Old 09-04-2011, 11:58 AM   #3061
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by blade072 View Post
you have to cut the shafts down 1.5mm correct???? and do you guys use the bladders still???? can you use the xray shafts and pistons with the tamiya shocks???
All tamiya apart from the plastic top and bottom. Cut about 1mm of thread off the piston
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-04-2011, 02:41 PM   #3062
syndr0me's Avatar
Trader Rating: 32 (100%+)
So the XRay plastic pieces are a direct fit? Just 1mm off the threaded end of the piston and you're set?
syndr0me is offline   Reply With Quote
Old 09-04-2011, 04:25 PM   #3063
yokemad's Avatar
i think you should do some dremel job on top alloy bit to fit xray top plastic part....
yokemad is offline   Reply With Quote
Old 09-04-2011, 04:37 PM   #3064
Johnny Wishbone's Avatar
Top shock cap has to be opened up for the stock Xray piece. Hagberg seems to think the Xray springs are the way to go for carpet. HPI for asphalt.
Gary Lanzer
Old 09-05-2011, 02:35 AM   #3065
CraigM's Avatar
Full instructions:
These are the dampers
http://www.rcmart.com/catalog/rc-dam...8-p-26673.html
To make them work properly on the xray you need to use the xray shock top and bottoms, you can either take them off your plastic shocks or get 2 x 308302.
In order to get everything working right together you need to make a couple mods
* Drill out the tammy cap to take the xray shock top
* Trim 1-1.5mm off the piston to get the correct length
* Sand down the lip on the underside of the xray cap that retains the bladder to about 0.5mm to prevent it cutting the tammy bladder
There's not a lot wrong with the xray shocks but I definitely prefer my car on the tamiyas.
Old 09-05-2011, 03:26 AM   #3066
Send a message via MSN to Emil
Originally Posted by CarbonJoe View Post
Thanks!
Emil is offline   Reply With Quote
Old 09-05-2011, 10:16 AM   #3067
syndr0me's Avatar
Perfect, thanks!
Old 09-06-2011, 05:08 PM   #3068
yokemad's Avatar
Hi ALL
Has anyone Tried SPEC-R Steering Blocks?
If so How good They are compare to Xray ones???
Cheers
Old 09-06-2011, 05:53 PM   #3069
Spec R plastics are harder, but more brittle, they also are molded with better tolerances around the bearings so less slop where the bearing seats.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 09-06-2011, 09:07 PM   #3070
markiemark's Avatar
Trader Rating: 23 (100%+)
Hey im trying rebuild my xray shocks and i keep getting negative rebound in my one shock when i full pull the shock shaft out how can i fix this using new bladder new orings and everythings smooth.
~ ~Blue Diamond Park Raceway~~
~~~~D Main Champ~~~~
markiemark is offline   Reply With Quote
Old 09-06-2011, 09:16 PM   #3071
Regional Moderator
CarbonJoe's Avatar
Add some oil.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 09-07-2011, 01:40 AM   #3072
blade072's Avatar
Trader Rating: 98 (100%+)
thanks craigm on the info on how to convert the tamiya shocks.....they do look nice
also heard the atomic alloy bodies are worth trying also.....
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 09-07-2011, 03:25 AM   #3073
Thinking about replacing all my bearings(not ball diff bearings). I ve had 2 crap themselves. What are the best replacement bearings for the T3?
rayrush is offline   Reply With Quote
Old 09-07-2011, 04:58 AM   #3074
Regional Moderator
CarbonJoe's Avatar
Hard to beat ones from Avid for $1 each. http://www.avidrc.com/
You can get both sides rubber sealed, one side rubber/one side metal, or both sides metal shielded. I just replace them when needed. The outer hub bearings take the most abuse. Just pitch them when they aren't smooth anymore.
Old 09-07-2011, 07:41 AM   #3075
markiemark's Avatar
Ok i keep addin oil then i get to much rebound so i unscrew top cap 1.5 turns push the shock shaft and then tighten cap to try and get 0 rebound. But seems once i get zero rebound i get a small negative rebound when fully extended. I got tired after 2 hrs off and on messing with them and got both to 20% rebound and left it as that. But now time to do fronts and not looking foward to it.
Add some oil.
