Old 02-09-2011, 12:48 AM   #1396
Cribbin's Avatar
Originally Posted by CraigM View Post
Don't forget belts, the xray belts wear out pretty quickly
so my car has belts almost 18 months old. if theyre wearing then theyre too tight
Bro-Kin Racing Group
X-Ray T3
X-Ray T2 '007
Castle Hill Raceway
Futaba LRP Tekin
Cribbin is offline   Reply With Quote
Old 02-09-2011, 07:50 AM   #1397
Fred Hubbard's Avatar
Originally Posted by EAMotorsports View Post
They clamps and weights were not in this order is what I was told last week when I called as soon as it showed up. They wont show up on backorder yet as they are not in the system yet since they have not had them.
Sorry
EA
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 02-09-2011, 08:26 AM   #1398
I am about 2 weeks away from ordering my 2011, I found some Spec R gear Diffs (part number SPR009-XR) they specify that a 50mm rear universal shaft must be used..... The car comes with 52mm right?
Murray is offline   Reply With Quote
Old 02-09-2011, 08:27 AM   #1399
Correct the car comes with 52's. You can use 52's if you use an additional 1.5mm shim between all four suspension mounts, naturally it will change the shock geometry and track width.
Old 02-09-2011, 08:50 AM   #1400
LowBoost's Avatar
Trader Rating: 63 (100%+)
Mine are on their way and should be delivered Friday.
Is this Spec-R diff an option for T3 (2011) or is this the NT1 diff that is being installed to T3s, therefore the need of 50mm rear drive-shafts?
Are there any other parts/modifications I should be aware of that will benefit me? I will be running asphalt and parking lots. (No bashing of course)
LowBoost is offline   Reply With Quote
Old 02-09-2011, 08:55 AM   #1401
ok, thanks.
Old 02-09-2011, 09:11 AM   #1402
dragont's Avatar
i dont know if this already been asked and posted, but...what is the advantage of using gear diff versus a spool, and where would you use it in the car. front or rear....? thanks
HOY BAKLA!!!! U DA BU LA'IA!!!!!!
dragont is offline   Reply With Quote
Old 02-09-2011, 09:44 AM   #1403
Got your pm, I will respond in just a little bit. Thanks
Old 02-09-2011, 09:51 AM   #1404
johnny55's Avatar
Send a message via AIM to johnny55
I believe they are for the rear. I would also like to know the advantage or difference it makes. I know one advantage is that you don't have to maintain them as much as a ball diff. Can someone confirm this? TIA
johnny55 is offline   Reply With Quote
Old 02-09-2011, 02:25 PM   #1405
You can also use them in the front. I do, with great results. The car has a lot of steering, and gets awesomely quick through 180's. Out of the corners, a spool will understeer a little, but with a geardiff up front the car will go where you want it to go.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 02-09-2011, 04:14 PM   #1406
CraigM's Avatar
Trader Rating: 34 (100%+)
It's mainly a maintenance thing. With mod power these days sometimes a ball diff will not even last 5 mins before going off - this is more prevalent with other brands, the xray ball diff is very good
Run a gear diff with a loose belt and see how long it lasts
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-09-2011, 04:25 PM   #1407
It can last with a stock-motor, but a mod motor will rip the belt apart in 2 runs (believe me - I've tried).
Niklas Hansen
Old 02-09-2011, 04:57 PM   #1408
ark
Does a NT1 gear diff pop straight in to a t3 (335050) without changing anything?
ark is offline   Reply With Quote
Old 02-09-2011, 04:58 PM   #1409
Xpress's Avatar
No!
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 02-09-2011, 05:03 PM   #1410
CraigM's Avatar
I broke my first rear belt the other day after about 3 month of use so it's not too bad if you set them right. My front belt is now due for replacement too
