Like Tree2Likes
Xray T3 2011
Old 11-18-2010, 10:29 AM
  #841
skypilot's Avatar
Trader Rating: 14 (100%+)
I mounted a Airtronics servo using the narrower set of holes. and had plenty of room although I did have to mount the rcvr on its side.
one question thou...
did anyone actually follow the directions and use the rubber mounts on the servo??
skypilot is offline
Old 11-18-2010, 10:39 AM
  #842
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Kail View Post
I am running on a low traction asphalt. Need all the traction I can have.
ok, that makes more sense then.
Originally Posted by runs_wscissors View Post
I am considering ordering a T3 2011 kit and have a few quick questions.
1) Does anyone sand and CA the chassis to prevent chipping/delamination in a crash?
Yes. I have yet to split a chassis or anything, but it gives me a bit of piece of mind and looks nice when done right
2) What servos allow the use of both mounting posts? Or more specifically what dimension servo should I look for. I'm not so interested in the single post mount if I'll be getting a new servo anyway. I'd also like to get correct weight servo given the discussions on balancing.
Depends on your esc /RX, not that simple of an answer. With a KO rx the size of a postage stamp, a tekin etc there isn't a space issue. But spektrum and say an LRP or gtb and you will be out of space and be cutting the tab
3) Do batteries with the mini-bumps on the bottom fit the cutouts in the chassis better? I'm assuming all the flat packs are just fine it was just something I noticed in the XRAY web photos.
Either style battery works, They added the notches in the chassis so the guys that ran the hump style bottoms dont have to grind the lipo...
4) Back when I was running a T2 '007 everyone switched to aluminum knuckles and uprights since we had so much grip on carpet. Is this a common upgrade in the T3 series? I'll be on asphalt this time around so I assume I'll be fine with the kit components.
Stock plastics worked fine for me all last season, broke one rear hub and a shock (shock got broken when team mate punted me into a steel wall lol). You will probably notice more grip with the stock pieces. If the grip comes up ALOT then you might play with stiffer arms but that's about it.
Thanks for the input. Build pictures are of great help as well, keep them coming.
rx7ttlm is offline
Old 11-18-2010, 10:49 AM
  #843
Johnny Wishbone's Avatar
I read that part too (?), and no.
Johnny Wishbone is offline
Old 11-18-2010, 12:10 PM
  #844
runs_wscissors's Avatar
Thanks for the helpful replies to my questions, they are much appreciated!
runs_wscissors is offline
Old 11-18-2010, 06:09 PM
  #845
picco007's Avatar
Trader Rating: 99 (100%+)
Hey guys, I'm hoping someone can help me.....I'm getting a t3 11 here soon and want to know which body is best for asphalt racing.....I've used the speed 6 but want to know if maybe the p37 is something to look into as well.....any help or advice would be greatly appreciated.
Ronnie
picco007 is offline
Old 11-18-2010, 08:29 PM
  #846
Ronnie
Proline rates them as similar characteristics, on the track (carpet) I really didn't notice a difference, P37 feels like a mix between a Speed6 and a Stratus, nice neutral feel.
Old 11-18-2010, 09:15 PM
  #847
rx7ttlm's Avatar
Ronnie
If you start out with a speed 6 mounted a little forward with the wing mounted back that is about where I would start out and once you get the car dialed in swap bodies for a LTR or a 37 and find out. But I think you will be most of the way there with a speed 6 and you can figure out what works best for your style
rx7ttlm is offline
Old 11-18-2010, 09:37 PM
  #848
picco007's Avatar
Thanks to both of you!
picco007 is offline
Old 11-19-2010, 04:43 AM
  #849
Jamesalex's Avatar
Many thanks for the replies
Jamesalex is offline
Old 11-19-2010, 06:08 PM
  #850
PitNamedGordie's Avatar
PitNamedGordie is offline
Old 11-19-2010, 06:15 PM
  #851
Magnet Top's Avatar
Hey man, this isn't the sakura forum !
Originally Posted by PitNamedGordie View Post
Some build photos....
Magnet Top is offline
Old 11-19-2010, 06:16 PM
  #852
oops!
Old 11-19-2010, 07:51 PM
  #853
Chris08527's Avatar
Trader Rating: 16 (100%+)
does the kit come with sway bars or is that an option?, are guys running bars with rubber tire carpet???
Chris08527 is offline
Old 11-19-2010, 09:38 PM
  #854
dpatterson26's Avatar
Have you built an 11 yet?
dpatterson26 is offline
Old 11-19-2010, 10:07 PM
  #855
The kit comes with front and rear bars.
It really depends on the track, I've run bars front and back, and with just a bar up front, but it was a heavier bar. All on carpet, just different levels of traction.
