Old 02-05-2011, 03:25 PM   #1351
dragont's Avatar
Originally Posted by Xpress View Post
Depends on the thickness of the gear where the layshaft passes thru. You may have to sand down the flange that fits around the gear mounting screws to fit the assembled layshaft into the car.
yeah, i tried it, you definitely have to sand it down whether if its kimbrough or RR. otherwise, you have to use the specific spur....
HOY BAKLA!!!! U DA BU LA'IA!!!!!!
dragont is offline   Reply With Quote
Old 02-05-2011, 03:50 PM   #1352
LowBoost's Avatar
Trader Rating: 63 (100%+)
Guys... I am about to place my order of T3' 2011s. AMain does not have any Hudy Bearing Oil. Is there a particular brand I should look for?
Any other suggestions on parts/tools I need to buy right away for the build?
I am just ordering the two kits, tools, etc right now. Second order will be all electronics.
LowBoost is offline   Reply With Quote
Old 02-05-2011, 04:55 PM   #1353
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
i use Xenon Spur gears with no issue...
luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 02-05-2011, 05:50 PM   #1354
i just got me the plain version of T3R
I didn't wanna go for the 2011 version because I want to stick to NiMH packs and I also found the old version ridiculously cheap
The price difference alone will get me servo and spektrum receiver easily
my second electric and my first belt drive.
omegaf is offline   Reply With Quote
Old 02-05-2011, 07:06 PM   #1355
Bigz84's Avatar
Trader Rating: 20 (100%+)
Default spec r diff
what is a good starting point for diff oil on the rear for a spec r diff. I'm on a carpet track using 17.5, no boost, for the time being. traction is med to high.
thanks for any input.
Bigz84 is offline   Reply With Quote
Old 02-05-2011, 07:08 PM   #1356
jammincrtjames's Avatar
Ive had good luck with Xray 1000 weight
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 02-05-2011, 07:22 PM   #1357
KevinHawk's Avatar
If you want more steering and the car to rotate quicker go with xray 1000. If you want it to calm down and easier to drive go with 2000.
KevinHawk is offline   Reply With Quote
Old 02-05-2011, 11:30 PM   #1358
Chris08527's Avatar
Trader Rating: 16 (100%+)
first time out with the car tonite rubber tire carpet and all i can say is wow . . .box stock set-up is a very good start!!!
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 02-06-2011, 11:33 AM   #1359
I use 2000cst Kyosho oil in my (in the rear) and it is great. I have a gear-diff up front aswell (500k cst oil), so I have plenty of steering. But if I was to only run geardiff in the back, I would probably use 1000cst oil to get enough steering.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 02-06-2011, 06:23 PM   #1360
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
where can you get the 2011 conversion kit and how much is it in U.S.D?
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 02-06-2011, 08:30 PM   #1361
mickrcarver's Avatar
Trader Rating: 98 (99%+)
got mine from ebay off a person in cali, I could not find a usa dealer with one in stock
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 02-07-2011, 10:23 AM   #1362
i recently got a T3R but I got the opportunity to upgrade to a T3 2011.
The only concern I have is that I want to use NiMH packs. Is it possible to use NiMH packs with the 2011 version or is the battery slot not big enough?
Old 02-07-2011, 10:55 AM   #1363
the 2011 doesnt have battery slots .
Old 02-07-2011, 11:08 AM   #1364
so does this mean that i can fit whatever battery pack i want?
they explicitly state that it is meant for LiPo only and I am worried that there won't be enough space for NiMH.
Old 02-07-2011, 11:23 AM   #1365
id say its time to get a lipo pack as you will enjoy longer run times. im sure you can get a nimh pack to fit but it might move on you during your run.
