Like Tree2Likes
Xray T3 2011
Old 10-28-2010, 04:27 AM
  #616
whityboy's Avatar
my LHS sold 70 xray's T3 2011 and still has 10 waiting for a new owner . shop located in france
whityboy is offline
Old 10-28-2010, 05:51 AM
  #617
Team EAM
Trader Rating: 79 (100%+)
Originally Posted by RCknight View Post
Man....there must have been few shipped on the first batch of T3'11s. My LHS said they could not get one. I even had the order in way before it's release. Going to have to wait until late Nove now.
I guess your shop didnt order quick enough. Mine got 4 that were pre sold out of the first batch (of around 100 kits). The next batch will be larger and last I heard was well over half way pre sold. So if you want one you better make sure your local shop puts that order in!
EA
EAMotorsports is offline
Old 10-28-2010, 10:42 AM
  #618
R Dodge's Avatar
EA
Let's keep this comment in mind next year when someone tries to tell us that Xray only sold 100 of the T3'11 kits
R Dodge is offline
Old 10-28-2010, 10:48 AM
  #619
Fred Hubbard's Avatar
Originally Posted by kobiwan View Post
Can I use the xray dog bone blades, or do I have to use different ones?
You can use the stock blades with the 50mm bones.
Fred Hubbard is offline
Old 10-28-2010, 11:11 AM
  #620
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
But if you run your front end wider than 1.5mm shimmed at arm u will break blades all day unless you run:
1- locked multidiff (fragile outdrives)
2- flyfox 50mm spool out drives (beefcake!)
hanulec is offline
Old 10-28-2010, 11:14 AM
  #621
I always run my front end at 2.25mm and I never have an issue with breaking blades.
Old 10-28-2010, 11:28 AM
  #622
skypilot's Avatar
Trader Rating: 14 (100%+)
skypilot is offline
Old 10-28-2010, 06:58 PM
  #623
RCknight's Avatar
Well no one has proven what I was told wrong yet either. Honestly it made no sense to me, but that's what I was told. Besides the T3'11 was released sooner than the T3. How many kits made it to the US? Until we see numbers you don't know squat either. I've only seen one T3 at our track. There are a lot of older Xrays, but only one T3 and he's a team driver. A 008 has been on the shelf at my LHS since it came out. Given what I've seen at my track and what I've been told a reasonable person could believe it's possible, but I would hope not. Make any sense now? Why go on and on with this? I think I made my point clear, and any sensible person could understand why I came to this conclusion. Xray makes good products so it's not a matter or quality, so I guess it's a matter of perception or cost. IDK for sure, but I wonder.
RCknight is offline
Old 10-28-2010, 07:30 PM
  #624
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Well no one has proven what I was told wrong yet either. Honestly it made no sense to me, but that's what I was told. Besides the T3'11 was released sooner than the T3. How many kits made it to the US? Until we see number you don't know squat either. From what I gathered sales in CA & FL are not good. I've only seen one T3 at our track. There are a lot of older Xrays, but only one T3 and he's a team driver. A 008 has been on the shelf at my LHS since it came out. Given what I've seen at my track and what I've been told a reasonable person could believe it's possible, but I would hope not. Make any sense now? Why go on and on with this? I think I made my point clear, and any sensible person could understand why I came to this conclusion. Xray makes good products so it's not a matter or quality, so I guess it's a matter of perception or cost. IDK for sure, but I wonder.
Any sensible person would realize that the RC Industry is bigger than you and your home track!
Owen RaCing is offline
Old 10-28-2010, 07:37 PM
  #625
hanulec's Avatar
Fred - I gotta say your better than me bro. I can usually look at a board when running the XRay Aluminum Spool Cups and break blades.
hanulec is offline
Old 10-28-2010, 08:14 PM
  #626
Trader Rating: 16 (100%+)
But, he has "reliable sources"...And he is still the only person on my Ignore List. Hint, hint, hint...
Still Bill is offline
Old 10-28-2010, 08:43 PM
  #627
R Dodge's Avatar
Have you tried taking 2 of the 1mm plastic shims that come with the kit, cutting 2 parallel flat edges on them and place a shim behind the cup on each side to make the spool 2mm wider overall?
R Dodge is offline
  #628
RCknight's Avatar
Oh...ok you got me there. Nice job...
RCknight is offline
Old 10-28-2010, 08:50 PM
  #629
hanulec's Avatar
That would work too.. but w/o some sort of modification average drivers will have issues ..
hanulec is offline
Old 10-29-2010, 07:33 AM
  #630
What I meant was, will the stock blades fit inside the out drives of the Spec-R gear diff? I heard you had to use different ones but wasn't sure.
kobiwan is offline
