Like Tree2Likes
Xray T3 2011
Old 09-25-2011, 07:38 AM
  #3256
Trader Rating: 36 (100%+)
Well, I made the choice to give TC another try after a few year break. Decided on the Xray t3'11 an now I'm looking to upgrade the chassis and was wondering what chassis everyone would decide on, the exotech or the smokem chassis'?
So if ya could tell me what your thoughts are on either chassis an why that would be great.
Thanks for any and all input.
Mike
NitroFreak2 is offline
Old 09-25-2011, 11:33 AM
  #3257
Meradin's Avatar
Trader Rating: 19 (100%+)
I have a question about esc's...even though this may not be the appropriate placde to ask this question.
Currently I am building my T3'11 and I was planning on running the Castle Mamba Pro I have. A fellow racer told me I would get much better lap times and smoothness if I switched to LRP speed controlls. Is he being a "brand-snob" or would the t3'11 really benefit from the switch?
One benefit I see is that it is a smalled speed control and would fit a little nicer as space is tight.
What are you t3 specific thoughts on either speed controll. I will be running it in 17.5 spec, rubber tire, carpet racing.
Meradin is offline
Old 09-25-2011, 12:59 PM
  #3258
cherokee95's Avatar
with your driving.......you'll never notice the differance
cherokee95 is offline
Old 09-25-2011, 05:14 PM
  #3259
kinga's Avatar
Trader Rating: 15 (100%+)
From my experience, in 17.5 stock/blinky there isnt alot of difference in speedy's, having said that of three i have used:
SPeed passion Cirtix: Cheap, ok speedy, brakes not as strong as others. Blown it up though, not as tolerant as other speedys when the motor thermals.
Hobbywing justock: Best bang for buck speedy, can get it for $55 around the traps, better brakes than the cirtix and little more tolerant of thermalled motors
SPeed passion GT2 LPF: Great speedy, great brakes, can be had for $95 if you look around on ebay. Great tolerance to thermalling motors, little bigger than the cirtix and Justock though
My reccomendation would be the Justock if u are new to the game
kinga is offline
Old 09-25-2011, 06:58 PM
  #3260
elee32's Avatar
Trader Rating: 18 (100%+)
Default gear vs ball diff
just started up carpet season and looking for some input/opinions on running a gear or ball diff with a spool in front. Running 17.5 blinky with a ball diff for now, have a gear diff and would like to get a rough idea of the pro's and con's of the gear diff
thanks eric lee
elee32 is offline
Old 09-26-2011, 10:10 PM
  #3261
Company Representative
OLD 69's Avatar
Trader Rating: 44 (100%+)
T3 2011 FEMCA Champion:
Setup here: http://forum.teamxray.com/xform/inde...&setup=t3_2011
Wide open, med/high grip track. Sweep Tyres (Low Grip)
Let me know if you have any questions.
...Ari
Attached Thumbnails Xray T3 2011-femca-1.jpg   Xray T3 2011-femca4.jpg   Xray T3 2011-femca5.jpg
OLD 69 is offline
Old 09-27-2011, 12:08 AM
  #3262
vazzo's Avatar
Trader Rating: 101 (100%+)
...Ari
XRAY FTW BABY!!!
vazzo is offline
Old 09-27-2011, 12:24 AM
  #3263
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
well t3 2012 is right around the corner. http://teamxray.com/ the main banner says it all
rx7ttlm is offline
Old 09-27-2011, 12:42 AM
  #3264
Registered User
Trader Rating: 8 (83%+)
...Ari
Congrats Ari well done!!! Hope to see you hear in SA for SA titles soon.
shano83 is offline
Old 09-27-2011, 05:49 AM
  #3265
Skiddins's Avatar
Mike
So far I'm please with the Exotek chassis.
My original chassis needed replacing so I went with the Exotek so I could try the rotated servo position.
Skiddins is offline
Old 09-27-2011, 06:11 AM
  #3266
M-Technic's Avatar
We will probably get the full presentation within a week then.
M-Technic is offline
Old 09-27-2011, 08:02 PM
  #3267
nerdling's Avatar
thanks eric lee
Hi Eric,
I've been playing arround with the XRAY Gear Diffs for a few weeks now in two different environments, tarmac with rubber and carpet with foam tyres. So far the downside of the gear diffs that I've found is that they are slightly more prone to causing a 'tank slapper' and its possible to snap a drive belt.
The upside is corner exit speed and reliability.
Last night at indoors (carpet with Foam tyres) I ran a ball diff in the rear (soon to be a gear diff with 2k oil) and a Gear diff in the front with 200k oil. My car was quick and consistent and easy to drive. If you are looking for a starting setup for Gear diffs this would be my sugestion.
Mark
nerdling is offline
Old 09-27-2011, 09:20 PM
  #3268
CraigM's Avatar
Trader Rating: 34 (100%+)
Mike
It depends what surface you are running on, the kit chassis is a very good all-rounder, the smokem should be good for low grip and the exotek may be best when the grip is up.
CraigM is offline
Old 09-28-2011, 12:46 AM
  #3269
PeterTaal's Avatar
...Ari
Congratulations, Ari !
What type of car do you drive ? A little pushing, more stable or fast reaction a bit oversteer ?
THX, PT
PeterTaal is offline
Old 09-28-2011, 05:28 AM
  #3270
OLD 69's Avatar
THX, PT
Thanks, I personally think my car is pretty neutral, if you drive smooth the car will have plenty of steering, if you push hard the car will push too.
Try the setting and let me know if you have any questions.
...Ari
OLD 69 is offline
