Xray T3 2011
#3631
Seems like lowering the rear hinge pins came up more than one and changing the rear toe to around 2 as well. I will give those a try. I need a simple place to start as the races are tonight and I haven't time for a rebuild.
Gonna keep the narrow front width as when I had it wider I couldn't make the turns, now I have plent of turn in. The trouble appears to be mid corner on power. The rear break loose as I don't think the weight is getting over fast enough.
So far I am going to lighten the rear shocks, reduce to 2 degree camber in the rear, and lower the inner suspension pin mounts.
Scoop, are you saying my droop needs to be closer to my ride height? As is stands now I have 2mm droop in the front and 3mm in the rear. I use those spaces to record my droop measurements, not the actual downstops as I find that changes from car to car. My numbers most likely 5 in the rear ans 6 up front if I had to guess. Wouldn't reducing the droop in the rear cause less weight to be shifted right to left as well as front to back. I think I need the weight to transfer right to left.
I did end up cutting the rear deck as many people have reported success doing it. If I don't like it I can always get a replacement.
-First thing to do would be to remove 1mm or 2mm of shims from the rear upright (where you now have 5mm). This alone should fix your lack of rear grip.
-Try 4 holes open for the pistons in the rear shocks.
-The next thing would be to try removing the anti-squat and going to -0.75 roll center holders all the way around in the back.
-The final change would be to shorten the wheelbase, you are running full long which can make the car more stable but reducing overall grip.
I would not have cut the top deck either, but oh well.
One other thing to consider is that your roll centers on the camber links are quite low (i.e. mounted up high), allowing the car to roll more. I can't see a mention in any of your posts about the type of track you race on, but if it's medium to high grip asphalt I think the roll centers are too low. I basically always ran my car with the L1/L2 holders in the lower/longer position on the shock tower.
#3632
Not sure I am the best to give a review of this. In fact the only reason I considered this was the positive reviews already given and the fact that the new 2012 model has a cut top deck already.
#3633
I may give this a shot down the road, don't have time tonight to change the piston over.
-One other thing to consider is that your roll centers on the camber links are quite low (i.e. mounted up high), allowing the car to roll more. I can't see a mention in any of your posts about the type of track you race on, but if it's medium to high grip asphalt I think the roll centers are too low. I basically always ran my car with the L1/L2 holders in the lower/longer position on the shock tower.
Here is a pic of the track
http://www.rctech.net/forum/9880636-post1333.html
#3634
I ran into a very similar situation with my car getting very loose mid-corner and not able to accelerate off the corner very strong without spinning out.
I discovered the T3'11 doesn't like much, if any, split in the front and rear shock oil. Especially if you have any tight turns to negotiate. Try dropping your front shock oil to 350cst, same as your rear shocks and see if that helps the rear end stick.
#3635
more rear camber, i'm at 2 degrees and 3.5 rear toe, sweeps 32 tires on carpet
take out 2 top deck screws in rear to give it more flex???
or something else??
any suggestions
#3636
So raise the rear arms all the way up?
I thought I had it slightly shorter but I will check. I need the stability down the staights and currently have plenty of turn in. I will experiment with this.
I am running in what others report as low traction carpet with rubber tires on a small track. 17.5 blinky.
#3637
yeah i did that too, it calmed the front end down from digging in to hard. that helped. i tend to get too loose at corner exit now. should i:
or something else??
any suggestions
or something else??
any suggestions
#3638
My only concern is reducing the steering too much as those are tight corners. My first race day was terrible and I couldn't get around those corners at all. I will take 1mm away and see what that does.
oops, misread that one!
Would you suggest moving the rear shocks up a hole? I remeber that being suggested and it shows on the basic rubber setup the rear shocks being in the middle while almost all of Pauls setup have the rear shock laid down.
#3639
Thanks, I wished that this was addressed somewhere in the setup book as clear ar you stated it. I know it has to do with the roll center but I like your description a lot better!
So far you are the only person I have read that even remotely suggests using them or imply using them. I have heard they are terrible and not to even bother with them.
Would shortening up the rear help? I need the steering but as I am still a novice driver the stability is a must!
I'd like to add that I am better with setup when the car is in my hand (especially if I can drive it myself) so all the advice I've listed are ideas for you to try. They may or may not solve or help your problems. One thing you will learn with car setup is that changes don't always result in the expected result!
#3640
I ran the rear shocks all the way down 99% of the time on the 2011. In the front I usually ran the 2nd hole from the outside (more responsive), sometimes the 3rd hole from the outside (more front bite, especially mid corner). Standing your rear shocks up more would reduce the side bite and rotation of the car, which I think is the opposite of what you are seeking.
Yup, everything I read I don't take at face value as there are so many differences in setup and conditions. You have provided me with exactly what I was looking for...a place to start.
As far as gettin your hand on the car, come on over to our track. We race every Friday night and you can run and tweak my car as much as you'd like!
#3641
or something else??
any suggestions
or something else??
any suggestions
For camber, I look at tire wear and adjust from there. If the tire wear looks pretty even across the entire tire, I adjust other things to gain grip. If you're getting a "death ring" on the inside of the tire [I've had this on the rear even], or the tire looks almost new on the outside 1/4 of the tread, try taking some camber out of that end, or work on reducing your camber gain and finding a new happy place on your roll center.
Front end settings can have an impact on rear grip on corner exit as well, too much ackermann, too much caster, etc.
Hard to give a firm answer on things to try without looking over your setup sheet.
#3642
I'm a little full trigger happy, but have been practicing to stop that. funny, when you think you drive slower, your lap times are better... anyway....
i'm running 2mm ackerman and just past 1mm of camber in the front and i'm still getting the ring of death. should i add a 1mm of bump steer under the steering block? on a setup station that is about how much it changes. rear tire wear is fine. rear shocks are laid down fully, 350cst oil and 3 holes open, 2mm camber. stock camber link setup. i sauce full rear and 1/2 of the front.
thanks for your info/help
#3643
I think the setup sheet should have the option of adding a URL or google maps geotag for the track layout or picture so we all know what the track looks like size and layout wise.
Here is a link to our track layout vids so you know what I am talking about in reference to setups.
http://www.wynnumrc.com/index.php/rc-videos
Here is a link to my current setup
http://forum.teamxray.com/xform/inde...&setup=t3_2011
#3644
Once you start getting the ring of death on a tire, you're not going to get it to go away, you can just adjust the camber and toe to try to prevent it from happening on a new set.
On my car, I think I'm between .5 and 1 degree in the front for asphalt, and run between 1 and 2 degrees in the front for carpet.
For bump steer, you want to shim under the steering link so that you have the least amount of bump steer from your ride height to full suspension compression you can manage.
#3645
Why don't you swing by my pit on sunday and we can get you some more rear grip figured out.
How many runs do you have on your tires??
LMK.
-James
