Xray T3 2011
#3946
So I did some laps at our local small track and temp'd it when it came off the track to be about 139 or so on the motor. Should I gear up a tooth? I was reaching top speed about 1/2 way down the the straight or so.
Also, what setting on the new style clamps matches the H1/H2 roll centers?
Additionally, I am running 1 degree camber in front and 2 in the rear. I am getting a littl ebuild up on the outside of the tire and a wear ring on the inside. Should i drop the rear camber down to 1.5?
#3947
its an lrp x12 stock spec 21.5, through a hobbywing 120a speedy (blinky mode)..
in an lrp forum someone is suggesting not to temp over 95deg which intuitively sounds about right. i'm from an offroad background and have historically temped between 70 - 85 without any problems whatsoever.
however, the wise people at the track suggest aiming to come off at around 50deg celcius. this seems very low to me.. do you need to aim for lower temps with on-road???
#3948
#3949
im sure it been posted before but what servos are you guys using
#3951
HI,
I use the futaba s9551 low profile it is very good, fast strong and doesnt make noises and it is very smoth ive had savox before but i havent realy liked it i would prefer spending a extra $30 of a futaba then to get a savox.The savox seemed to be slopey and wasnt smoth and made noises.
#3952
HI,
Hi Jake95 - I notice you are Sydney based - what do you suggest for shock oil weight on local tracks? Running the kit 350cst at the moment and finding it quite good...
I mostly run at castle hill but are looking to venture to SMA and Windsor over the coming months.. where do you run?
#3955
Been asked about a dozen times in this forum. You just need to have a search through this formum. I presonally have posted pics and info three times, search on my posts in here for more info
#3957
Drove my 2011 with the modded chassis, turned servo and 2012 topdeck for the first time today. My car was dialed! I took the win in 17.5T boosted after some exiting races!
#3958
#3959
Nope. The '11 topdeck is fine
#3960
