Old 11-14-2011, 04:48 PM   #3586
kinga's Avatar
Trader Rating: 15 (100%+)
Depends on what motor you are running. THe spec-r ones are only rated down to 10.5 turn motor, so if you run them in mod you are going to blow them out. I only run 17.5 blinky.
I have run these in the front for about 6 months with no issue
http://www.rc-mushroom.com/product_i...ducts_id=21442
Rebuild them often and keep them clean and you wont have too many issues
Ranthese in the back for about the same time with no issue
http://www.rc-mushroom.com/product_i...ducts_id=22106
I find using the ECS or any CVD with a spool creates wear and needs servicing often.
Using a front diff mitigates some of the wear
Ran the 52mm Xray shafts and the performance difference in 17.5 is not noticable
kinga is offline   Reply With Quote
Old 11-14-2011, 10:21 PM   #3587
Meradin's Avatar
Trader Rating: 19 (100%+)
Yeah, I know I don't need the esc in the rear, I don't think I stated it very clear. What I was intending to say was I didn't want to replace the fronts with the spec-r and also have to replace the rear shafts as well with the shorter regular shafts. I wanted to keep it cheap.
It is only going in my vta car to reduce the front spool chatter. Performance/smoothness would be nice but not the main point.
Meradin is offline   Reply With Quote
Old 11-15-2011, 04:37 AM   #3588
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Potoczak View Post
Thanks for the info guys, i will give it a try..
How'd you go? Post up some pics when you're done.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 11-15-2011, 04:55 AM   #3589
Regional Moderator
CarbonJoe's Avatar
Or you could just run a ball diff up front. Several of us have re-purposed our '007 foam cars for VTA. The foam cars had ball diffs front and rear.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-15-2011, 08:22 AM   #3590
Meradin's Avatar
So, what are the lengths of the spec-r ecs shafts? I know everyone says get the xray ones but I don't have the patience to wait until I have the extra dough to spend on them. I only race 17.5 and VTA which is 25.5. These would be installed in the VTA. I can pick up a set of spec-r's, new for about 37 bucks. That leaves me extra for race entry fees, parts, etc...
I do have an extra ball diff but from what I have read and been told the spool is a much better option and I want to reserve that for my 17.5 touring car.
My concern is going with a shorter shaft as I race on carpet with rubber tires on a very small track 90 percent of the time. The other 10% will be spent on large tracks.
Old 11-15-2011, 09:06 AM   #3591
MikeXray's Avatar
Trader Rating: 73 (100%+)
Why not just get a front gear diff and fill it with putty.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-15-2011, 09:42 AM   #3592
Midnight's Avatar
Trader Rating: 85 (100%+)
Can someone tell me what shocks are these? The upper part of the shock shaft is round, instead of having the part were you can adjust the adjustable shock pistons.
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 11-15-2011, 09:46 AM   #3593
Attachment 834219
xray aluminium ones by the looks of things, photo is small though!!
Mb3195 is offline   Reply With Quote
Old 11-15-2011, 10:11 AM   #3594
Johnny Wishbone's Avatar
If you're getting the spec-r the length doesn't really matter does it? Sounds like your mind is made up. The thing about the length measurements are that each manufacturer does them differently so even if spec-r gave you a "hard" number it probably wouldn't be the same as Xrays' 50 or 52, all you can do is trust spec-r, and if they say its for the T2/T3, that's what you will get. NOW, if you do get the spec-r and you think they are too short, put the 1mm spacer between the spool and the outdrive. (You will have to trim a 1mm plastic spacer so it will fit in the "0" cutout of the spool). I have had spec-r for another car and was very disappointed in their life span.
Gary Lanzer
Old 11-15-2011, 10:11 AM   #3595
Midnight's Avatar
Are they better than the stock ones?
Old 11-15-2011, 03:17 PM   #3596
Skiddins's Avatar
This has been a matter of debate for years.
In truth I don't think there's much difference.
If you've been offered them get them and fill them with different oil so you can change them over during a meeting.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-15-2011, 03:58 PM   #3597
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
Mine lasted 4 runs with a couple board knocks running 17.5 my xray ones havent even bent.
but its your choice lol
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 11-15-2011, 09:11 PM   #3598
Midnight's Avatar
Yeap they are aluminum. On some of the setups they read Droop: 2.5mms above ride height in front and rear. Can someone explain this in actual droop terms?
Old 11-16-2011, 12:18 AM   #3599
Meradin's Avatar
I can try as this is what I interpret it to mean. You settle the suspension and measure the ride height. Then, place the ruler again the car and lift the car by the shock towers. The point at which the tires come off the ground is the droop setting. You would turn the droop screws in or out so the wheels will come off the ground at the desired height, in your example, 2.5mm.
Old 11-16-2011, 12:22 AM   #3600
Meradin's Avatar
Also, compared to my T3'10, my '11 is pretty loud. I am pretty sure it is the gears but the mesh is fine. Anyone else find this? Where can I start the search? Everything spins freely, just noisy on the bench. I will see if I can post some video or something.
Also, what is the optimum weight for the '11? I don't see this stat on any setup sheets. How should I balance the car out? Even front/rear, weight more forward?
