Like Tree2Likes
Xray T3 2011
Old 11-02-2011, 09:22 PM
  #3481
jake95's Avatar
Trader Rating: 27 (100%+)
the smokem chassis works really good compared to the original xray chassis the smokem has allot more flex
jake95 is offline
Old 11-03-2011, 12:46 AM
  #3482
What size are the standard huddy droop setup blocks ?? the ones in the manual
Also just bought a used 2011.
How do I tell if a gear diff is Xray, 3Racing or Atomic etc (so I know what spares to get for it)
Cheers
1101 is offline
Old 11-03-2011, 01:50 AM
  #3483
blade072's Avatar
Trader Rating: 98 (100%+)
10mm mate...and if it is a real big chunky gear diff its probably a converted nt1 diff....
blade072 is offline
Old 11-03-2011, 05:12 AM
  #3484
M-Technic's Avatar
Trader Rating: 15 (100%+)
Well, that would depend on what tracks you race at and your setup preference. I would not want a more flexible chassis where I race.
M-Technic is offline
Old 11-03-2011, 06:58 AM
  #3485
Meradin's Avatar
Trader Rating: 19 (100%+)
A few more setup questions and I think I am done, until next week when i will have to retune my car depending on the outcome of the races on Friday!
On the setup sheet it lists "o-ring on shaft" as a setup option in the shock section. What is this referring to and how does it effect handling?
2nd - I think I want to try gear diffs. The spec r's have been updated so they don't leak if I remember correctly, or at least can be assembled in a manner that will prevent them from leaking. I just want to confirm though that you need to run 50mm drive shafts with them. You can't run the 52mm shafts that came with the car right?
Sorry, I know the gear diff thing has been discussed but I wanted a clear response so I cannot misinterpret/confuse the info.
Meradin is offline
Old 11-03-2011, 07:07 AM
  #3486
Xpress's Avatar
Placing an o-ring on the shock shaft is done to limit the compression of the shock. You can think of it as a bump stop. I kind of look at it as a band-aid fix for a car that leans too much or traction rolls. The last time I fiddled with external limiters it just seemed to make the car eratic...
Some people I know have had good luck with the spec-r diffs not leaking, but my luck has been hit or miss. I've got some that don't leak and others that I can't get to stop leaking. For the price of the spec-r diff + their aluminum outdrives you can purchase an xray diff that comes with the aluminum outdrives and doesn't leak a drop.
With the spec-r diffs you must run the 50mm driveshafts in the back of the car unless you want to widen the wheel track.
Xpress is offline
Old 11-03-2011, 07:09 AM
  #3487
yokemad's Avatar
tried both and recommend you to go for xray gear diff
yokemad is offline
Old 11-03-2011, 07:25 AM
  #3488
Meradin's Avatar
That was the overall feeling I got when initially reading about the diffs. With the Xray gear diffs you can run the stock driveshafts right?
I ask cause if one were to buy the spec-r gear diff and the corresponding drive shafts, the price would be about the same as just getting the xray gear diff, and it wont leak.
Also, the o-ring goes on the outside of the shock body right...on the shaft? That would limit the about of up travel on the shock.
It would be nice if all areas or options on the setup sheet were addressed in the setup manual. Maybe they are and i missed them in the countless times I have read and reread it!
Meradin is offline
Old 11-03-2011, 11:44 AM
  #3489
Default chassis mod
so much for needing to buy a new car
Pics below of both my non modified '11 and my now modified '11.
bucketboy is offline
Old 11-03-2011, 12:14 PM
  #3490
Attachment 829015
So did the mods make a "noticeable" improvement/difference?
nytryder is offline
Old 11-03-2011, 12:21 PM
  #3491
other than saving a bit of weight i have no idea, only done today and not going to be able to run it until next saturday
Old 11-03-2011, 12:25 PM
  #3492
RC MARKET's Avatar
Today some parts arrive can upgrade to 2012 Spec
Attached Thumbnails Xray T3 2011-xr-301132.jpg   Xray T3 2011-xr-301193.jpg   Xray T3 2011-xr-302086.jpg   Xray T3 2011-xr-302526.jpg   Xray T3 2011-xr-303087.jpg
RC MARKET is offline
Old 11-03-2011, 01:19 PM
  #3493
blade072's Avatar
awesome. as for chassis the cso racing one works really well
blade072 is offline
Old 11-03-2011, 05:32 PM
  #3494
yokemad's Avatar
This time Chassis cuts and top deck reminds me the BD5
@David
Do you have any Tweak issue with CSO Chassis?
Cheers
yokemad is offline
Old 11-04-2011, 01:25 AM
  #3495
blade072's Avatar
@David
Cheers
have had no problems what so ever with the cso chassis...best car i have driven...basicly had a t3 stock setup on it....only changes i had were 1 hole rear hubs and the exotek centre steering brace....oh and xray alloy shocks.....
Attached Thumbnails Xray T3 2011-xrayt311-large-.jpg   Xray T3 2011-xray-t311-large-.jpg
blade072 is offline
