Old 09-23-2011, 08:30 AM   #3241
Meradin's Avatar
Trader Rating: 19 (100%+)
We run blinky mode, 4 min races. It may be a bit more, but not much. 700 is just what sticks in my head. Definately no more than 100 though! Once I went an entire race night on one battery without charging it. Got pretty tired towards the end though!
Meradin is offline   Reply With Quote
Old 09-23-2011, 10:44 AM   #3242
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
that is pretty amazing to run one pack all race.
700mah doesnt sound like youre gearing it enough though
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 09-23-2011, 11:36 AM   #3243
locked's Avatar
700mAh does seem to be a little low for 4minutes, but not that far off from what I use. For a 5 minute 21.5 blinky race, I usually end up using around 1200-1300mAh and just over 1500mAh for 6 minute races, so for 4 minutes my 21.5 car would probably use around 1000mAh. Maybe just a little under. I know I can get just over 20minutes of run time from my 5000mAh batteries before they hit the cutoff (found this out during a recent 500 lap endurance race)
If I was a little more gentle on the trigger and/or if I needed to be marshalled a few times, I could see it only using 700-800 in 4 minutes.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 09-23-2011, 05:17 PM   #3244
Originally Posted by kinga View Post
The two IP batteries, 5800 and 6200 60c batts are the two I use.
The 5800 & 6200++ etc batts are starting to get fairly heavy.
Does this mean the the 'lipo position/setup' option of the chassis shoudnt be used??
the lipo needs to be bought back into the chassis because of the weight of these heavier lipos??
Cheers
1101 is offline   Reply With Quote
Old 09-23-2011, 05:34 PM   #3245
HarryLeach's Avatar
Send a message via AIM to HarryLeach
My car balances fine with standard size electronics with a 289g battery, with ballast still needed to reach minimum weight.
I doubt I'll get a heavier battery any time soon, but I have room to move my electronics outboard to cover up to a 320g battery I figure.
[off-topic fortune telling]
The way the progression in RC seems to go, I'd venture to say the current trend for guys running the largest capacity they can for a higher ending voltage to gain any advantage they can find will probably be erased by longer mains.
Aside from 1/12, it wasn't that long ago that every electric class only ran 4min.
Battery capacity has more than doubled since 6 min. became the norm.
[/o-t f t]
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 09-24-2011, 04:30 AM   #3246
CraigM's Avatar
Trader Rating: 34 (100%+)
So, I got to race with Ronald Volker today
After 6 rounds of qualifying Ronald is TQ for the FEMCA ISTC Championships in Sydney this weekend, but XRAY is the best represented brand with 4 cars in the Amain including p2 and p3.
This is the first time I've seen a pro driver race and man is it awesome! I'm not sure if you guys have consistency/standard deviation scores in your race software but Ronald managed 0.08 in a 16 lap run today, that's robot precision! Umino and Masami are here too, it's all very cool
It's finals day tomorrow, I'm p6 & hoping to finish that high but there are some real guns behind me so we'll have to see. Hopefully there will be someone videoing, the track is super cool
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-24-2011, 07:57 AM   #3247
M-Technic's Avatar
Trader Rating: 15 (100%+)
Good luck Craig!
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 09-24-2011, 09:41 AM   #3248
Trader Rating: 30 (94%+)
That sounds like an awesome time. Good luck!
Rocky8333 is offline   Reply With Quote
Old 09-24-2011, 05:20 PM   #3249
vazzo's Avatar
Trader Rating: 100 (100%+)
Does anyone know how many teeth the gear diff has from xray?
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 09-24-2011, 05:26 PM   #3250
kinga's Avatar
Good work Craig, I see you are giving the Brisbane boys some stick too! U running that new smokem chassis there?
kinga is offline   Reply With Quote
Old 09-24-2011, 05:34 PM   #3251
Trader Rating: 8 (83%+)
Talking about smokem chassis i got one on the way.I have been using the exotec one atm and found it to be quite nice.So im looking forward to trying the smokem.
The lovely wife bought it for our 1 year aniversary gotta love it
shano83 is offline   Reply With Quote
Old 09-24-2011, 05:41 PM   #3252
HarryLeach's Avatar
38t
Old 09-25-2011, 02:19 AM   #3253
t32011's Avatar
Im interested to see how the smokem chassis goes aswell.
t32011 is offline   Reply With Quote
Old 09-25-2011, 05:20 AM   #3254
CraigM's Avatar
Well bad news, the FEMCA finals were rained off today, so the results went on qualifying. While Ronald won the event, as he is not a member of the FEMCA block the FEMCA champion was actually XRAY driver and aussie team principal Ari Bakla. I'm sure Ari will post his setup soon, it will be under the handle NBHC on the XRAY site... It's very close to kit, gear diff up front with putty, shorter rear wheelbase and front shocks leaned in one hole
I didn't use the smokem chassis - mine didn't arrive in time. I did see one mounted though and it has a lot of flex, plarticularly around the front suspension bridge. Compared to the tamiya the XRAY with the FX chassis has less flex at the rear because of the bulkhead design, so it'll definitely have ample steering, hopefully it will also have enough rear grip!
I'll post my setup soon, my car was awesome to drive all weekend, again pretty close to kit and only 4/10ths a lap slower than Ronald
Edit: here is some of the action http://www.youtube.com/user/TeamYoko.../0/aIggTNpEBnA
... Nearly forgot, Masami presented the trophies!!!
Old 09-25-2011, 06:31 AM   #3255
nerdling's Avatar
Originally Posted by hana166 View Post
T311 is a very impressive car, especially on carpet. Been getting fastest laps all over the place since I got mine a few weeks ago. Kit set up is utterly awesome. Its a real pleasure to drive.
On the anodising, Yeuccch. Had to be changed
your car looks awsome. kind of like Darth Vaders XRAY
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
