Old 11-08-2011, 03:59 PM   #3541
bjs227's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Potoczak View Post
Has anyone tried to deanodize the orange off?? if so what did you use?
I used an oven cleaner like easy off. Takes about 30-45 min on a standoff. Then i tried to 14k gold plate it but didnt turn out like i wanted!
Brandon J. Skewes A.K.A "Skittles"
genesisrcraceway.com - skewesjewelry.com - race-rewards.com
bjs227 is offline   Reply With Quote
Old 11-08-2011, 04:25 PM   #3542
Bigz84's Avatar
Trader Rating: 20 (100%+)
Default lighter rear diff fluid
what will be the car reaction be if i went w/ a lighter rear gear diff fluid, i am currently running 1000k xray on med/high bite carpet, 17.5 blinky.
thanks
Bigz84 is offline   Reply With Quote
Old 11-08-2011, 04:54 PM   #3543
Regional Moderator
CarbonJoe's Avatar
Oven cleaner, or "Greased Lightning". Basically, anything with sodium hydroxide will remove anodizing.
http://www.instructables.com/id/Remo...kly-and-Easil/
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-08-2011, 06:25 PM   #3544
Potoczak's Avatar
Trader Rating: 112 (100%+)
Thanks for the info guys, i will give it a try..
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-08-2011, 09:22 PM   #3545
Xpress's Avatar
Well ventilated area. That's all I'm sayin.
Xpress is offline   Reply With Quote
Old 11-09-2011, 03:26 AM   #3546
kinga's Avatar
Trader Rating: 15 (100%+)
thanks
Less on power steering. Should provide more rear traction in low grip situation.
Most people are running 1000-2000 in the rear on carpet. less than 1000 is usually reserved for low traction asphalt.
I run 17.5 blinky on med bite aspahlt and 800-1000 is perfect
kinga is offline   Reply With Quote
Old 11-09-2011, 03:35 PM   #3547
Midnight's Avatar
Trader Rating: 85 (100%+)
Were are you guys putting your weight on your cars to bring them up to weight?
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 11-09-2011, 03:42 PM   #3548
Skiddins's Avatar
I believe, at the front if you want to smooth out the steering, particularly at corner entry, the back.
If you want more aggressive steering into the corners put the weight at the back.
Or down the centreline near the middle if you want the handling to remain the same.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-09-2011, 03:49 PM   #3549
HarryLeach's Avatar
Send a message via AIM to HarryLeach
All of my weight is under the front belt on centerline since the car balanced so well with my electronics and battery. Haven't yet found the need to bias front or rear.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 11-09-2011, 04:44 PM   #3550
I like that ride
Crazed4wd is offline   Reply With Quote
Old 11-10-2011, 01:59 AM   #3551
redron123's Avatar
Trader Rating: 87 (99%+)
So whats the trick with the no o ring on the shock shaft? I tried leaving it off my shaft and all it does is suck air in through the bottom and blow it up through the fluid. What am i missing here?
check it out ----> www.ddatvinc.weebly.com D & D ATV PARTS INC.
redron123 is offline   Reply With Quote
Old 11-10-2011, 06:00 AM   #3552
Send a message via MSN to Emil
There is an option to put an o-ring on the shock shaft but I have never seen anyone use it on the Xray. Note that this refers to the outside of the shock at the bottom of the shaft.
Donīt try to remove the seals, that will not work.
Br. Emil
Emil is offline   Reply With Quote
Old 11-10-2011, 06:52 AM   #3553
redron123's Avatar
Br. Emil
Ok it had me confused because in the book it only shows the two o rings and it does not show a option on the outside.
Old 11-10-2011, 06:12 PM   #3554
Skiddins's Avatar
True, but that's what the setup sheet means.
It's used sometimes as a shock travel limiter, to help prevent grip roll etc.
It's very rarely used.
Just build the shocks as per the instructions.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-11-2011, 12:01 AM   #3555
waOscar's Avatar
Originally Posted by geubes View Post
how did I go on carpet? should I keep it on for Carpet this weekend?
I usually run on a decent/high grip but bumpy asphalt.
Ran the modified upper deck tuesday night with all screws, except stearing post, as suggested. I usually run the minimum screws in the standard top deck.
I liked the change a lot, at the moment our club is running a 17.5 blinky "all in" 4 week challange in touring, so can not compare to full speed modified driving. At the 17.5 speeds back to back testing was very positive.
Highly recomment trying the change for carpet as well.
Xray T3 2011 - my asphalt chassis
Xray T3 2011 - my carpet chassis
waOscar is offline   Reply With Quote
