Like Tree2Likes
Xray T3 2011
Old 10-05-2010, 10:31 AM
  #376
Drew Ellis's Avatar
Guys if you have question about the new car please post on the RCAmerica thread, there will be helpful and useful answer's there.
Thanks Drew
Drew Ellis is offline
Old 10-05-2010, 06:56 PM
  #377
Originally Posted by ByteStream
The manual, setup book, etc .. are available
Their is a T1/T2/T3/T3'11 Parts Cross Reference Table that is particularly interesting ...
http://www.teamxray.com/teamxray/new...loadable Files
Lots of info there, especially the Parts Cross Reference Table..
slashman4x4 is offline
Old 10-05-2010, 07:21 PM
  #378
RC America's Avatar
Initially there was a possibility for both an EU and US version, but with most of the racing focusing on rubber tire, there will only be one version of the 2011 Spec kit, #300017. The demand was almost exclusively for the rubber tire kits, even here in the US, so XRAY simplified the offering.
Unfortunately, that change was after our last price list update, so I will need to send out an update to our dealers to remove the previous US kit listing!
Bryan
RC America is offline
Old 10-06-2010, 03:17 AM
  #379
alecladanga's Avatar
the car really looks good. the best innovation for me, is that the new top deck! looks very similar (the front part that is) to the hop up top deck for the 008/009 asphalt version which produced more grip...
alecladanga is offline
Old 10-06-2010, 06:56 AM
  #380
Skiddins's Avatar
A modified T3 2011 setup sheet with a comments box that can be filled in with editors such as CutePDF.
T3 2011 Setup Sheet with Editable Comments Box
Skiddins
Skiddins is offline
Old 10-06-2010, 09:49 AM
  #381
If X-Ray would come out with a set of golf clubs...
Now THAT would be something
Dondor is offline
Old 10-06-2010, 10:21 AM
  #382
Drew Ellis's Avatar
Noted..
Old 10-06-2010, 10:52 AM
  #383
yumlailai's Avatar
Is the setup on a T3 a good starting point to set up the T3 2011?
yumlailai is offline
Old 10-06-2010, 11:19 AM
  #384
Drew Ellis's Avatar
Yes it will be. You will just have to see where you like the ackermen at. I have ran it from 1mm shim to 4mm shims. It is something you can really fine tune the car with. On carpet I ran 1mm shim, on asphalt I ran 1-4mm and like the way 4mm felt.
Check out the RCAmerica thread on here all the team guys are there, if you have anymore question.
Thanks Drew
Old 10-06-2010, 05:13 PM
  #385
Skiddins's Avatar
Thanks Drew
Can you compare how the ackermann was with the old system, i.e. 1mm is position 2, 4mm is position 5 etc?
Just a rough guide
Skiddins
Skiddins is offline
Old 10-06-2010, 05:47 PM
  #386
Drew Ellis's Avatar
Just a rough guide
Skiddins
I have not fulley checked it against a T3, you for sure can't go as forward as the old one. 1mm is like running the bearing back and the ackermann piece all the way back and if there was a middle whole on the steering block.. You can run more ackermann with the new steering system.
I will see if Martin can put something up on this.
Thanks Drew
Old 10-06-2010, 05:55 PM
  #387
R/C Tech Elite Member
JayL's Avatar
Drew: kick Martin about a shock build video he has been promising on the xray forum too I like the look of the new bladders
JayL is offline
Old 10-06-2010, 09:14 PM
  #388
Drew Ellis's Avatar
Yes I know, I think Paul is going to be doing one.
Thanks Drew
Old 10-09-2010, 07:09 PM
  #389
RCknight's Avatar
Default Cheapest online shop to buy Xray?
Looking for ceramic thrust bearings, for best price? Can't seem to find them anywhere. None at speedtech. Thanks.
Drew nice to see the T3'11 come with steel front cvds. Is this correct? Also any chance we will see aluminum steering as an option?
RCknight is offline
Old 10-09-2010, 07:15 PM
  #390
Regional Moderator
CarbonJoe's Avatar
http://ashfordhobby.com/detail.aspx?ID=4313
CarbonJoe is offline
