Like Tree2Likes
Xray T3 2011
Old 08-08-2011, 02:37 AM
  #2761
Registered User
Trader Rating: 8 (83%+)
Originally Posted by blade072
i could of given you orange....its not a top or a kyosho mate....
and your ball end on the servo looks a little long....
oops lol just realised that i used the long one to work out how many shims to put between servo and servo posts,just gotta put the shorter one back on.
got orange but i wanted red!!!!
shano83 is offline
Old 08-08-2011, 04:25 AM
  #2762
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Well I have to say production gear diff is sweet and they put a lot of work into making not only the gears light, but the diff case also. I can say that with minimal prep it's a nicer piece than the tamiya gen 2 diff(tamiya diff needs break in to be butter smooth). The Oring / gasket combination is nice. The outdrive oring material is the same as the NT1 so it shouldn't leak and should be good for many runs before there is a need to change the oil. Be careful when using putty in the front position, if you do it might be a good idea to have spare gear sets.
Since I don't know of any mfg's that make anything higher than 1300cst in increments of 100cst here is some math help for mixing your own solutions out of say 1000 and 2000cst.
Calculating the viscosity of a blended liquid consisting of two or more liquids having different viscosities is a three step procedure. The first step involves calculation of the Viscosity Blending Index (VBI) of each component of the blend using the following equation (known as a Refutas equation):
(1) VBI = 14.534 ln[ln(v + 0.8)] + 10.975
where v is the viscosity in centistokes and ln is the natural logarithm (Loge).
The second step involves using this blending equation:
(2) VBI-blend = [wA VBIA] + [wB VBIB] + ... + [wX VBIX]
where w is the weight fraction (i.e., % 100) of each component of the blend. In using the above blending equation, it is necessary that all viscosities are determined at the same temperature, for example, 22 C.
The third and final step is to determine the viscosity of the blend by using the invert of equation (1):
(3) v = (ee(VBI - 10.975) 14.534) − 0.8
where VBI is the Viscosity Blending Index of the blend and e is the transcendental number 2.71828, also known as Euler's number.
Note the weight fraction can be found by weighing the empty diff case and filling appropriately (tare the diff case while loaded with the planetary gears ~7.9grams) keep in mind that 100% solution would weigh approximately 1.3 grams. If you don't feel like doing algebra you can use the scale method for mixing a consistent solution from build to build. (Ex: Adding .65 grams of 1000cst and .65 gr of 2000cst to make your builds consistent while mixing with non algebraic methods)
Can't wait for the North West Indoor Championships to start
rx7ttlm is offline
Old 08-08-2011, 05:30 AM
  #2763
yokemad's Avatar
Originally Posted by shano83
Even made up a pair of tamiya shocks to use and a thanks to craig and kinga for the advice and the know how to do it!!!!
Any chance to share that info?
yokemad is offline
Old 08-08-2011, 05:33 AM
  #2764
Skiddins's Avatar
Just got my exotek t311 chassis.Looks sweet and very nicely manufactored.
Even running the servo the right way.
even Using the zeppin racing steering mount.required a bit of shimming but i still get full lock.
Have you measured how thick the original chassis is compared with the Exotek?
Skiddins is offline
Old 08-08-2011, 05:45 AM
  #2765
sohlman's Avatar
Trader Rating: 92 (100%+)
Originally Posted by hanulec
Side Piece Racing Nikita Outdrives are starting to get some adoption in under 1 month of availability. At the 2011 ROAR Paved On-Road Nats there were a bunch of XRays from the 17.5T blinky TC (Steve Sohl) to 13.5T & Modified TC (Randy Bernard) successfully running these new outdrives. I haven't heard of a single broken blade yet...
I just got a picture from Haywood of them installed into his car:
Quality product. I inspected them after the race weekend, good as new. One less thing for me to worry about. And they are made in the USA!
sohlman is offline
Old 08-08-2011, 07:49 AM
  #2766
TeamB&B's Avatar
It takes a lot of convincing for us to even try a non Xray part in both of our XRAY T3'11 cars. During a recent club race, we broke the XRAY plastic outdrives in the 13.5 car and the aluminum ones in the MOD was showing a lot of wear. We tried the SidePiece outdrives and we were sold by the end of the day.
After 4 days of practice, qualifying and triple A mains at the ROAR Nats, the outdrives in both cars look perfect. Better yet, the 3.5 mm plastic caps on the drive shafts still look brand new.
Thank you for delivering a professional and quality product.
TeamB&B is offline
Old 08-08-2011, 10:00 AM
  #2767
Johnny Wishbone's Avatar
Stock is 2.53mm, Exotek is 2.27mm.
Johnny Wishbone is offline
Old 08-08-2011, 04:57 PM
  #2768
Skiddins's Avatar
Cheers, how does handling compare with identical setups?
Skiddins is offline
Old 08-08-2011, 05:02 PM
  #2769
Skiddins's Avatar
While I'm sure they're great (they certainly look it) I was told by Elliot Harper while he was still running Xray that the composite outdrives give more steering. So I'm afraid I'll suffer with the odd breakage to gain more steering.
P.S. If you wrap the composite outdrives with cell tape, going around them about 3 times, making sure you keep it tight while applying it. This seems to help the outdrives last a lot longer as it allows them to distort slightly in a crash but the tension of the tape helps to prevent them fracturing.
Skiddins
Skiddins is offline
Old 08-08-2011, 05:16 PM
  #2770
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Thanks guys for the unprompted feedback!
Skiddins
While the plastic outdrives might give more steering (i've never heard this before...) I for one rather finish my race than fail to finish. Your tape hint might do the trick for a bunch of people though....
For people who know me... I'm really good at failing without having other parts on my car fail
hanulec is offline
Old 08-08-2011, 05:21 PM
  #2771
wildman's Avatar
Do you have pics of an outdrive wraped with cell tape?
Thx
BB
wildman is offline
Old 08-08-2011, 06:32 PM
  #2772
kinga's Avatar
Trader Rating: 15 (100%+)
Hey Mate
Where did u order the exotek chassis from?
kinga is offline
Old 08-08-2011, 09:18 PM
  #2773
Weight wise the Exo is about 2 grams lighter, definitely narrower the the stock chassis. The chassis handle pretty much the same as it feels like the Exo chassis is as stiff as the stock one but not as thick. Of course this is with full upper deck screws in and on carpet, but i think it will shine on asphalt and taking advantage of the multi-flex settings.
Old 08-08-2011, 09:44 PM
  #2774
CraigM's Avatar
Trader Rating: 34 (100%+)
I'm interested to see this for myself, the exotek should flex more simply because its narrower, but also being made of thinner CF you would expect a noticible difference.
Originally Posted by kinga
Hey Mate
http://www.exotekracing.com
I ordered mine yesterday morning and it was shipped the same day. Great service
CraigM is offline
Old 08-08-2011, 09:57 PM
  #2775
Registered User
+1 to that Craig exotek has great service and there chassi is even better!!!
Kinga sorry for late reply not meant to be playing with my phone at work lol.Got mine through exotek.
Hey Craig those new shocks are so much nicer!!!
shano83 is offline
