Old 11-29-2011, 11:04 PM   #3736
Meradin's Avatar
Trader Rating: 19 (100%+)
Originally Posted by kinga View Post
Drill a hole in the chassis and use one servo mount in the center of the chassis. Carefully drill out hole then carefully countersink with bigger drill bit.
THis thread should be renamed "Help Mera'din get his xray handlin' well! "
Lol
I agree! But once I get it dialed you most likely wont hear much from me as I will be racing and onto the next thing that catches my attention. Right now this has my focus as I hate it when things get the better of me. I kinda obsess on them a bit.
I may come back to help the next Mera'din that comes along!
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 11-30-2011, 08:34 AM   #3737
Integra's Avatar
Originally Posted by mazmorbid View Post
Better to buy a proper 45 deg countersink drill bit for like $8
A BIG X2
Drill bits for Countersinks aren't a wise idea.
Old 11-30-2011, 09:43 AM   #3738
morgoth's Avatar
Do you guys set your shock collars in the same position between the left and right side? Or is there a little difference so that the ride height on left and right is the same?
My car is pretty good balanced, but some guys told me to adjust the collars on every shock independent. I'm used to used to use the same setting left/right from offroad.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 11-30-2011, 10:23 AM   #3739
Having seen the track and reading about fast sweeping bends I fear that the issue is more your driving than the set up of the car. Surely that track isn't suitable for 1/10 TC's?
scoop is offline   Reply With Quote
Old 11-30-2011, 11:50 AM   #3740
M-Technic's Avatar
Trader Rating: 15 (100%+)
I start with them exactly the same using calipers, and then adjust them independently with the car on a tweak station to get any small amounts of tweak out of the car. If they are off by more than a few tenths of a MM I will go through the car to find the source of the tweak.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 11-30-2011, 12:46 PM   #3741
morgoth's Avatar
Is a tweak station really worth it? I think I'll get a setup station first before getting a tweak station. I hate it use my friends setup station every time and the difference is big between 1 extra of less camber. Some don't care about 1 less or more, but I want my car as consistent as possible.
Old 11-30-2011, 01:58 PM   #3742
M-Technic's Avatar
I don't use it all that often but they aren't that expensive. I think I paid $30 for my tweak station.
Old 11-30-2011, 04:52 PM   #3743
Here you go
http://www.ebay.co.uk/itm/HUDY-Exclu...item1c215c866e
Bb
bucketboy is offline   Reply With Quote
Old 11-30-2011, 10:56 PM   #3744
morgoth's Avatar
Originally Posted by bucketboy View Post
Thanks for the link! That's a very nice price! Are you the seller or have stumbled on it while browsing ebay?
Old 11-30-2011, 11:29 PM   #3745
Coincidentally, I'm the seller
I'll post to Belgium if you cover postage costs.
Any questions, let me know.
Mb3195 is offline   Reply With Quote
Old 12-01-2011, 12:19 AM   #3746
CraigM's Avatar
Trader Rating: 34 (100%+)
Think youll find most pros don't use tweak stations. If you are precise when you build the car they aren't required
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 12-01-2011, 04:00 AM   #3747
Skiddins's Avatar
If the weight balance from corner to corner is even slightly out you will get tweak, no matter how carefully to do up the screws etc.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-01-2011, 03:29 PM   #3748
morgoth's Avatar
Got overbidded But they are a bit cheaper in Belgium than in the UK so I didn't wanna bid too high.
Old 12-02-2011, 07:32 AM   #3749
Meradin's Avatar
Shoot! Looks like I wont be able to race tonight so I wont be testing out my settings this week. You guys get a week off from my pestering!
Just Kidding! Morgoth, I use a setup board that has the tweak station built in. It is an Integy one. I find it a little difficult to use as you can see the bubble when the car is on the board. Kinda a silly design in my opionion. What I have been doing is measuring the gaps on the sides of the arm and the board to take care of the tweak.
I was very surprised to see how much tweak my car had! Everything balanced well on my balance buttons but once I put it on the tweak station there were huge differences. Bottom line, even if the car balances right to left, it can still be outta tweak. Check it. A mentor at my track checks his tweak after every race as there is a lot of contact on our small track.
Speaking of balance...how are you guys balancing your cars front to rear. Not the actual how as I have scales and know "how" to do it, but what percentages are you using? More front bias, rear bias, even front to rear?
Old 12-02-2011, 08:13 AM   #3750
nitrobeast's Avatar
Trader Rating: 41 (100%+)
To me a tweak station is worth every penny. If your buddy has a setup station and not a tweak station buy the tweak and share it with him.
This way you wont feel bad
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
