Like Tree2Likes
Xray T3 2011
Old 12-15-2010, 03:49 PM
  #1066
Con
Shims between arm holder and bulkheads. you will lose steering...but its the only thing I can think of.
Con is offline
Old 12-15-2010, 05:58 PM
  #1067
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by traitor
I just finished my NT1 diff conversion for the T3`11 and it wont work in the front with ecs driveshafts 52mm and front arms spaced out 2.25mm the driveshafts bind in the outdrives.Does anyone have any solutions other than 50mm driveshaft? Thanks.
Flying fox have some prototype outdrives that let you run the long bones and 3.5mm blades. Hopefully they make production
CraigM is offline
Old 12-15-2010, 06:36 PM
  #1068
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
Are the prototype FF outdrives really for an NT1 gear diff? All I had seen from them are the replacement outdrives for the standard spool. I would love to be wrong however.
andrewdoherty is offline
Old 12-15-2010, 06:51 PM
  #1069
Default a little please
I run an old t1fk05 and having some problems setup wise with the front end scrubbing real bad . im running on an order carpet and my set up is as followed 500cst oil in the front 22pnd spring no sway bar middle on roll center and short camber link. the car is plowing in the front and has a little of a push on power but not bad . i just really need to fix this plowing problem in the front anyhelp would be greatly app thanks , by the way i running a spool in the front also thanks jeff
lberry is offline
Old 12-15-2010, 07:26 PM
  #1070
I am by no means the guru on these things, but a 22# front spring seems terribly soft. I would surmise the car is transferring enough weight forward with the soft spring to over load the front tires. It might sound trite, but I really think your best bet would be to grab one of Paul's latest carpet set ups off the XRay forum.
Old 12-15-2010, 11:30 PM
  #1071
CraigM's Avatar
100%, Paul posted pics a while back. I have seen them, and I want them
http://www.rctech.net/forum/8199503-post776.html
The longer bones should give a bit more rear grip too
CraigM is offline
Old 12-16-2010, 05:31 AM
  #1072
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Why do you want more rear grip Thats the problem i had getting rid of on the 2011!
Yokomo_Ant3 is offline
Old 12-16-2010, 07:16 AM
  #1073
Pablo Diablo's Avatar
A limited number will be made in the next couple of days. It might be necessary to go 0.5mm wider to run 52's on the rear.
Pablo Diablo is offline
Old 12-16-2010, 01:22 PM
  #1074
CraigM's Avatar
Yeah but you're a mong
CraigM is offline
  #1075
arn671's Avatar
Trader Rating: 17 (100%+)
Thumbs up
So I noticed some TC6 drivers going to 80wt shock oil in gear diffs, has anyone running NT-1 gear diffs in their T3's tried going to something lighter than 1000wt diff oil? I understand the goal of the gear diff is to be as smooth as a well built ball diff? Thanks in advance!
arn671 is offline
Old 12-16-2010, 01:42 PM
  #1076
Mini-Mod's Avatar
I run 65wt shock oil in my diff if that helps.
Mini-Mod is offline
Old 12-16-2010, 02:33 PM
  #1077
L@gger's Avatar
Im not sure about downstops from a setup sheets. They meant to be measured from the bottom of car right? Because it looks for me like a pretty high downstop. Not sure how it should be right but shock shaft gets out like 1mm if im lifting car. Thanks.
L@gger is offline
Old 12-16-2010, 02:42 PM
  #1078
R/C Tech Elite Member
JayL's Avatar
wt and cst are different, you cannot compare. Most are running 1000cst or 2000cst on asphalt
80wt is pretty close to 1000cst
associated shock oil usually has both numbers on the bottle
JayL is offline
Old 12-16-2010, 02:50 PM
  #1079
StevenOlsen's Avatar
if the numbers is like 25mm+ its mesured from the top of the aksel to the ground
StevenOlsen is offline
Old 12-16-2010, 08:30 PM
  #1080
Trader Rating: 28 (97%+)
Default A Few Stupid Questions
I have a few dumb questions but hopefully you guys can help without too much laughing....
I am building my T3 '11 which is my first Xray car. Most of my other TCs are Team Associated (TC3s, TC4s and a TC5). Can I use my plastic Associated droop guage to set the droop on this car or do I need the Hudy blocks and droop guage to get an accurate setting? Also, I have lots of Associated shock oil and my LHS does not carry any Xray stuff. Should I just use the oil from the kit or would I be better off using some of the other shock oil I already have (everything from 25-45wt). If so, does anyone have any reccomendations on which weight I should use for the front and rear shocks? I also have lots of Associated spring sets from my other TCs, should I stick with the stock springs or should I experiment with some of the other springs I already have (if they fit)? Will I be struck by lightning for putting Associated stuff in my new Xray?
... and do I need to tear down and rebuild the rear diff that came in the kit or is it ready to go out of the box? It feels great but I didn't know if I am supposed to pull it apart and rebuild it or just run it and adjust it out of the box.
I'll buy all of the right tools/parts/fluids sooner or later, but for now I broke the bank just buying this kit so this is what I have to work with. Any advice would be greatly appreciated. I will be running a stock 17.5 setup with rubber tires on carpet on this track http://www.youtube.com/watch?v=TBVQvnb9Z6c
Funky is offline
