Like Tree2Likes
Xray T3 2011
Old 11-14-2011, 01:21 AM
  #3571
smilekt's Avatar
Originally Posted by CraigM View Post
sorry .. could give me detail where to cut .. i don't see it ..
smilekt is offline
Old 11-14-2011, 01:27 AM
  #3572
Registered User
Trader Rating: 8 (83%+)
I have circled the area with a yellow circle for you
shano83 is offline
Old 11-14-2011, 02:24 AM
  #3573
kinga's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Midnight View Post
If a setup calls for 2 hole piston in the front and 1 hole in the rear on a setup sheet. What piston is that on the tree? 1-1,1-2,1-0 / 2hole or 1-1,1-2,1-0/ 3hole on the shock tree.
Usually when this is listed people are talking about the clicker pistons that are adusted from two to four holes. I believe the clicker pistons are .9 or 1mm piston holes.
the 1-1 1-2 and 1-0 pistons refer to the 1.1 1.2 and 1.0 mm hole pistons
Without the piston hole specified in the setup its hard to tell.
Use smaller holed pistons on smooth tracks, larger hole pistons on bumpy tracks
kinga is offline
Old 11-14-2011, 02:42 AM
  #3574
blade072's Avatar
Trader Rating: 98 (100%+)
glad im not racing against you....lol oh i am joking you know
blade072 is offline
Old 11-14-2011, 07:34 AM
  #3575
Originally Posted by Mera'din View Post
So, do you think it is a good mod to do on a small carpet track with rubber tires?
Absolutely, we had a race this weekend and even as the grip came up the car was the best I have ever driven it.
- Emil
Emil is offline
Old 11-14-2011, 09:36 AM
  #3576
smilekt's Avatar
Thanks shano
smilekt is offline
Old 11-14-2011, 09:46 AM
  #3577
smilekt's Avatar
smilekt is offline
Old 11-14-2011, 10:22 AM
  #3578
Midnight's Avatar
Trader Rating: 87 (100%+)
The setup is for a med size, med traction carpet track. He calls for 350 shock oil.
Midnight is offline
Old 11-14-2011, 01:05 PM
  #3579
Midnight's Avatar
So the stock 2 and 3 hole piston are 1.0 or 1.1? Thanks in advance.
Midnight is offline
Old 11-14-2011, 01:53 PM
  #3580
Meradin's Avatar
Trader Rating: 19 (100%+)
I hate to bring up the esc drive shafts again but I have done some reading on them which just means I am more confused than before.
I have a T3'11 for sedan that use the spool and stock 52mm shafts. It rattles but I am going to live with it for now.
i also have a t3'10 setup for vta. It rattles and I would like to try the ecs shafts on this as a test. I have heard from fellow racers that the esc shafts (xray/spec-r0 break easier than the stock shafts so I want to try them here.
Basically I see 3 choices...
52mm Xray
50mm Xray
Spec-r
The Spec-r shafts don't give a size so I that is were i get confused. I don't have the funds to switch the entire car over. The Spec-r shafts have a better price but how long are they? Will I notice a difference between the lengths if the front is 50mm and the rear is 52?
I'd go with the Spec-r shafts but not if it means replacing all 4 corners with new shafts.
Meradin is offline
Old 11-14-2011, 02:05 PM
  #3581
Regional Moderator
CarbonJoe's Avatar
You only need the ECS driveshafts on the front if you're using a spool. The rear uses a diff, so you don't need them there.
CarbonJoe is offline
Old 11-14-2011, 02:10 PM
  #3582
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
the spec r ecs shafts lasted me about 3 race days before the main solid shaft sheared into two. The XRAY ones are worth the money IMO.
R3VoLuTiOn is offline
Old 11-14-2011, 02:30 PM
  #3583
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Save Your $$- don't buy spec-r shafts and then have to buy xray ecs to replace the spec-r junk. Most folks are running 50mm ecs...
hanulec is offline
Old 11-14-2011, 02:36 PM
  #3584
oeoeo327's Avatar
Trader Rating: 75 (100%+)
Agreed. They're not cheap, but worth the investment.
oeoeo327 is offline
Old 11-14-2011, 03:17 PM
  #3585
jgraham37128's Avatar
Trader Rating: 25 (100%+)
52mm Xray
50mm Xray
Spec-r
I use Xrays 52 mm. I had the 50mm first but kept breaking the out-drives. Once I went to 52mm the problem stopped. Most people I know run 52mm in the front since you space it out with the shims. You don't need ESC's in the rear.
jgraham37128 is offline
