Like Tree2Likes
Xray T3 2011
Old 07-20-2011, 05:02 PM
  #2596
Fred Hubbard's Avatar
Originally Posted by Tron
Hello~
I need to work on getting my car to rotate more on corner entry and exit with a bit more on power steering. With Solaris Hard spec tires my car rotates OK, but I raced with the Solaris SP40 and the rear end seems to be more stuck, same track same setup as posted below.
I attached my setup sheet...I was thinking a 0.3mm or 0.5mm spacer under the rear suspension blocks or using the inside hole on the clamps to make a longer camber link in the rear.
For the T3 2011, which way do Ackermann spacers work? Less shims = more rotation? I'm running 1mm Ackerman spacers.
Come see if you are you going to be at WC tomorrow or Saturday.
Fred Hubbard is offline
Old 07-20-2011, 09:19 PM
  #2597
CraigM's Avatar
Trader Rating: 34 (100%+)
Hello~
Less ackerman shims make the car more agressive mid corner.
Raising the rear RC should work but I'd just try a harder rear bar to start with. I've also found the shorter rear link gives better mid-corner steering.
CraigM is offline
Old 07-20-2011, 10:28 PM
  #2598
Hi, Need a little help. Which ecs drive shafts to get 50 or 52mm to run with 304900 gear diffs?
Also does it make a difference if i am running different track width at front?
Thanks.
rayrush is offline
Old 07-21-2011, 05:34 AM
  #2599
Skiddins's Avatar
Hello~
Perhaps try all or some of the following;
Less rear toe
Stand rear shocks up more
Harder rear spring
Skiddins
Skiddins is offline
Old 07-21-2011, 11:17 AM
  #2600
Tron's Avatar
Trader Rating: 17 (100%+)
I'll be there Saturday when they open, thanks again for all the help
Thanks to Craig, hana and Skiddins for the replies too.
I'm trying to find that 0.4s I need to be competitive in the Expert class.
Tron is offline
Old 07-21-2011, 11:32 AM
  #2601
Brett, nice avatar
stitchy is offline
Old 07-21-2011, 02:29 PM
  #2602
Built my xray geared diff tonight. All went smoothly. Will update tomorrow on How it performs compared to the ball diff.
Xray2011 is offline
Old 07-22-2011, 10:45 AM
  #2603
Over-rev's Avatar
I had a few questions regarding the new gear diff for the T3-11. First, who is selling it atm? I have tried looking on A Main and sofar they do not have it up.
How does the new gear diff compare to the Multi-Diff? Would the Multi-Diff have any benefits over the new gear diff?
I am using the car for bashing and the occasional race, and am not looking forward to constantly adjusting and rebuilding the ball diff. Also would it be good to get the diffs to replace both front and rear, or is just the front needed only?
Thank you
Over-rev is offline
Old 07-22-2011, 10:58 AM
  #2604
Thank you
here you go
http://www.nexusracing.com/product_i...oducts_id=3478
http://www.amainhobbies.com/product_...ic-Touring-Car
light
light is offline
Old 07-22-2011, 11:28 AM
  #2605
Magnet Top's Avatar
Originally Posted by Xpress
Do you have any idea how much lighter the spec-r is with their aluminum outdrives?
The spec R gear diff WITH the optional low weight aluminum outdrives ( is about 21 grams ) which is still roughly 5 grams heavier than the Xray T3 gear diff !
The Xray gears and case feel feather light. I'm guessing lots more carbon than plastic.
Magnet Top is offline
Old 07-22-2011, 11:36 AM
  #2606
Over-rev's Avatar
lol I have the car already, I was just looking for who is actually selling the Xray gear diff, and whether it is worth going with over the Multi-Diff. ty though.
Over-rev is offline
Old 07-22-2011, 11:38 AM
  #2607
Are there any parts needed in aluminum or carbon fiber? I know a great cnc shop and I would like to start making parts
dragracekid is offline
Old 07-22-2011, 12:35 PM
  #2608
Xpress's Avatar
How about chassis plates (properly drilled) for under $100?
Xpress is offline
Old 07-22-2011, 12:53 PM
  #2609
Team EAM
Trader Rating: 79 (100%+)
I know someone that is working on that. Should have more done very very soon. Possibly for sale at the Nats next week too!!
EA
EAMotorsports is offline
Old 07-22-2011, 01:01 PM
  #2610
Xpress's Avatar
EA
Yeah I now have to add $100 to the price of going to BTH...
Xpress is offline
