Like Tree2Likes
Xray T3 2011
Old 08-13-2011, 08:22 AM
  #2821
hacker's Avatar
Trader Rating: 141 (100%+)
Originally Posted by CraigM
Only ones I've seen are zeppin - haven't tried them. I think one of the HB belts also fits but I don't know if it's the front or rear. So sick of the xray belts, they are sub par compared to the tamiya low frictions
thanks, I ended up getting some Japanese made belts from ebay, but do not know what brand they are. Half the price of xray belts. Hope they last longer, only had about 30 packs through mine.
hacker is offline
Old 08-13-2011, 08:28 AM
  #2822
kman16jr's Avatar
Trader Rating: 56 (100%+)
What is the tooth count on the t3 belt and which belts work on it besides the xray belt?It seems like my old tc5r that my buddy has never goes through belts,it is the original belt and looks brandnew,if the ae belt works works ill buy those.
kman16jr is offline
Old 08-13-2011, 10:54 AM
  #2823
Trader Rating: 15 (100%+)
Default Belts
What issues are you guys having with the belts? Mine always look like new and have never broke. Is it possible they are rubbing on something or maybe the setscrew in the pinion is chewing them up?
AARON YOUNG is offline
Old 08-13-2011, 11:23 AM
  #2824
Johnny Wishbone's Avatar
1+, please explain.
Johnny Wishbone is offline
Old 08-13-2011, 12:52 PM
  #2825
rocafella's Avatar
Trader Rating: 19 (100%+)
Questions?? spur gears & pinions 64P
hi all, i am completely new to on-road vehicles and just got my XRAY T3 2011.
was wondering which brands and models of pinions and spur gears i can use for my vehicle on 64P setup?
thank you all so much and sorry if I am re-posting these questions.
rocafella is offline
Old 08-13-2011, 02:28 PM
  #2826
Brokin Racing's Avatar
Trader Rating: 74 (100%+)
You might find lack of experience with Xray's (eg; how to tension them) is some folks biggest drama re belts,
I've run most classes including drag spec with is more powerful than any mod you'll get & have never had a problem with Xray belts
One young guy (Ben C) from our group who runs mod consistantly has had the same belts on the car for 12mths..
Brokin Racing is offline
Old 08-13-2011, 06:14 PM
  #2827
blade072's Avatar
Trader Rating: 98 (100%+)
both zeppin and spec r belts are fine......are using both still.....my rear belt is a rubber one...and is still going strong....
blade072 is offline
Old 08-13-2011, 11:33 PM
  #2828
blade072's Avatar
just had a look at a t311 with exotek chassis and zeppin racing steering brace for the servo position mod....then i looked at a serpent s41l...the steering mount points look so similar....has anyone thought of trying the serpent bellcrank system on the t311 for the servo mod???
blade072 is offline
Old 08-14-2011, 12:03 AM
  #2829
blade072's Avatar
http://www.rc-mushroom.com/product_i...ducts_id=23131
another new chassis on the market which i just found....hmmmm
blade072 is offline
Old 08-14-2011, 04:46 AM
  #2830
kinga's Avatar
Doesnt look like that zeppin chassis supports the east-west servo mod. There is blank space where you would normally drill the new hole for the servo mod
kinga is offline
Old 08-14-2011, 05:02 AM
  #2831
blade072's Avatar
yeah looks like a flex version of the standard t311 chassis...
blade072 is offline
Old 08-14-2011, 12:55 PM
  #2832
fullout's Avatar
In a pinch I needed a rear belt for my t3 11 today, so I tried a TOP one that was the same length as the xray and it worked fine, seems a bit more beefy(in a good way) also.
fullout is offline
Old 08-14-2011, 01:00 PM
  #2833
fullout's Avatar
I must say this also, I have been running the belt that snapped for a good 6 months in boosted 13.5 and 17.5 and it worked perfect.
But then i put in a 5.5 without tightening the belt and sure enough the torque was just to much for my particular tension setting(user error).
Also based on what i have experienced it seems a gear diff in the rear works the belts harder because there is zero give when applying power, where a ball diff may give just that amount of slip to lesson the torque on the belt, in turn saving the belt.
My 2cents
fullout is offline
Old 08-14-2011, 03:59 PM
  #2834
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
I am not sure if it's a motor output change or a change in belt vendors but I have noticed that the belts have more of a tenancy to twist than before. I have yet to have one twist on my cars but I have seen other peoples cars actually fully rotate the belt. The optional tensioner helps with this.
rx7ttlm is offline
Old 08-14-2011, 05:47 PM
  #2835
elee32's Avatar
Trader Rating: 18 (100%+)
xray or RW make good 64p spur gears and any 64p pinions will work
elee32 is offline
