Like Tree2Likes
Xray T3 2011
Old 07-22-2011, 04:41 PM
  #2611
Bonadona's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Xpress
Yeah I now have to add $100 to the price of going to BTH...
+1
Bonadona is offline
Old 07-22-2011, 10:07 PM
  #2612
Team EAM
Trader Rating: 79 (100%+)
I hear ya on that!! This should be a bit cheaper and with a new top deck possibly.
EA
EAMotorsports is offline
Old 07-23-2011, 01:59 AM
  #2613
CraigM's Avatar
Trader Rating: 34 (100%+)
why do you need chassis plates?
CraigM is offline
Old 07-23-2011, 08:04 AM
  #2614
Xpress's Avatar
The track was, well, let's just say, a little bumpy.
Xpress is offline
Old 07-23-2011, 09:20 PM
  #2615
Suspended
I mean, my chassis isn't that jacked. Maybe raise your rideheight next time? :P
Chris Adams is offline
Old 07-23-2011, 09:21 PM
  #2616
spring71's Avatar
Smile
Spec-R upper deck,steering bock,upright and arms for Xray T3 are available at TQ RC RACING.
Spec-R: http://www.tqrcracing.com/shop/produ...id=60&s_sort=3
T3 parts store:http://www.tqrcracing.com/shop/parts.asp?parts_p_id=654
FYI, Thanks.
spring71 is offline
Old 07-23-2011, 10:20 PM
  #2617
Xpress's Avatar
Raise the rideheight? Any higher and I'll need 808 shocks and towers.
Xpress is offline
Old 07-24-2011, 01:41 AM
  #2618
Trader Rating: 16 (100%+)
hey guys had my first chance to try the specr diff today in mod just wondering if you guys needed to make any setup changes when going to the the gear diff. i found it to be a little more taily off power on corner entry with 1000 cst tried 600 mm shock oil and the same should i go 2000cst and try? car was very good with the ball diff. any suggestion for thing to try or look at car is near box setup cheers
jay m is offline
Old 07-24-2011, 11:55 AM
  #2619
Most of the Xray drivers I know, use 2000cst in the rear.
Nilks is offline
Old 07-25-2011, 05:33 AM
  #2620
kinga's Avatar
Trader Rating: 15 (100%+)
Just raced my first meet with the t3 2011, had the servo turned 90 degrees as per Clint Livingston AKA PIMP setup. As everyone has said, the car is overall much easier to drive with the same overall grip level. I put it down to the car having a more even steering spread due to the wider EPA on the servo.
I have a tendancy for big movements with the steering wheel so having to be less fidgety and precise with the wheel made it easier to pull off consistant lap times.
I was racing the T3R previously and everyone i race with who was marshalling all said how much smoother the t3 2011 looked compared to the old T3R.
Laptimes werent significantly faster, maybe .3 sec at best but overall consistancy went from P.B. of 1 sec down to .5 which is big.
I am also running gear diff front and rear, huge difference and makes the car much easier to drive, my 2cents worth if u are looking to get a more consistant car overall. Our track has heaps of 180 degree corners which makes it unusual though
kinga is offline
Old 07-25-2011, 07:17 AM
  #2621
Hi,
Just received my x ray gear diffs. Was thinking of running 1000cst in the rear but a bit unsure about the front gear diff. Any suggestions would be appreciated. Racing on carpet.
rayrush is offline
Old 07-25-2011, 09:17 AM
  #2622
Anyone else ever have issues with the T3R servo saver popping out after a big hit due to chassis flex? Did I miss something in the build?
Syxxstring is offline
Old 07-25-2011, 09:51 AM
  #2623
whityboy's Avatar
I also had this problem.
Place an aluminum top deck mount (30 6515-K) behind the servo to prevent this in the future
whityboy is offline
Old 07-25-2011, 10:43 AM
  #2624
Default Diff
Originally Posted by rayrush
Hi,
Ideally cleaning gum in front, as much as you can get in, if not 500000 cat oil. In rear, around 1000 should be ok as a starting point, I'm using 70wt shock oil in mine.
Ps until recently, no one run gear diffs in the front of there cars over here, a couple of weeks after people have seen mine you can't spot a spool anywhere!
Mb3195 is offline
Old 07-25-2011, 05:52 PM
  #2625
What is 500000 cat oil. What is that is cst?
rayrush is offline
