Like Tree2Likes
Xray T3 2011
Old 01-01-2011, 09:35 AM
  #1186
I have found the T3 11 to be a great car. I think the front spool as helped my driving a lot. The way a spool works means I need to power it through the corners.
I had a Yokomo BD before the T3 11.
Miniripper is offline
Old 01-01-2011, 10:02 AM
  #1187
hana166's Avatar
Originally Posted by Chris-s View Post
Never had any problems building smooth schumacher diffs. Just re-built the diff on my T3, used a new thrust bearing, new spring plates, re-surfaced the diff plates (1200grit wet and dry). Diff still feels notchy. Using silicon nitride diff balls and its the only thing I havent changed, anyone had any experience of these getting flat spots on them?
Definitely - and with all diffs I have had this issue, with silicon nitride/ceramic if it has slipped a few times I found a little black dust mixed in with the lube. I'm sure it is material from the balls.
In a way it doesn't make sense because the steel plate is softer than ceramic but a change to new balls every now and then seems to keep everything dead smooth. I tried also fitting an old set of ceramic balls and the diff was notchy again so I'm convinced that was the issue.
hana166 is offline
Old 01-01-2011, 10:31 AM
  #1188
I'll order up some new diff plates and balls in the week. Have even tried a schumacher thrust bearing. Will buy some schumacher diff plates, see if they fit into the xray.
Chris-s is offline
Old 01-01-2011, 10:43 AM
  #1189
RC MARKET's Avatar
What about this, I'm not sure exactly what I'm looking at, could be a modded NT1 diff
http://rcmarket.com.hk/product_info....drblul7gspacs6
This is from XRAY NT1 rear gear diff & 38T pulley for XRAY T3 to use !
we Hk near all customer changed this support long life ,
& also upgrade LW Xceed gear , LW outdriver , support lW 20g !
RC MARKET is offline
Old 01-01-2011, 09:50 PM
  #1190
Default difference in parts
Hi guys,
I was wondering what is the difference between the two suspension holders part #XRA 302048-O and part#XRA 302045- O.
thank you
grouchy is offline
Old 01-01-2011, 11:29 PM
  #1191
StevenOlsen's Avatar
Originally Posted by grouchy View Post
Hi guys,
thank you
the 48 is a replacement for the std 2 piece forward holders in the rear. the 45 is for the forward holders in the front af the backward in the rear
StevenOlsen is offline
Old 01-02-2011, 03:04 AM
  #1192
Can that diff be used with the 52mm driveshafts ?
Chris-s is offline
Old 01-02-2011, 03:50 AM
  #1193
thank you steve
grouchy is offline
Old 01-02-2011, 08:55 AM
  #1194
What about using low membranes and inserts with the optionals alu shocks?
Psycho_ is offline
Old 01-02-2011, 09:13 AM
  #1195
Fred Hubbard's Avatar
That's what you want to do from this point forward.
Fred Hubbard is offline
Old 01-02-2011, 03:05 PM
  #1196
But the new membranes and inserts give any improvement on alu shocks?
I just assembled the alu shocks with stock high profile membrane and inserts and they are really smooth and works well.
Psycho_ is offline
Old 01-02-2011, 05:01 PM
  #1197
Johnny Wishbone's Avatar
Depends on how wide your running your car, if your narrow 52 will be tight.
Johnny Wishbone is offline
Old 01-03-2011, 03:55 AM
  #1198
Hi there guys
just brought a t3 '11' and i have a 38 t geared diff and was just wondering what weight oil i should use for competitive racing
tankmiester82 is offline
Old 01-03-2011, 08:37 AM
  #1199
Dane's Avatar
Trader Rating: 26 (100%+)
Low membranes allow you to have basically dead shocks. The high profile ones are too tall and make the piston bounce off of them giving you some unneeded rebound.
Only thing I don't like about the low profile bladders is that they are a little more fragile compared to the old ones.
Dane is offline
Old 01-03-2011, 08:38 AM
  #1200
Dane's Avatar
Originally Posted by tankmiester82 View Post
Hi there guys
1000
Dane is offline
