Old 08-02-2011, 07:08 AM   #2686
kinga's Avatar
Trader Rating: 15 (100%+)
http://www.rc-mushroom.com/product_i...ducts_id=22994
Spotted this on rcmushroom. Might be a good thing to try for those using the 90 degree servo turn mod. Might add to it to my next purchase order form there to give it a go.
kinga is offline   Reply With Quote
Old 08-02-2011, 03:38 PM   #2687
jake95's Avatar
Trader Rating: 27 (100%+)
ill be grabing one off them soon looks prety good
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 08-02-2011, 04:47 PM   #2688
kinga's Avatar
Anyone know who has the XRAY gear diff in stock at the moment, rcmushroom is out, amain dont stock, cant seem to find it anywhere
Old 08-02-2011, 06:14 PM   #2689
JayL's Avatar
Which roll center mount in which position gives the LEAST roll L,H or old silver round?
MOD: A800X LRP FlowX X22 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 08-02-2011, 06:44 PM   #2690
Thanks Skiddins and Harry I'll try both of your suggestions.
Originally Posted by Skiddins View Post
Put slightly stiffer rear springs in, or preferably the same as the front.
Skiddins
Sponsored by mooby 64
outlandr91 is offline   Reply With Quote
Old 08-02-2011, 10:47 PM   #2691
CraigM's Avatar
Trader Rating: 34 (100%+)
H rolls more than L but there isn't much in it. If you wan't to stop your car rolling use the +0.75 lower suspension mounts
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-03-2011, 07:30 AM   #2692
yokemad's Avatar
Hi All
Ive build myself a t3 with exotek chassis ,t3 bulkheads etc. and 008 parts but as you know t3 rear shock tower 4 quick roll centre points are more upward compare to 008-9
What do you think should I buy, t3 rear shock tower or H1-h2 can sort that out?
Or leave it as it is???
Cheers
yokemad is offline   Reply With Quote
Old 08-03-2011, 09:23 AM   #2693
RC MARKET's Avatar
CSO New T3'11 2.2mm Carbon Chassis ( Servo Support 90 deg turn )
RC MARKET is offline   Reply With Quote
Old 08-03-2011, 09:55 AM   #2694
MikeR's Avatar
At least you could have tried to make it look like it was not traced
Is it Chinese 'carbon fiber'?
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-03-2011, 09:58 AM   #2695
Fred Hubbard's Avatar
When I saw the CSO chassis a few minutes ago I immediately noticed it was an a copy of the Exotek T3'11 chassis!!!
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 08-03-2011, 10:26 AM   #2696
JayL's Avatar
Already running those lower suspension mounts still need less roll for VTA 25.5 the WIDE tires and tall sidewall have plenty the car doesn't need to roll and make more grip
Old 08-03-2011, 10:52 AM   #2697
$72.95
$45.00
xtaiji is offline   Reply With Quote
Old 08-03-2011, 11:08 AM   #2698
yokemad's Avatar
Don't forget there are many different grade of quality CF available
It's a bit early too early to make judgement ...
Old 08-03-2011, 11:09 AM   #2699
yokemad's Avatar
Originally Posted by yokemad View Post
Hi All
Cheers
Anybody?
Old 08-03-2011, 11:17 AM   #2700
Johnny Wishbone's Avatar
Anybody?
I'd use the 008 shock tower and go after the inner rc adjusters. Go back a couple of posts where Craig M (i think) does a quick synopsis of link angle and how it works, this should benefit you with the 008 tower and just adjust on the outer to fine tune the angle. You could also post the same question to Paul L, I know they used to run the 008 but not sure if they still do on the 11.
Gary Lanzer
