Like Tree2Likes
Xray T3 2011
Old 11-09-2010, 10:09 AM
  #736
frank b's Avatar
i do agree there should be a few more spots on the chassi for the screw on weights, then i found some lead weights from 3racing that were painted graphite that looked awesome so i am using those. there is more of an adjustment with the stick on weights than the permanent weight. i have only had a short time on the 11 car and i am noticing the 11 car has a lot more potential than the original t3. it is nice to have a permanent track now and having the time to look at the car and finding out what certain things do to miner changes on the setup.
frank b
frank b is offline
Old 11-09-2010, 10:42 AM
  #737
skypilot's Avatar
Trader Rating: 14 (100%+)
question on chassis weight, I read where some are using a full size servo to help with weight balance, I have a metal cased XP servo that weighs 69 grams, you guys think thats to heavy. I have more servos if it is.
skypilot is offline
Old 11-09-2010, 11:11 AM
  #738
arn671's Avatar
Trader Rating: 16 (100%+)
Default Servo
Hey Skypilot, I'm running a full size servo, Futaba 614 and LRP SXX SS and they all fit flat on the chassis just fine, with the full size servo the extra weight seems to keep the car more balanced, definitely not running as much weight on the battery side-Alvin
arn671 is offline
Old 11-09-2010, 01:08 PM
  #739
frank b's Avatar
yes if you are running a full size servo you wont need that much weight to balance the car as i am running a low profile servo i had to add weight beside were i placed the servo. i also had to cut one of the ears off from the servo to make my electronics fit as it said in the manual because my receiver and speedo is quit big.
frank b is offline
Old 11-09-2010, 01:30 PM
  #740
CraigM's Avatar
Trader Rating: 34 (100%+)
I'm running a full size servo and my car is too heavy on the electronics side? Admittedly I'm running an LRP air conditioner on the motor
First run of the car last night and I was less than 1/10th off the fastest lap I did with my state titles winning tamiya. That's just silly
CraigM is offline
Old 11-09-2010, 02:32 PM
  #741
frank b's Avatar
i like running the low profile servo's just incase i need to add weight in other places. an air conditioner is not needed with the latest speedo out there, i am only running a regular hi speed fan from muchmore 30mm by 30mm that did the trick. i also have 4 mini scales that i balance all 4 corners of the car to get a close enough weight distribution so i can add weight were it is needed.
frank b is offline
Old 11-09-2010, 05:02 PM
  #742
CraigM's Avatar
I run a BD so usually my temps are well in check, but it's getting hot in OZ at the moment so the heatsink and fan is insurance, plus we run 1425g so it helps me get up to weight. Will put a low profile in this weekend, should be sweet
CraigM is offline
Old 11-09-2010, 10:25 PM
  #743
frank b's Avatar
i have heard good things about a low profile servo called SAVOX SC-1251MG it is only 60 something and it has the same speed and torque or even better than some of the name brand servo... i am going to use it in a day or so during practice and i will let everyone know what i think of it.....
frank b is offline
Old 11-09-2010, 10:29 PM
  #744
Cribbin's Avatar
no craig, thats just what ive been telling you
Cribbin is offline
Old 11-10-2010, 03:12 AM
  #745
FK05 lover's Avatar
Trader Rating: 147 (99%+)
ALL Xrays are good straight out of the box!
FK05 lover is offline
Old 11-10-2010, 04:34 AM
  #746
whityboy's Avatar
these servo's are very good quality for a low price
whityboy is offline
Old 11-10-2010, 06:49 AM
  #747
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 65 (100%+)
Savox low profile servo has held up nicely. When will the T3 11 be shipping again to hobby shops?
Jamison R is offline
Old 11-10-2010, 06:51 AM
  #748
M-Technic's Avatar
Trader Rating: 15 (100%+)
The next shipment is due in middle to end of November.
M-Technic is offline
Old 11-10-2010, 08:44 AM
  #749
John_S's Avatar
The Uk distributer got them in today so it should be around a week or so for the US
John_S is offline
Old 11-10-2010, 08:47 AM
  #750
mok
mok's Avatar
would that include 2011 specific parts as well?
-Mark
mok is offline
