Like Tree2Likes
Xray T3 2011
Old 08-14-2011, 07:50 PM
  #2836
mikel33's Avatar
Trader Rating: 2 (75%+)
Originally Posted by elee32 View Post
xray or RW make good 64p spur gears and any 64p pinions will work
Far as I know, Xray and RW are your only choices. The Xray are actually cheaper.
mikel33 is offline
Old 08-14-2011, 08:22 PM
  #2837
blade072's Avatar
Trader Rating: 98 (100%+)
zeppin racing now make xray spurs in both 48 and 64 pitch
blade072 is offline
Old 08-14-2011, 10:09 PM
  #2838
Johnny Wishbone's Avatar
Originally Posted by Team Speedy View Post
Anyone here have any "firm" testing of the Xray "hard" plastic vs the "medium" composite. Is there an advantage to one? I.e. less prone to breakage, more grip, tunability, etc? If so, perhaps you could explain your findings. I've tried to read up in older threads but never seem to hit the answers I've wanted over time.
Secondly, does anyone still run the aluminum hardware, (knuckles, hubs, c-hubs) that was a popular trend back in the 04' - 08' days? I wasn't sure if something like that was worth considering to keep. If it helps at all I run on both carpet and asphalt so different perspectives of both would be great!
Maybe slightly more traction but definitely a more positive feel but less forgiving to the car.
The aluminum parts feel more like medium parts but more prone to bending rather than breaking which can lead you astray if chasing a ill handling car. The unsprung weight is a disadvantage as well, but the durability can't be overlooked. If I'm at a track where I'm taking out parts I'll switch over just to make sure I can finish. Most notably are the rear uprights, if you're smacking a board enough to loosen the top camber link I'd consider changing just to keep the car setup more consistent and durable over the slight performance change the part makes.
Johnny Wishbone is offline
Old 08-15-2011, 06:06 AM
  #2839
My T3'11 is getting pretty worn out it was converted from a T3 and has done alot of racing. I don't want to buy lots of parts and it is also going to need a chassis soon. I keep looking at other cars but the Xray has been a good car, how long before a new version will be out ?
Thanks.
S.A.W is offline
Old 08-15-2011, 06:15 AM
  #2840
yokemad's Avatar
I reckon within 2-3 months time as usuall...
But I dont think Its not gonna be a radical change new chassis for servo and top deck +2 more screw point on top deck near spurgear... you can see @pic.
yokemad is offline
Old 08-15-2011, 12:16 PM
  #2841
haywood's Avatar
Trader Rating: 49 (100%+)
Default Servo Mod.
Anyone help me out with info on this and parts need? Thanks
haywood is offline
Old 08-15-2011, 12:55 PM
  #2842
yokemad's Avatar
You need some servo tape that's all...
yokemad is offline
Old 08-15-2011, 12:58 PM
  #2843
haywood's Avatar
Default Servo Mod.
Longer linkage? Where does it connect?
haywood is offline
Old 08-15-2011, 01:03 PM
  #2844
Go to the xray web site (http://forum.teamxray.com/viewtopic.php?f=8&t=11252) and in the forum section the question was asked of Alex Hagberg, lots of pics and description on how to do it.
  #2845
yokemad's Avatar
P.s Pic. belongs to Alex H.
yokemad is offline
Old 08-15-2011, 07:30 PM
  #2846
kinga's Avatar
Trader Rating: 15 (100%+)
Here is the method I used. Drilled hole in the right hand steering arm for the stock ball to mount to.
Works well, done a couple of race meets on it so far.
You have to chop off the old servo turnbuckle mount, so you will ned to buy new arms if you want to go back.
Attached Thumbnails Xray T3 2011-2011-08-16-08.32.35-small-.jpg   Xray T3 2011-2011-08-16-08.33.08-small-.jpg
kinga is offline
Old 08-15-2011, 09:57 PM
  #2847
Registered User
Trader Rating: 8 (83%+)
Or check out rcmushroom zeppin racing has a steering link specifically for the t311. I have bought and looks good and exact fit. If ya need some pics let me know. I also just kitted the car out on an exotek chassis with the steering mod
shano83 is offline
Old 08-15-2011, 11:15 PM
  #2848
kinga's Avatar
Got one of those on order from rcmushroom! Have you tested the exotek chassis out yet? Improvement over stock?
kinga is offline
Old 08-16-2011, 12:21 AM
  #2849
blade072's Avatar
just got my t311 cso racing chassis.....i must say its very nice indeed....let the building begin....i also have the zeppin racing brace...but i do like what i just saw above....very nice...
blade072 is offline
Old 08-16-2011, 12:28 AM
  #2850
Registered User
Nah havent tested the chassis yet but providing no rain this weekend i will!!!!
shano83 is offline
