Like Tree2Likes
Xray T3 2011
Old 10-28-2011, 08:20 AM
  #3451
Xpress's Avatar
Originally Posted by Mera'din View Post
On the setup sheets it lists diff either being high or low and eccentric as being standard or 1. It appears to be two different settings. Right now I have my diff mounted high but I cannot find what the eccentric is.
The kit eccentric is the "standard." The optional +1 eccentric is further offset from center.
Xpress is offline
Old 10-28-2011, 08:24 AM
  #3452
Meradin's Avatar
Trader Rating: 19 (100%+)
So it is where the diff is located in the carriers ??(left to right)
How do you adjust this?
Meradin is offline
Old 10-28-2011, 08:47 AM
  #3453
Xpress's Avatar
It does not move the diff left to right as that is fixed. The +1 eccentrics will make the "low" setting lower or the "high" setting higher.
Xpress is offline
Old 10-28-2011, 09:44 AM
  #3454
Johnny Wishbone's Avatar
See post #1211 here http://www.rctech.net/forum/electric...rpower-81.html
The eccentrics are Q&A by Paul L.
Johnny Wishbone is offline
Old 10-28-2011, 10:40 AM
  #3455
yokemad's Avatar
Wow I was thinking lowering rear diff gives more rear end
Also does anyone have rear belt tension problem cos on normAl diff position rear belt feels too tight...
yokemad is offline
Old 10-28-2011, 12:01 PM
  #3456
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'd rather quit racing than change the hinge pin blocks again. Is there some trick to it?
syndr0me is offline
Old 10-28-2011, 12:36 PM
  #3457
Meradin's Avatar
Thanks for the info on what it does, but how do you do it? What do you adjust? I must be missing something in the manual but I cannot find info on how to actually adjust the setting. Do you add shims, flip something, etc...
Meradin is offline
Old 10-28-2011, 12:47 PM
  #3458
elee32's Avatar
Trader Rating: 18 (100%+)
pretty sure its where the notch on the plastic part sits in the grooves onthe suspension holder....notch at 6 o'clock=high diff, 12o'clock= low diff
may be completely wrong but that's how i read it
elee32 is offline
Old 10-28-2011, 02:02 PM
  #3459
Loosen the 4 hinge pin block screws then change one at a time, once done tighten the screws, check that the arms have no bind, re-set ride height and droop, go race.
Old 10-28-2011, 02:05 PM
  #3460
Rotate the eccentrics to tighten or loosen the belts, I usually start one notch less than what the assembly book calls for. OR 2 notches, but run a external belt tensioner. Kit setting is on the tight side.
Old 10-28-2011, 02:09 PM
  #3461
You are correct, although belt tension will dictate if the final settings are true 6 or 12 o'clock, the tension is more important than the reading. For the new guys make sure you rotate both sides of the eccentrics the same direction or the pulleys wont run straight in relation to the belts and idler pulley.
Old 10-28-2011, 02:17 PM
  #3462
Page 10 of the assembly manual, section 2, central transmission info.
Old 10-28-2011, 02:41 PM
  #3463
Meradin's Avatar
Nope, still don't get it. I have the manual in front of me and page 10 references the diff height and how to adjust the belt tension. The word eccentric isn't mentioned at all.
On all the setup sheets I have read it lists diff height and eccentric as different settings.
Diff height = highor low
eccentric = 1 or standard
Meradin is offline
Old 10-28-2011, 02:57 PM
  #3464
The +1 eccentrics have the hole that the bearing sits in located 1mm offset from center different than the stock standard ones. The same as the stock ones are not perfectly in the center of the holder the +1 are even more off set.
You do know what eccentric means right? In this case its the red ring in the assembly manual.
Old 10-28-2011, 05:21 PM
  #3465
Xpress's Avatar
The round plastic thingie that the bearings are in is an eccentric. You can run the diff high or low with the stock eccentric or a little higher or lower with the +1 eccentrics.
Xpress is offline
