Old 01-21-2011, 11:04 AM   #1246
JamesReilly's Avatar
Trader Rating: 58 (100%+)
Originally Posted by Green Machine! View Post
We all seem to run 64. As far as the gearing fitment forget Bout it. Anything bigger than around 46 tooth you can't get the pinion off without removing the top plate anyways.
Save yourself alot of trouble an take the motor screws and tip the motor "endbell" up and you'll be able to get a larger pinion on and off without removing the top deck.
- James
Reilly Paint ([email protected])
JamesReilly is offline   Reply With Quote
Old 01-21-2011, 11:13 AM   #1247
In my opinion that aluminium lipo holders are totally unnecesary. The only real reason to use this is if you are looking for a cosmetic option part.
I'm actually adding lead to the electronics side to balance left&right wheight with the new 6200 batteries, It has no sense to add more wheight to the battery side.
Just my opinion
ARC R11 - LRP Powered
Find RC news on: http://www.rcelectrico.es
Psycho_ is offline   Reply With Quote
Old 01-21-2011, 11:13 AM   #1248
peter_robinson's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Fred Hubbard View Post
Hey what do you guys think about these?
EDIT: Be sure and click the 2nd attachement for a closer look. Thanks
i'm putting weight on the electronics side of my car to balance it. And if they don;t fit the battery any better then I'd say they are a waste
Alum parts always look nice though.
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 01-21-2011, 11:32 AM   #1249
Fred Hubbard's Avatar
The thin version weigh .20oz and the thick version weigh .25oz. which comes out to around 5 grams which is nothing. I swapped the thick ones with the stock units on my car and there was no difference in handling or lap times Obviously they are more resilient than the stock units and they look cool!
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 01-21-2011, 11:36 AM   #1250
Personally, 24 / 26 USD for a piece of orange aluminium holder, is really unnecesary. Xray plastic ones are really hard and make the function correctly.
Old 01-21-2011, 12:37 PM   #1251
Those could prevent a electronic yard sale. Where are they available?
A.B.R is offline   Reply With Quote
Old 01-21-2011, 01:28 PM   #1252
rchalt.com and I have some with me. They also make a Titanium layshaft that I've been using for over 6 months now. The guy that makes it all is a local buddy of mine.
Old 01-21-2011, 02:35 PM   #1253
Smile
Will you be at the Reedy this next weekend? If so hook Eric up with a set.
Old 01-21-2011, 02:38 PM   #1254
Nope, I will be in Florida. I'll figure something out though.
Old 01-21-2011, 04:18 PM   #1255
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Fred,
One of the things I disliked about 009 aluminum holders was the way the locating pin only recessed about half way through the carbon. I had a rough wreck on asphalt and the aluminum holders bent and tweaked enough to allow the holder to rotate and kind of shear the CF out and away from the locator hole (of course nothing else broke! ). The quality of the aluminum would also need to be top notch considering the amount of leverage the battery might have on them. Very nice work though. Good to see ya!
Old 01-21-2011, 10:19 PM   #1256
Originally Posted by andrewdoherty View Post
Fred,
Thanks Andrew and ditto! Attached is a pic of the holder pin installed. The depth of the pin is the same as the "Front-Rear" and "Rear-Front" suspension mounts.
Old 01-23-2011, 04:00 AM   #1257
Hi,
Who use's the foam insert's with the alloy or plastic shocks ? and when should it be used and when is it better to leave it out ?
Thanks.
S.A.W is offline   Reply With Quote
Old 01-24-2011, 09:16 PM   #1258
CraigM's Avatar
Trader Rating: 34 (100%+)
mmm due mid-late feb
302028-O - T3 ALU UPPER CLAMP WITH ADJ. ROLL-CENTER (L+R) - ORANGE
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-26-2011, 12:49 AM   #1259
RCknight's Avatar
Default Stock Servo saver?
Anyone else having issues with the servo saver? Mine broke with a 25.5. I tried to use an aluminum servo arm and then broke the plastic steering bell crank. Is there an alternative to the stock Xray servo saver?
RCknight is offline   Reply With Quote
Old 01-26-2011, 12:52 AM   #1260
RCknight's Avatar
EDIT: Be sure and click the 2nd attachment for a closer look. Thanks
Fred do those fit more tightly around the battery? The stock units have a lot of battery play and don't support well.
