Like Tree2Likes
Xray T3 2011
Old 11-28-2011, 10:07 AM
  #3721
morgoth's Avatar
This is the setup I ended with at the end of the day. But the car was still a bit twitchy and had a lot of steering.
Link: http://cl.ly/CApE
morgoth is offline
Old 11-28-2011, 10:30 AM
  #3722
Try the following:
Move shocks out front and rear, one hole, maybe move front out 2.
Less front toe, try 0.5 degrees
Increase wheelbase to 257
Rest looks ok.
Mb3195 is offline
Old 11-28-2011, 10:53 AM
  #3723
morgoth's Avatar
Originally Posted by Mb3195
Try the following:
Rest looks ok.
Actually, my shocks were in the middle hole in the front and 2nd lower hole in the back. Inclining them all the way down made the car a little less responsive. But I'll change my wheelbase and try again with the shock locations.
I have changed my oil to 450cts because I think this will slow down the weight transfer a little and make the car a little more forgiving. I'll see how that goes on sunday.
morgoth is offline
Old 11-28-2011, 09:39 PM
  #3724
Meradin's Avatar
Trader Rating: 19 (100%+)
Gonna try something for the next races. Going back to the rubber tire setup but I am going to shorten the wheel base. What do you think? I thought bringing the front back 1mm may help, I would have 1mm shim in front and behind the front arm.
Should I bring it all the way back?
What about the rear. Should I bring that forward or leave it as is? Right not the set sheet calld for 2mm spacer in front of the rear arm.
I also am going to add 2mm shims to the akerman since the track is so tight. I remember reading that in the setup manual I think.
This months track is even more technical! Take a look!
Meradin is offline
Old 11-29-2011, 12:34 AM
  #3725
morgoth's Avatar
I raced on a very tight track last sunday, but this is even more smaller!
I'd start with a 1mm shim in the front of the front arm and a 2mm shim in front of the rear arm.
You'll need a lot of steering on that track to get around the tight corners.
morgoth is offline
Old 11-29-2011, 01:21 AM
  #3726
Dude, you need to try one thing at a time so you can see whats happening, first thing I would do on a track like that is sell the Xray and get a CRC XL
bucketboy is offline
Old 11-29-2011, 05:22 AM
  #3727
Meradin's Avatar
Oops, in re-reading that I realize I forgot to mention that! It was my intention to do the wheel base first then the akerman shims.
You're kidding about selling the XRay right! They are still the fastest and most durable cars at the track. The guy driving the TC6 just switched camps so he doesn't count! We run 1/14th scale recoils for small scale action. Heck we are the 2nd most active track in the USA when it comes to the recoil/carisma class according to Horizon. Those cars are running more laps than the 1/10th scales.
Meradin is offline
Old 11-29-2011, 05:47 AM
  #3728
M-Technic's Avatar
Trader Rating: 15 (100%+)
Go back to the kit wheelbase, which is what bucketboy suggested.
M-Technic is offline
Old 11-29-2011, 07:48 AM
  #3729
Meradin's Avatar
Rodger the kit wheel base. I thought it odd that the suggested rubber setup was different than than the kit setup. What else differs from the suggested rubber tire setup and the kit setup? I see the H1/H2 roll centers, which I have. Don't really see any difference in them to tell you the truth.
I am also wondering how you guys are holding down the servo when you do the east/west mod. I have used servo tape before on other cars and they all seem to wobble a bit when turned by hand and over time the tape starts to give way. Those were on smaller 1/18th scale cars, I imagine it would be worse on a 1/10th scale car.
Meradin is offline
Old 11-29-2011, 12:19 PM
  #3730
This thread is so wide I started in my house but had to go to my next door nieghbours to read the rest
Anyway, east west servo make the car a whole lot better.
You will need to fit a servo post inboard and servo tape under servo, stick it down and its going nowhere.
Bb
Old 11-29-2011, 01:47 PM
  #3731
Meradin's Avatar
Bb
Sorry, fixed that. I just linked to some pics of the track and didn't take the time to resize them.
I assume that a hole will need to be made in the chasis for this method to work? I had thought simply using some servo tape and shoo goo.
Meradin is offline
Old 11-29-2011, 02:08 PM
  #3732
Yep you will need to drill a hole, you want to get the servo as close as you can to the middle without hitting the beltand as far forward without hitting steering crank (if you cut off the inside horns of you servo you can fit the servo post on the other side)
Drill a 2.5mm hole in the right hand steering crank as close as you can to the track rod ball, fit a ballstud and steering link, this will give you more servo throw which will give much smoother steering.
Shoegoo will work but it is a bu66er to get off if you need to
Bb
Old 11-29-2011, 02:25 PM
  #3733
Bigz84's Avatar
Trader Rating: 24 (100%+)
Are you using the H roll centers? If you are having issues w/ grip, use the L roll centers that come w/ the kit. I thought the same thing as you, but i just put the L roll centers in my T2 and the rear end is STUCK to the track. I converted my '11 car to a '12 and i am using the long link in the rear and the -.75 hubs, shocks laid down, 2.5 rear camber, 3.5 toe, and my 12 has a ton of grip. H roll centers are for high grip according to their web site and used to prevent traction rolling, which i can't see happening on such a small track like yours.
Shoe goo has been used at our track to hold the servo down on the '11s.
Bigz84 is offline
Old 11-29-2011, 09:42 PM
  #3734
kinga's Avatar
Drill a hole in the chassis and use one servo mount in the center of the chassis. Carefully drill out hole then carefully countersink with bigger drill bit.
THis thread should be renamed "Help Mera'din get his xray handlin' well! "
Lol
kinga is offline
Old 11-29-2011, 09:59 PM
  #3735
mazmorbid's Avatar
Trader Rating: 11 (92%+)
Lol
Better to buy a proper 45 deg countersink drill bit for like $8
mazmorbid is offline
