Like Tree2Likes
Xray T3 2011
Old 11-06-2011, 01:18 PM
  #3511
kinga's Avatar
Trader Rating: 15 (100%+)
I had the rear upright top camber link screw rip out at the top on the weekend in a big crash, running the two hole. Would the one hole be less likely to pull out, as there is a bit more meat around the screw hole? I was running a grub screw in the secon hole in the upright as a precaution but didnt help
kinga is offline
Old 11-06-2011, 02:53 PM
  #3512
Skiddins's Avatar
How much of the screw was in the upright?
If you ran alot of shims it might be worth using a longer screw so it's just off touching the driveshaft on the inside of the hub carrier.
Skiddins is offline
Old 11-06-2011, 04:01 PM
  #3513
has anyone tried cutting the rear of their 2011 top deck?
I did it today to an old re-glued top deck (delaminated where the bearings are after a heavy impact in mod) and it seriously transformed the car and it was the fastest its ever been round my local track in a single lap. dropped 0.2 off my recent times.
this was on asphault.
I am very tempted to do the same to my non-bogged top deck, but with it being carpet season, not sure if its worth the risk?
geubes is offline
Old 11-06-2011, 05:39 PM
  #3514
nerdling's Avatar
What was the mod?
nerdling is offline
Old 11-06-2011, 05:56 PM
  #3515
yokemad's Avatar
Hi Guys
I'd Like to Let you Know That CSO Chassis For T3 2011 Is not Proper Carbon fibre ...
Only Top And Bottom Layers CF and middle is Fibre Glass ...
For your information
yokemad is offline
Old 11-06-2011, 06:06 PM
  #3516
kinga's Avatar
Was running 4mm of shims.
Was thinking of using a longer screw, but it goes quite deep into the upright as it is, not sure if I have the right length screw to fit.
I am not sure if it would have helped, I came off at full speed into a parked car in the carpark!
kinga is offline
Old 11-06-2011, 06:08 PM
  #3517
kinga's Avatar
Post some Photos Please!
kinga is offline
Old 11-06-2011, 07:08 PM
  #3518
Xpress's Avatar
Thread a set-screw into the hole you aren't using and it will keep the hole from deforming and help keep the screw from pulling out.
Xpress is offline
Old 11-06-2011, 07:51 PM
  #3519
kinga's Avatar
Was doing that, it didnt help lol.
kinga is offline
Old 11-06-2011, 09:30 PM
  #3520
Johnn27's Avatar
Trader Rating: 86 (100%+)
Thumbs up set up help??
Hi ,
changing over from rear ball diff to a spec-r gear diff what weight diff fluid should be good on carpet???
Thanks!
Johnn27 is offline
Old 11-06-2011, 10:02 PM
  #3521
blade072's Avatar
Trader Rating: 98 (100%+)
Originally Posted by yokemad View Post
Hi Guys
yep we know...i posted pics ages ago on this thread......i have the chassis....and i love it...
blade072 is offline
Old 11-06-2011, 10:30 PM
  #3522
CraigM's Avatar
Trader Rating: 34 (100%+)
Default Cut top deck
CraigM is offline
Old 11-06-2011, 10:37 PM
  #3523
blade072's Avatar
nice craig....and did you have screws in all the top deck holes except the steering brace ones???
blade072 is offline
Old 11-06-2011, 10:43 PM
  #3524
CraigM's Avatar
Yep, I never liked the feeling with the motor mount screws removed
CraigM is offline
Old 11-06-2011, 10:49 PM
  #3525
blade072's Avatar
thanks craig...i tried the car with all but 2 screws on the front bulkhead and steering brace first...went ok but then i put the missing 2 in the front....then it was great......i have a spare cso top deck i might experiment with now....
blade072 is offline
