Like Tree2Likes
Xray T3 2011
Old 10-28-2011, 10:52 PM
  #3466
Meradin's Avatar
Trader Rating: 19 (100%+)
Okay, I think i get it now. The +1 eccentric is a extra part you must purchase, not an adjustment on the kit.
Meradin is offline
Old 10-29-2011, 09:42 AM
  #3467
Xpress's Avatar
Yes part number 302077.
Xpress is offline
Old 11-02-2011, 02:53 AM
  #3468
at the weekend my son recived his new 2012, but before we started building it i laid the 2012 chassi over my 2011 and marked out the changes.
the main changes being narrower around the rear droop adjusters and larger
holes around the diff areas. (i already had the harder front hubs, diff and latest top brackets) we went testing last night at maritime racing. wow what an improvment to the 2011! and how good is the 2012! if you have a 2011
mister dremal is your friend !!!!!
shrek54 is offline
Old 11-02-2011, 04:26 AM
  #3469
Skiddins's Avatar
Was that using your current T3'11 setup on the T3'12, or kit setup on the new car?
Skiddins is offline
Old 11-02-2011, 12:51 PM
  #3470
Meradin's Avatar
Hey gang,
Thanks for your help and patience while I learn about this car and setup. Thank being said I have another noob question concerning droop gauges.
I have this set of gauges for measuring droop.
They look like the hudy ones mentioned in the setup manual but a little bit more affordable.
To measure Droop, all I need to do is put the car up on the blocks, stick the stepped gauge under the rear upright and viola, there is my measurement right?
I see many people say things like 2mm under ride height and such. If I do the above and set my droop screws to -2, would this give me the correct reading?
Is every car the same? It seems like one should have a base line measurement before using the gauges in this fashion. Or can I just use these to measure the downstop?
Meradin is offline
Old 11-02-2011, 01:47 PM
  #3471
Johnny Wishbone's Avatar
Hey gang,
No 2mm OVER ride height is very different than -2 on your droop blocks. That reading is taken with a ride height gauge, measuring ride height and then picking the car up until the wheels just unload from the surface and measured, this gives you the measurement of OVER ride height, orh. Under ride height doesn't exist, just OVER. There is no conversion to take a orh reading and convert it to a droop reading, its one or the other.
Johnny Wishbone is offline
Old 11-02-2011, 02:53 PM
  #3472
on the 2012 we started with the kit carpet setup, but raised the front roll centers and stiffened the roll bars front and rear by moving the little alloy balls in appx 5mm. going to 1.3 and 1.5 bars was to much. still a work in progress but much better than a the 2011 before the chassi dremel mod.
shrek54 is offline
Old 11-02-2011, 06:18 PM
  #3473
being a new owner of a 2011...where can i find this "dremel' mod?
nytryder is offline
Old 11-02-2011, 07:32 PM
  #3474
nerdling's Avatar
+1
nerdling is offline
Old 11-02-2011, 07:38 PM
  #3475
yokemad's Avatar
you need 2012 chassis to draw that holes under the diff and spool etc. over 2011 chassis after thAT dremel out the extra CF to make same Chassis Cuts like 2012 chassis....
yokemad is offline
Old 11-02-2011, 07:45 PM
  #3476
Bigz84's Avatar
Trader Rating: 23 (100%+)
Default chassis
looking to make a change to the car. i was thinking of swapping the chassis. i was thinking of either:
1) sticking w/ the stock, not sure if i really want to change, and risk dumping money into something i won't like...
2) Exotec
3) CEFX "11 stiff chassis, upper and lower
am i looking for pros and cons of each and what would be easier to drive.
I have a heavy trigger finger, which i am trying to stop thru practice, so i need something that can compensate for my bad driving, or am i dreaming a chassis can do that? i have tried numerous setups, haven't found one i'm dead set comfortable w/ yet. getting closer though.
any and all comments would be helpful
i run on carpet, med bite, but by the end of the day, it's high bite. running 17.5 blinky, rubber tires
thanks
Bigz84 is offline
Old 11-02-2011, 07:52 PM
  #3477
yokemad's Avatar
If I were you I could go for 2012 chassis and top deck Thats it
yokemad is offline
Old 11-02-2011, 07:55 PM
  #3478
Bigz84's Avatar
why? easier to handle? never considered that chassis, more to think about....
will all parts swap over? no alignment issues?
thanks for your input.....
Bigz84 is offline
Old 11-02-2011, 08:04 PM
  #3479
yokemad's Avatar
TBH If you keep your car Stock means You got more Support
With Different Chassis You should Find YOur Own Right Setup ,I dunno your Ability but IT was always easier for me to go Xray website and check some latest setups from all over the World and start from there...
Now Im using CSO Chassis for Last couple of months and couldnt find the same CF Quality and chassis was a bit Tweaked from Day one ...
I tried Exotek Chassis on T3 but Felt so Solid with no flex and Back end...
We all winding up sometimes that Xray optimized stuff but on serious side Xray and Hudy=quality
I hope That helps
yokemad is offline
Old 11-02-2011, 09:26 PM
  #3480
redron123's Avatar
Trader Rating: 87 (99%+)
What size lipos is everyone running? Im trying to shop for new lipos but im kind of stumped as what to get. I was told by someone who is very knowledgeable to get as big as i can get like around 5500 mah. This does not seem right. I thought the whole idea was to keep it light as you could with as much mah as you needed? I was looking at some of the Roar approved packs around the 4000mah area. I really like the looks and price of the protek ones but for some reason they decided to make it round like the old stick nicads. I was also looking at the Thunder power 4300 35c packs that say TBA in the roar approved section. I just want to get something that is consistent and all the same weight so i can get my t3 balanced and dialed in. I may also want to run these packs in my vta car too. Right now i have several packs for my two on road cars and they are all different sizes and weights. I like the turnigy packs to but they are out of stock.
redron123 is offline
