Old 08-22-2011, 06:11 AM   #2911
yokemad's Avatar
Originally Posted by kinga View Post
Just spent all evening trying to get the zepping racing steering brace/ center steering link bridge working. It makes the steering arms rub on the front belt when turning left/right. Dont bother, spend the extra cash and get the exotek one.
I tried every conceivable orentation and when installed, the steering ball caps rub on the belt when turning the wheel left to right. Its only 2 or 3mm off, but its enough
Thanx for the info...
yokemad is offline   Reply With Quote
Old 08-22-2011, 06:35 AM   #2912
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Originally Posted by E-clip View Post
The caps were on very tight when I tryed to unscrew them
thanks
I struggled the same. Get rid of those bladders and use the bladders in the Hot Bodies Cyclone. They cost about $4 and are way better than the stock xrays. I could build the shocks perfectly everytime with the HB bladders whereas it was a gamble with the old bladders and more than likely would rip the same as you.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 08-22-2011, 06:57 AM   #2913
blade072's Avatar
Trader Rating: 98 (100%+)
you need to raise the ball on the zeppin brace 6mm atleast.....look at shano83 pics....the exotek has it built in to its brace......as for rubbing dont think his does.....
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 08-22-2011, 07:14 AM   #2914
kinga's Avatar
Trader Rating: 15 (100%+)
I think I know what you are getting at, Its the balls that attach the steering arms to the brace that rub on the lower part of the belt, not the ball that connects to the servo saver.
I have had a good look at it, if you flip the diff to the lower position it doesnt rub, or you could raise the two mounting posts with spacers to get the 2 or 3mm needed. Neither really appeal to me.
Any suggestions welcome, otherwise I will be adding the exotek steering brace to my shopping list( good excuse to buy the chassis to save on postage!)
kinga is offline   Reply With Quote
Old 08-22-2011, 07:20 AM   #2915
blade072's Avatar
look at the pic of the exotek setup.....uses more spacers as they put the servo link parallel..... whats a couple of spacers underneath compared to on the actual saver......wish everything could be perfect.....but there is no such thing in life....
David Randall
Old 08-22-2011, 07:42 AM   #2916
Fred Hubbard's Avatar
Originally Posted by syndr0me View Post
Any idea why Nexus would delete the gear diff from their site?
I see items disappear and the reappear on their site, it seems to maybe be a glitch or something. I quite sure they are still selling them
EDIT: I just checked and it is listed on their site but it is out of stock at the moment.
I have just gone to rebulid some 2nd hand shocks I brought to find that the bladders in all four shocks were ripped around the lip with only about 2mm left holding it together.
The bladders are the new 2011 low membranes.
Has anyone else had this happen to them ??
or is this some team speed secret ??
I don't see how they could be torn like this
The shock caps also had been drilled out and plugged with grub screw for rebound I guess
This has happened to me before as well. When you put the cap back on only tighten it to the point to when it starts to give resistance when turning. This will leave about .75mm to 1mm of space between the cap and the shock body. You don't want to tighten the cap all the way down as this forces the bladder into the shock body which damages it by smashing the bladder lip as well.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 08-22-2011, 07:43 AM   #2917
kinga's Avatar
Have you installed your zeppin brace yet blade? Just wondering if the flat side should go up or down. with the flat side up, as the orginal xray brace is installed, it rubs. With the two humps facing up it should fit, but the bearings are the wrong way round
Old 08-22-2011, 01:18 PM   #2918
32819toon's Avatar
Originally Posted by yokemad View Post
Hi All
Whats the Bodypost option on the Front shock Tower For?
Cheers
Hi, I'm interested in this option, can you paste a link, or some more info.
Thanks,
32819toon
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 08-22-2011, 02:07 PM   #2919
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Thanks,
32819toon
Nothing complicated, just mount a rear body post to the front shock tower. The stock XRay rear mounts fit, I'm using an HPI body post I had laying around.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 08-22-2011, 11:30 PM   #2920
arn671's Avatar
Default Xray T3 Gear diff
This question is for guys that have the new T3 gear diff and a converted NT-1 Diff. Wondering if anyone can compare the lengths of the outdrives of the NT-1 diff and the outdrives in the new gear diff. Just noticed that the gears are the same as the composite gears that are in the NT-1 Diff. I'm wondering if I can just buy the diff case and o-rings for the new diff, and use the internals of the NT-1 diff that I already have. It's nice to not have to switch to the 50mm axles. Thanks in advance
arn671 is offline   Reply With Quote
Old 08-23-2011, 01:15 AM   #2921
Do you drill the body for this 3rd front post , or does it sit under the body only ??
Cheers
1101 is offline   Reply With Quote
Old 08-23-2011, 06:22 AM   #2922
sohlman's Avatar
Trader Rating: 89 (100%+)
Cheers
Not sure about everyone else, but mine just sits under the body. I also use Tamiya rear body mount spacers to push the mount back further towards the bottom of the windshield. I can take pics later tonight.
Steve Sohl
sohlman is offline   Reply With Quote
Old 08-23-2011, 06:39 AM   #2923
kinga's Avatar
I put a hole through the body with a body hole reamer, then put the post all the way through with a body clip on top, without the clip it is just preventing the body from pushing down.
Cheers
Old 08-23-2011, 06:43 AM   #2924
Ron-Z's Avatar
I also have a T3'11 XRAY car is my favorite, I also give you a few days being counted!
Ron-Z is offline   Reply With Quote
Old 08-23-2011, 06:48 AM   #2925
HarryLeach's Avatar
Cheers
Yes, 3rd hole.
