Like Tree2Likes
Xray T3 2011
Old 07-30-2011, 07:36 AM
  #2656
heretic's Avatar
Originally Posted by Nilks
They break too easy.
Could you be a bit more specific as to what breaks ? Body, shaft, the piston itself ? Thanks.
heretic is offline
Old 07-30-2011, 07:49 AM
  #2657
I had problems with the pistons itself. Changed to 3-hole pistions and problems disappeared.
Nilks is offline
Old 07-31-2011, 03:12 AM
  #2658
Default H1+H2 & L1+L2 confusion
Hi there. The H1+H2 and L1+L2 usage seems as clear as mud.
What are the effects of L1/2 & H1/2 on the car ??
Cheers
1101 is offline
Old 07-31-2011, 03:34 AM
  #2659
jake95's Avatar
Trader Rating: 27 (100%+)
Cheers
they are 1mm higher than l1 l2
will allow car to roll more
jake95 is offline
Old 07-31-2011, 04:34 AM
  #2660
CraigM's Avatar
Trader Rating: 34 (100%+)
Cheers
On the front H has more initial steering, L has more steering off the corner. I haven't played around with the rear as much, but when I have H seemed to lock the rear in too much, so I always use L or inbetween (0.5mm on the new bulkheads). This is on rubber/asphalt btw.
CraigM is offline
Old 07-31-2011, 05:41 AM
  #2661
Trader Rating: 16 (100%+)
will moving the rear wheel base long or short help with rear traction cheers
jay m is offline
Old 07-31-2011, 03:16 PM
  #2662
M-Technic's Avatar
Trader Rating: 15 (100%+)
Hi, I'm considering buying Xray shock for my next car ( T.O.P,) because I like their 4-step pistons -externally adjustable. But it seems few people still use them ? I don't know. Anyway I would like some advice before maybe spending 80 bucks.
I really love the external adjustability and I'd be ready to give up a tiny bit of performance just for how convenient they are. On my FK05 these shocks have always been a major + compared to my other cars.
I don't think you'd be giving up any performance coming from the TOP shocks. The two TOP drivers we had at our track were running Tamiya shocks on their cars because they didn't like the TOP shocks.
Also, I can only think of one Xray driver in FL that uses the fixed pistons. Everyone else uses the adjustable pistons, myself included. I love having that adjustment and use it frequently.
M-Technic is offline
Old 07-31-2011, 03:42 PM
  #2663
jake95's Avatar
a shorter wheel base is better for sharp turns and could provide more rear grip long wheel base is better for high speed corners
jake95 is offline
Old 07-31-2011, 06:22 PM
  #2664
can someone please explain camber link angle for front and rear. Should they be the same angle front and rear? Does different angle produce different effects.
I am running normal roll center back and low roll center front
rayrush is offline
Old 07-31-2011, 10:03 PM
  #2665
kinga's Avatar
Would the H roll centers in the rear offer more rear grip? Using your H roll centers in the front, L in the rear. The front definitly offers more grip and turn in with the H roll centers on the front.
Track is too bumpy to run kit rear spring
my setup is here
http://forum.teamxray.com/xform/inde...&setup=t3_2011
Seems to break loose a bit off power, bites under power. On medium traction asphalt. Was locked with the XRAY shocks but they suck when u need to change oil, so went to TRF shocks. Much nicer shocks to build and seem super smooth but damping seems slightly harder maybe than xray.
kinga is offline
Old 08-01-2011, 12:51 AM
  #2666
does more initial steering mean more initial front grip ?? H is Better for long sweepers ??
use L in front if the car pushes coming out a corner? (not as much of an issue for me with silvercan racing)
Cheers
1101 is offline
Old 08-01-2011, 02:03 AM
  #2667
why isnt anyone running o-ring on shock shaft ? wont the shocks leak? cheers
jay m is offline
Old 08-01-2011, 02:16 AM
  #2668
kinga's Avatar
The oring goes on the inside of the shock bottom cap. You can also run an oring on the outside of the cap on the main shaft exposed section. Not sure of the purpose, maybe to stop harsh bottoming out. Without an oring on the inside of the shaft the shock would leak.
I beleive the oring mentioned on the setup sheets is the external oring to stop bottoming out
kinga is offline
Old 08-01-2011, 03:29 AM
  #2669
CraigM's Avatar
my setup is here
First get rid of that R9 body, they are horrible. MS6 for sure
I drove a car with a 30k front diff and it behaved just how you described. For a bumpy track I would leave the spool in to give it stability under brakes. Also the tamiya white springs are very stiff so I would go to something softer like xray 2.4 - Tamiya springs aren't really used on asphalt btw. Running H on the rear will lock the rear in more, I usually find running H on the rear takes away too much corner speed.
correct... except for long sweepers, it depends
The simplest explanation is the more angled down the camber link is, the higher the roll centre is, the less grip that end of the car will have. Normally you will have the front links slightly less angled than the back
CraigM is offline
Old 08-01-2011, 04:12 AM
  #2670
kinga's Avatar
Thanks Craig, wise words as usual. I was running spool for ages but went to the gear diff to get more turning. Our track has 6 x 180 degree corners and pushes too much for my liking with the spool. I can drive more consistant and precise with the gear diff up front. I have 50 000 cst diff silicone also, would that make much difference?
I agree, the R9 body is very aggressive, I tried the MS6 body I have also today on the new setup and was much calmer, I think most of the stepping out issues I am having is due to crappy tires, tried a few sets with varying results and got better with newer tires.
I have a full set of the spec-r 2.4-2.8 tuning springs for xray coming in the post this week from rc mushroom so will give the 2.4 a go. Also have the full tuning kit of sway bars coming, whats the best to try first instead of the kit ones?
Thanks for your tips on building the TRF shocks, one thing i found was the addition of a 11mm(I.D.) x 1mm thick oring to the inside of the shock top cap took up the slight difference in the diameter of the xray shock top and the tamiya shock top, and gives an air tight shock top every time. Was having trouble getting it 100 percent bled before this but now able to bleed first time everytime. i can actually make shock oil changes at the track and not have to worry about running out of shock oil or missing the race because of shocks taking 2 hours to bleed, awesome!
kinga is offline
