Like Tree2Likes
Xray T3 2011
Old 10-17-2010, 03:04 PM
  #496
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
I think the xray plastic shocks are great. Hell, all of xray's plastic parts are far better than most other manufacturers. I know many folks that run xray hubs, steering blocks, arms, etc on their cars.
hanulec is offline
Old 10-17-2010, 03:44 PM
  #497
R Dodge's Avatar
I've never used aluminum shocks on any of my Xrays and never felt the need to either. I am excited about the new bladders though.
R Dodge is offline
Old 10-17-2010, 08:43 PM
  #498
Johnny Wishbone's Avatar
Originally Posted by EAMotorsports View Post
The plastic shocks are slightly smaller so you just barely have to trim around the edge of the bladder to get them to fit perfectly. It will work and settles the car down quite a bit.
EA
+1, +drilled cap=100% zero rebound shock made easy.
Have the aluminum shocks too, but never seen a need to use them over the plastic ones.
Johnny Wishbone is offline
Old 10-18-2010, 03:09 AM
  #499
RCknight's Avatar
Can anyone tell me if RW brand spurs will work with the T3? What tooth do most people run in VTA? 100T? Just wondered if it's better to push the motor back with a smaller spur for better rear traction or not? I'm all new to the T3 series. With my 008 I had pushed the motor forward with my gearing. Maybe it don't matter. lol Thanks
RCknight is offline
Old 10-18-2010, 03:17 AM
  #500
RCknight's Avatar
The Tamiya shocks are sharp and well made. I hope we see some new shocks, bulk head braces, aluminum steering arms, soon as option parts.
RCknight is offline
Old 10-18-2010, 06:21 AM
  #501
Fred Hubbard's Avatar
You can either use the XRAY spur gears or the RW spurs gears designed specifically for the XRAY cars. Someone else should be able to give you guidance on spur sizes used for VTA.
Fred Hubbard is offline
Old 10-18-2010, 08:25 AM
  #502
Regional Moderator
CarbonJoe's Avatar
I hope we see some aluminum steering arms, soon as option parts.
Doesn't the existing aluminum C hubs and steering blocks work on the T3 series? I thought that they did, as long as you have the V2 C hubs (for use with the ECS driveshafts).
CarbonJoe is offline
Old 10-18-2010, 09:21 AM
  #503
R Dodge's Avatar
Yea they do have alum. steering blocks and c-hubs that work on the T3 suspension (which is the same as the T2 suspension) but Knight is talking about the new swing rack pieces that are plastic. The piece that links them is alum. but the two swinging pieces on the posts are plastic. I don't see a need for them to be alum. but some do I guess.
R Dodge is offline
Old 10-18-2010, 11:38 AM
  #504
unpacking the xray:
+ YouTube Video
andy3000 is offline
  #505
Has anyone tried the R9-R or the P37-R bodies? I currently run the LTC-R body which I like better that the Speed 6, but was just currious about the other 2.
kobiwan is offline
Old 10-18-2010, 05:38 PM
  #506
Slideaway's Avatar
Originally Posted by andy3000 View Post
unpacking the xray:
+ YouTube Video
Yeah, Extreme "Rest In Peace" playing back ground !! Cool !
Slideaway is offline
Old 10-19-2010, 03:50 AM
  #507
RCknight's Avatar
Originally Posted by Nilks View Post
Paul answered why in another thread. It is because of the weight. You can also use a low profile and then add some weight yourself.
This must be the reason why Tamiya mounts the servo the way they do. Regardless it makes the narrow chassis a mute point when the servo hangs off of it 10mm, but I guess it creates more flex.
RCknight is offline
Old 10-19-2010, 05:29 AM
  #508
Just ordered mine last night. Should be here tommorow.
Cant wait to build and do some testing round ardent.
matthab is offline
Old 10-19-2010, 11:08 AM
  #509
Xchange's Avatar
Trader Rating: 10 (92%+)
Winch setup is the best to start with?
Xchange is offline
Old 10-19-2010, 11:17 AM
  #510
I'v heard that some the guys using the plastic shocks have been drilling the 3 hole pistons out to 1.1mm, drilling vent holes in the top mount, and using 400 wt xray oil on high grip carpet. what are your veiws on this ?
shrek54 is offline
