Xray T3 2011
#1171
So with running 17.5 and 13.5 now, are youguys finding one ways and riffs to be quicker than spools? Just wondering if the one way and diff is faster in the corners than the spool with the slower motors. This is assuming running no boost or anything to make a stock motor run like a mod motor.
#1172
It really depends on the track. If you can do a fast lap without braking, one-way could be an option, but if you need to brake, one-way is a no-go.
I find one-ways to be quite difficult to race with, because of the sudden change of cornering-ability. The spool is much more "consistent", but it does offer less steering (but I've more than enough - I even turned down my dual rate).
But I don't know if you can use a one-way in the T3'11, as the belts are flipped, flipping the one-way also.
#1173
#1174
#1175
#1176
#1179
Are we going to see a gear diff from Xray anytime soon?
#1180
What about this, I'm not sure exactly what I'm looking at, could be a modded NT1 diff
http://rcmarket.com.hk/product_info....drblul7gspacs6
#1181
Thats it, The main axle is also available (if you already have a multi diff and you just want to upgrade it to the flipped version
http://www.rc-mushroom.com/product_i...ducts_id=21662
#1182
Never had any problems building smooth schumacher diffs. Just re-built the diff on my T3, used a new thrust bearing, new spring plates, re-surfaced the diff plates (1200grit wet and dry). Diff still feels notchy. Using silicon nitride diff balls and its the only thing I havent changed, anyone had any experience of these getting flat spots on them?
#1183
#1184
Hopefully you folks can help me, aside from some carbon fiber pieces, and the orange anodize are there any other major differences between the T3-2011 and the T3R? I'd love the 2011 but the $225 price difference nearly gets me 2 ROAR approved batteries. I will be club racing on asphalt and carpet on spec tires. I know the asphalt tends to be harder on a car than carpet and I figured that should I break anything I'd upgrade to the 2011 spec parts. Budget is a consideration for me and as someone returning from 7 years of "retirement" would I honestly be able to realize the differences in the 2 cars? Thanks in advance.
Chris.
Chris.
#1185
Chris.
Chris.
