Like Tree2Likes
Xray T3 2011
Old 12-19-2010, 09:42 AM
  #1096
HarryLeach's Avatar
Ride height 5mm f/r
Droop [ORH] 3.5mm F, 3mm R
Front Toe- Out 1 degree total
Rear Toe - In 3 degrees per side [per kit instructions]
Camber -2 F, -2 R
HarryLeach is offline
Old 12-19-2010, 10:21 AM
  #1097
RobS's Avatar
I also had my first runs with the T3'11 this weekend and the car was absolutely awesome! I used EA's setup with only a minor shock oil change in the front and the car was so nice to drive!
RobS is offline
Old 12-19-2010, 10:25 AM
  #1098
StevenOlsen's Avatar
sorry guys stupid question. byt how do you measure the droop ORH ?
StevenOlsen is offline
Old 12-19-2010, 12:46 PM
  #1099
HarryLeach's Avatar
Set your ride height, then using your ride height gauge, measure the point when the tires just lift free, subtract that reading from your ride height value, that gives you your over ride height [ORH] droop value. I use downstop blocks to make sure everything is even side to side and recheck as well.
doing it this way is easier to compare droop values with other drivers, if you're not using the same tires. If you race somewhere with a spec premount tire, downstop values can be compared a little easier.
HTH.
I guess I'll look over EA's setup to see if anything jumps out at me. I should have time to do some testing the next couple weeks to see if I can get the car closer to what I want. Didn't make sense that the car seemed more stable driving so aggressively, felt like I was just jerking the car around the track.
I'm sure I'm missing something relatively simple, but I can already tell this car will be real nice once I get some fine tuning on it.
Old 12-19-2010, 01:24 PM
  #1100
HTH.
thanks but just have to say wow, running 6f 5b measured with a droopgauge but its 3f 4r whem measured ORH
Old 12-19-2010, 03:50 PM
  #1101
CraigM's Avatar
Trader Rating: 34 (100%+)
They measure different things, the gauges actually measure your downstops not your droop. The droop will change as you raise/lower your ride height, the downstops will not
CraigM is offline
Old 12-19-2010, 05:42 PM
  #1102
Johnny Wishbone's Avatar
Ride height 5mm f/r
Camber -2 F, -2 R
Change your camber to -1.5 front and -3 rear and go to one step heavier front spring, rest of car setup looks good. The heavier front spring will take the laziness out of the car, the -3 will lock the rear in better.
Johnny Wishbone is offline
Old 12-20-2010, 02:58 AM
  #1103
Trader Rating: 23 (100%+)
Anyone got or know of a Shock oil conversion chart for xray to associated/ losi ?
bmcallister is offline
Old 12-20-2010, 05:44 AM
  #1104
Trader Rating: 28 (97%+)
http://www.petitrc.com/reglages/OilChart.pdf
Funky is offline
Old 12-20-2010, 05:58 AM
  #1105
Team EAM
Trader Rating: 79 (100%+)
HTH.
My setup is really really easy to drive on our lower bite track. For a higher bite track you may want to go up on the front shock oil a little. I also think I am running 2.8 front springs but cant remember if I have those on the sheet or its something Ive changes since then. Everyone at my track that has driven it loves the way it feels. Tons of steering, stable and carries great corner speed. Our track is very bumpy too and it eats the bumps up!!
EA
EAMotorsports is offline
Old 12-20-2010, 06:01 AM
  #1106
Team EAM
On my rear droop I set it like Paul showed me at the birds last year and it works pretty much 98% of the time on all tracks. After you set the ride height set your car on the car stand and tighten the rear droop screws up till the spring barely touches the collar but has NO tension on it. this will give you about 2mm of rear up travel and works great most of the time. Ive never had to change more than 1/8th of a turn either way on the droop screw from this setting.
EA
Old 12-20-2010, 06:10 AM
  #1107
EA
thanks, what about the front ?
Old 12-20-2010, 06:49 AM
  #1108
Team EAM
Front I do it by feel and is at 2.5mm over ride height to begin with. Most of the time as the bite comes up I'll take some out and end up around 1.5-2mm of up travel (above ride height) on the front.
EA
Old 12-20-2010, 09:14 AM
  #1109
Anyone know where I can grab the t3'11 chasis?
Andy Z is offline
Old 12-20-2010, 10:42 AM
  #1110
Dane's Avatar
Trader Rating: 26 (100%+)
EA
EA,
How much has setup changed going from T3 to T3'11?
Thanks,
Dane
Dane is offline
