Like Tree2Likes
Xray T3 2011
Old 11-12-2010, 10:45 AM
  #781
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Pablo Diablo View Post
since everyone is talking about shocks and gear diffs, here are some things I have been working on.
I didn't drill out the TRF caps, I machined down the Xray tops a little. I also run TRF bladders. One thing to consider is that TRF's are longer and at ride height, are more compressed than Xray shocks. As discussed in the HB Cyclone thread, this does seem to take some grip away.
As for the diff, you just can't come close to the quality of the NT1 diffs. Spec R's don't even come close. Now that I have mine done just watch Xray release theirs and make all the time it took a waste.
I have been running my tamiya shocks that way for about 5 months now. And about a month ago I decided to try cutting my shock shaft so they were more extended and more oil over the piston. Magic number I came up with was 2mm lol. Car works lots better that way
And second, I need those outdrives you have in your nt1 diff, will you sell me a set? I hate the tiny blades you have to use in the outdrives! Also are you running all Capricorn insides in the diff? You will have a diff that's 1 or 2 grams lighter then a spec r that holds up to modified power no problem
BlackedOutREVO is offline
Old 11-12-2010, 10:49 AM
  #782
Johnny Wishbone's Avatar
Originally Posted by j86 View Post
Could somebody be kind enough to name a list of some of the MOST COMMON/Neccesary upgrade/replacement parts I should pick up when buying a T3 2011?
If your running 13.5 or less I'd option for the aluminum outdrives for the spool, and then get some replacement blades. Or the Flying Fox outdrives either or, but thats the only weak/wear part I've had on the car.
Johnny Wishbone is offline
Old 11-12-2010, 10:52 AM
  #783
Originally Posted by skypilot View Post
Last night I built my first ever set of xray shocks. When does all this "pain" I keep hearing about start?
Exactly, but perhaps some shock oil in the eye will do. LOL
  #784
Fred Hubbard's Avatar
LOL
Fred Hubbard is offline
Old 11-12-2010, 11:40 AM
  #785
skypilot's Avatar
Trader Rating: 14 (100%+)
skypilot is offline
Old 11-12-2010, 10:54 PM
  #786
CraigM's Avatar
Trader Rating: 34 (100%+)
Awesome! Can't wait to strap my one in
What are those outdrives??
CraigM is offline
Old 11-13-2010, 01:39 AM
  #787
darrenoakley's Avatar
Just finished my t3 011 build and have to say how easy it goes together. Also feels really smooth and great quality, just really well designed. The only problems I had was getting the servo saver in the right place between the top deck.
In the manual it shows adding a 1mm shim under the steering arm (wheel end). Is this correct as the ball stud doesn't seem to go very far into the arm with it fitted. I had some spare screws so have used longer ones but just wanted to check.
Also I presume the plastic nuts that you can fit on the shock mounts are also optional as it says to use longer screws if needed.
darrenoakley is offline
Old 11-13-2010, 02:53 AM
  #788
B4james's Avatar
Yes, the plastic nuts on the shock tower are optional. I generally only space the shocks out when changing between wheelbases.
I also changed to different longer ball studs for peace of mind
B4james is offline
Old 11-13-2010, 04:21 AM
  #789
Pablo Diablo's Avatar
Yep, 2mm shorter is where I am at. I took 1.5mm off the shafts and mount the shocks about 0.6mm higher.
The outdrive is a prototype. If Xray release a geardiff, these might be popular enough to go into production. Currently the NT1 diff requires the old 3mm blades which are chewing up fast. Considering how long blades are lasting on a spool with my outdrives, they should last an eternity on a diff. These will allow me to run 52mm driveshafts too.
Not sure about the gears for the diff. How good are the capricorn ones? I think 3racing gears fit too. I want a bulletproof diff for running mod.
Pablo Diablo is offline
Old 11-13-2010, 07:15 AM
  #790
Chris08527's Avatar
Trader Rating: 16 (100%+)
what batteries are most running in there t3 11, do some fit better then others???
Chris08527 is offline
Old 11-13-2010, 08:42 AM
  #791
Running an 5600Mah 50C LRP, fits fine.
Chris-s is offline
Old 11-13-2010, 09:17 AM
  #792
StevenOlsen's Avatar
have tryed IP 3800 35C, IP 5000 30C, SMC 5200 50C, LRP 5300 28C. LRP 5900 50C all fits fine
StevenOlsen is offline
Old 11-13-2010, 10:07 AM
  #793
I will send you a pm. Don't wanna clog up the thread lol
Old 11-13-2010, 12:03 PM
  #794
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Brandon- have patience, xray is working on a gear diff. I am confident that after the 1/8th onroad is shipping they will get a gear diff out . I am thinking I will have one in my hands before carpet nats.
rx7ttlm is offline
Old 11-13-2010, 12:09 PM
  #795
Yeah Nosram 5600 50c fits perfect too.
