Xray T3 2011
#646
anyone running the T3 or the 11 in the stock class??? how is it getting close to that low FDR???
#647
hi
yesterday i finished to build my new 2011 i have to say that the kit is awesome except for the shocks, i found one shock shaft with no groves for the c clips and two shock cap nut to small to fit in the the part which goes in it. now i have to wait for my lhs to open
#648
hi
#649
I try yesterday the ecs drive shaft and i do not see any difference in lap time.
Next thing to try is a gear diff in the rear but i ran tam shock again yesterday and i was very impressed to feel how car rotate smooth in comparaison with the xray shocks
Any way, may be it s me i dont know how to build xray shock hehe
#650
It looks like Nexus has a bunch of the small spurs that fit in stock:
XRay 92t - http://www.nexusracing.com/index.php?cPath=145_321_436
RW gears all the way to 72t - http://www.nexusracing.com/index.php?cPath=145_321_322
#651
thanks hanulec, your like a walking RC-pedia and if nexus doenst have it, could always check www.hanulecsbigyellowpitbox.com . . .LOL
#652
hi
Hey me to same problem cap to small to fit the plastic shock mount and parts wrong colour...and one other guy as well no clips to mount the piston.what is going on with xray ever since the second run of 09 kits I have had stuff wrong and I'm not the only one I order 3 09 kits ones and all had some issue of some sort out. of three t3'10 kits two where fine 1 had problem and now stuff still going wrong with t3'11.not liking xray At the moment:-(
Guys sorry to hear that. You can call RCAmerica and send the parts in and we will replace them. I know that takes time for you guys to get the parts back and I apologize for the inconvenience and we will make note to say something to Xray.
Thanks Drew
214-744-2400
[email protected]
#653
Just finished with the build. Everything went together well, however, I think the kit was missing a few screws. No problem as I had a surplus of parts from other cars. Only complaint I have is that Xray didn't include any turnbuckle wrenches (3mm and 4mm). They didn't have to include the fancy Hudy ones, but if they could've included some cheap turnbuckle wrenches to help with the build, that would've been good.
[IMG]
[/IMG]
[IMG]
#654
Quick can someone tell me what pinion gear I need for 5.0 gear ratio with 100t spur. thanks
#657
#659
I ran my car for the first time yesterday, the car has a lot more rear grip than the T3 and the steering is much smoother. I was having issues with driveshafts for some reason yesterday
I ran it 3 races, all 3 my rear driveshaft pins came out, and in the 1st race the whole rear driveshaft fell out
Yes they were loctite'd. Then in the 3rd race i completely sheared a front driveshaft, just from driving. Oh well, time for some flat spot pins and stronger loctite. never had that issue on my T3.
I definatly need more time with this car as it wasnt driving perfectly yesterday. It needs more overally steering, and definatly needs more high speed steering. Anyone have any suggestions?
Here is the setup sheet
http://forum.teamxray.com/xform/inde...&setup=t3_2011
Here is what i was thinking of changing. Thoughts?
Thanks,
Antoni
Thanks,
Antoni
#660
Anyone know an Online shop that has these in stock?
