Like Tree2Likes
Xray T3 2011
Old 08-09-2011, 06:22 PM
  #2791
kinga's Avatar
Trader Rating: 15 (100%+)
How do you guys find the new front/rear bulk heads with the top mount camber links? Are they worth the upgrade? THe cheapest I have seen them is about $40 a set, which for front/rear is around $80 plus ball links and spacers etc will be reasonably expensive upgrade.
I have seen them on most of the post pictures in this forum.
kinga is offline
Old 08-09-2011, 10:28 PM
  #2792
CraigM's Avatar
Trader Rating: 34 (100%+)
If I was upgrading again I would just get the front clamps and some one hole rear hubs. I've played with different link lengths & heights a lot but I always end up going back to L on the rear, on the front I use the middle hole a lot and all sorts of heights
CraigM is offline
Old 08-10-2011, 03:39 AM
  #2793
I had them front and rear. I found that at mid - high speed the car was more stable but anything below mid speed, or breaking from high speed, the rear of the car was unpredictable. I had to change my setup quite a bit so i put "L's" back on untill i have the spare time available to do some testing with them.
RSCosworth is offline
Old 08-10-2011, 05:19 AM
  #2794
sohlman's Avatar
Trader Rating: 91 (100%+)
Originally Posted by shano83
I run mod and have never broken any outdrives yet
I too never "broke" them running mod, but I did wear about a 1mm+ groove inside them. This obviously caused an abrupt power delivery. I would have to replace them after every race weekend.
sohlman is offline
  #2795
yokemad's Avatar
top camber clamps are £38 a pair here in UK comes to £76=$124 wow
yokemad is offline
Old 08-10-2011, 05:29 AM
  #2796
blade072's Avatar
Trader Rating: 98 (100%+)
i also have never broken any outdrives either......
on another note...have tried the max carbon camber links....they work well....might try again one day...
blade072 is offline
Old 08-10-2011, 05:37 AM
  #2797
Skiddins's Avatar
Originally Posted by spammy
what is the tape for?
The idea is that it allows the outdrive to distort slightly during a sudden impact, but the tightly wrapped tape spreads the loading of that impact a bit more evenly , instead of fracturing in the thinnest part of the outdrive.
It's certainly not a miracle cure but it does seem to help a bit
You need to make sure the tapes width is cut down so it can't get caught up in the bearings or the eccentric diff housing bits.
Skiddins
Skiddins is offline
Old 08-10-2011, 05:40 AM
  #2798
Skiddins's Avatar
Originally Posted by blade072
[/I][/B]on another note...have tried the max carbon camber links....they work well....might try again one day...[/I][/B]
I also use the Max Carbon upper links, as seen on the photo on the previous page.
The advantage of them is that they were a lot cheaper than Xray's.
I believe they have stopped making them now.
Skiddins
Skiddins is offline
Old 08-10-2011, 05:46 AM
  #2799
blade072's Avatar
Skiddins
the alternative are these http://www.litemodz.com/product_info...roducts_id=232 .....and i have a set....
blade072 is offline
Old 08-10-2011, 12:28 PM
  #2800
Johnny Wishbone's Avatar
Default Body weight?
Not T3 related but any one know what a trimed lightweight PF Speed6 with wing mounted weighs in grams? Clear or painted will work.
Johnny Wishbone is offline
Old 08-10-2011, 03:53 PM
  #2801
Team Speedy's Avatar
Trader Rating: 55 (100%+)
Questions??
Anyone here have any "firm" testing of the Xray "hard" plastic vs the "medium" composite. Is there an advantage to one? I.e. less prone to breakage, more grip, tunability, etc? If so, perhaps you could explain your findings. I've tried to read up in older threads but never seem to hit the answers I've wanted over time.
Secondly, does anyone still run the aluminum hardware, (knuckles, hubs, c-hubs) that was a popular trend back in the 04' - 08' days? I wasn't sure if something like that was worth considering to keep. If it helps at all I run on both carpet and asphalt so different perspectives of both would be great!
Team Speedy is offline
Old 08-10-2011, 04:08 PM
  #2802
yokemad's Avatar
I find Medium parts more robust , Alloy parts never breaks but bends which is not good and not always very noticable
I was keep breaking rear uprights till I've gone for Medium uprights ,since then no problem at all...
yokemad is offline
Old 08-10-2011, 04:19 PM
  #2803
Skiddins's Avatar
Knowing Litemodz the way I do, and formerly TiR. I won't hold out for any deliveries from them.
They are the most unreliable company there is!
Skiddins
Skiddins is offline
Old 08-10-2011, 07:57 PM
  #2804
kinga's Avatar
Not sure about the speed 6, but did a few measurements on my shells:
LCTR Normal weight - painted with shoo goo under arches: 107gms
LTCR lightweight - painted wth shoo goo : 88gms
Speed 6 normal - Painted, with shoo goo : 109gms
R9R lightweight - painted, with shoo goo : 87gms
Looks to be about 20grams lighter for the lightweight vs standard shells
kinga is offline
Old 08-10-2011, 08:20 PM
  #2805
My painted one is ~85g.
-Mike
grippgoat is offline
