12-22-2007 07:38 PM
(WTA)3PKS PCM RX brand new market price in market now. sangyi41 Malaysian R/C Racers 0 03-20-2007 12:13 PM
High end stick radio racenut123 R/C Items: Wanted to Buy 0 07-11-2003 11:52 PM
