Like Tree2Likes
Xray T3 2011
Old 09-19-2011, 12:27 AM
  #3196
veecee's Avatar
Trader Rating: 34 (100%+)
Here's a photo of my updated Smokem T3FX via my crappy phone cam... Has 3 servo positions - original T3, T3-11 and T3-11 with horizontal servo.
veecee is offline
Old 09-19-2011, 12:50 AM
  #3197
CraigM's Avatar
Originally Posted by kinga View Post
SMokem or exotek Craig? I am thinking of one or the other for medium traction asphalt. Was looking a the zeppin racing one on rcmushroom but it doesnt have the 90 east west servo mounts.
I found the exotek a bit stiff for our track. I'll post how the smokem goes once I have it bolted on, the fx deck used to be awesome on my 416
CraigM is offline
Old 09-19-2011, 05:37 AM
  #3198
Skiddins's Avatar
Really
It's thinner and narrower than the original.
Skiddins is offline
Old 09-19-2011, 05:46 AM
  #3199
kinga's Avatar
Trader Rating: 15 (100%+)
I noticed it the exotek doesnt have any holes cut in it at all. The original xray chassis has a few holes in it for older lipos.
The thing I have noticed is the schumacher is particlularly fast at our track. THe schumacher standard chassis is 2mm thick. The schumacher carpet chassis is 2.5mm
The standard xray chassis is 2.5mm, and the exotek is 2.2mm
There are a number of after market chassis, just trying to figure out which one is the best.
kinga is offline
Old 09-19-2011, 07:27 AM
  #3200
Exotec uses premium quasi weaves carbon, so their chassis' are nice and stiff.
trigger is offline
Old 09-19-2011, 09:16 AM
  #3201
yokemad's Avatar
very true
t3 chassis Ive tried was really stiff ...
yokemad is offline
Old 09-19-2011, 01:59 PM
  #3202
redron123's Avatar
Trader Rating: 87 (99%+)
What's a good pinion to start with? I have 17.5 motor stock 84 spur. I got a whole set of hudy pinions. I just don't want to burn motor up. I'm kind of new to on road. I don't know what kind of fdr I'm shooting for. Sorry about newbie questions.
redron123 is offline
Old 09-19-2011, 02:38 PM
  #3203
Robertcooper88's Avatar
It really depends on a lot of things such as trac type, ESC settings etc. But I think a 6.2 FDR is a goos starting point for outdoor asphalt. I ran a 6.7 this weekend on a small carpet track. Hope tha helps.
Robertcooper88 is offline
Old 09-19-2011, 02:49 PM
  #3204
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
start around 5.5. If you're topping out 1/4 into the straight, you're under geared, try a bigger pinion. After a few minutes, check your temps and go from there
R3VoLuTiOn is offline
Old 09-19-2011, 02:53 PM
  #3205
Johnny Wishbone's Avatar
Need more info. How big is the track? Boosted or Blinky? What kind of motor?
Johnny Wishbone is offline
Old 09-19-2011, 02:58 PM
  #3206
redron123's Avatar
Its a indoor carpet track with good traction and a few tight spots.
Old 09-19-2011, 03:09 PM
  #3207
redron123's Avatar
I'm just really looking for a good starting point. I will be running either ballistic 17.5 or tekin 17.5 with a tekin rs esc. What's a good temp to look for to know if I need to go up or down?
Old 09-19-2011, 03:24 PM
  #3208
CraigM's Avatar
Originally Posted by Skiddins View Post
Really
Definitely stiffer than stock. It's slightly narrower overall but it's wider near the inboard suspension bridges, the stock chassis is more aggressively shaped in those areas. I'm guessing that plus the weave accounts for why a 2.25mm chassis would be stiffer than a 2.5.
CraigM is offline
Old 09-19-2011, 06:53 PM
  #3209
kinga's Avatar
I am running stock 17.5 blinky, FDR of about 4, rollout around 55. Temping the motor at around 60 degrees
Really depends on the motor and how much timing you are running on the endbell
Use gearchart.com to work out your preferrred combination of spur and pinion.
While on this, is there any benefit to using a larger spur and smaller pinion to obtain the same gear ratio? Or vice versa
kinga is offline
Old 09-19-2011, 07:12 PM
  #3210
HarryLeach's Avatar
I usually run 17.5 Boosted, geared around 6.3FDR.
I try to run the biggest spur I can all the time, seems to help make the brakes a bit stronger and more consistent.
HarryLeach is offline
