Xray T3 2011
#4096
Parts for T3 2011 EW servo placement
I would like to use the 2mm Xray or Smokem lower deck for my T3 2011, but need advice on how to convert to a EW servo placement please.
#4097
Drill a 2nd hole in the right arm of the steering rack to add another ballstud, then line up your servo on the chassis and either glue it on, or mark out a hole and drill/countersink a hole on the inside near the topdeck for mounting. I use one post and shoe goo and it has never broken free. I trimmed the left side servo mounts off the case because I didn't like the way it looked and cases are cheap
#4098
What can make a car noisy? When I first got the car it was whisper quiet. I changes the pinion gear but now it is noisy. It sounds like the gear mesh is too tight but it isn't.
Car runs smooth, it just is noisy. There isn't too much slop in the drivetrain or other parts.
Could switching pinioned make the car noisy? As if the spur was worn in to the old pinion or something like that?
#4099
#4100
#4101
Yes, a bad pinion or spur can make a car sound terrible. Just check there are no little stones in the gears also. Sometimes pinions are out of round and the mesh can get tighter and looser as it rotates. I have had some cheap pinions make awful noises before.
#4103
Hmm, I have been using robinson racing pinions. Same brand on both. How can you tell the difference?
In my VTA car I am running a Spec R gear and it has always been noisy. I just thought it was the gear. What pinion brand should I run in that?
In my 17.5 sedan I am running the Xray spurs. Will robinson racing pinions work with those?
I have never seen anything other than 64 pitch and 48 pitch myself.
#4104
I've been using Robinson and XRAY gears for some time, with XRAY Spurs with no problem.
#4105
Its not so much the brand but the specification of the gear. If your looking at 48 pitch you can just about spot it just by looking as the metric (some times refered to as .04 or mod 4) gears will look slightly finer. Its very hard to spot the difference between the 64 pitch gears, one way to tell is to compare two gears with the same number of teeth as they will have a different diamater.
So far, what has worked best for me are HPI and Xenon pinions. I have also changed to Spec R spur gears for the reason that Spec R produces odd numbered spurs which gives me the option to be really specific with my FDR.
#4106
I use RW racing spurs and pinions, and people always comment how quiet my car is. Mis-matched pinion/spur gear is the number one cause for a noisy car, and noise = loss of Efficiency
The trinity pinions seem really good too, using one at the moment and it is very nice. The robinson racing pinions are a pain as they use imperial grub screws, and seem noisy compared to other brands i have used
#4107
#4108
re east west
you need to drill one hole about 10mm behind steering post holes then can use xray 306220 servo mount and t3 12 arm 302526 or drill tap extra hole in 11arm
main issue no stock of either part in aust for 2weeks.
pm as i have smokem chassis with correct holes we could copy
#4109
what part numbers are you using
